Zalman K500 Mechanical Keyboard: Replacing Single Switch & Fixing Non-Working 'D' Key
feebas 30225 3
  • #1 14448351
    feebas
    Hello!
    I have a problem. I flooded the Zalman K500 mechanical keyboard. I dried it and it worked fine, until the letter d stopped working. When I wet the switch a little, it all works until it dries. There is no contact. Now the question. Is it possible to replace a single switch? Are there any chances to fix this? Do I have to "drool" the switch to the end of my life :D
    bloodyman
    Help: 9
    Rate: 171
    You can look for some, but I doubt you will find a single one. If you can, replace the switch with one that is not used from the same key, type Pause break page down or something :)
  • #4 14448635
    feebas
    Ok, it worked without changing the switch. After taking it out, it turned out to be working, so probably February was faulty. After soldering, everything works :D
