No Signal & Poor Quality on CP HD 6000 Decoder: Inverto TWIN RED EXTEND HDTV, Channel 42 CBS Europa
dariusz_pt 17502 14
Why does my CP HD 6000 decoder show 0 signal and poor quality on some channels while other channels work normally, and is the LNB or antenna alignment to blame?
The decoder shows different signal quality on different channels because those channels come from different transponders, polarizations, and frequency groups, so one setting can be fine on one channel and fail on another [#16626075] In this case, the most likely culprit was the converter/LNB: after testing the decoder on a neighbor’s antenna installation, it received all channels correctly, which pointed to the original Inverto LNB rather than the decoder itself [#16626417] Another factor discussed was LNB skew and dish alignment, because a bad tilt can make some frequencies disappear while others remain usable [#16629444] The problem was ultimately solved by replacing the Inverto TWIN RED EXTEND HDTV with a new Televes TWIN 747802 LNB, after which the antenna set up normally and the missing channels returned with 89% signal strength and 100% quality [#16633116]
  • #1 16625977
    dariusz_pt
    Rate: 18
    I have a problem with the reception of some programs on the CP HD 6000 decoder. The image on some channels is of poor quality, or the board does not display a signal from the TV antenna. This is not the case for all programs: for example, on Channel 42 of CBS Europa this is happening. When I enter satellite dish settings in the menu, the quality and strength of the signal is 0. After a moment I switch to the 40 COMEDY CENTRAL channel, the picture is very nice. I enter the antenna settings on this channel and see: signal strength 80, quality 83. Please explain how it is on two channels almost simultaneously the decoder shows different antenna settings. The decoder has the latest updates and a loaded list of channels. The converter is Inverto TWIN RED EXTEND HDTV
    I wrote to CP and I received the answer:
    Sir
    We would like to kindly inform you that the described situation indicates incorrect setting of the antenna or problem with the converter. Poor picture quality or lack of channel reception are in this situation caused by insufficient signal strength. Therefore, we recommend checking the correctness of the antenna setting and the operation of the entire antenna installation.
    We explain that the channels are broadcast on 4 frequencies: high vertical and high horizontal, low vertical and low horizontal. The converter and decoder have 4 heads adapted to receive these frequencies. A properly set antenna should receive the signal from all 4 frequencies. Incorrectly set antenna can receive several frequencies, not all, then on the channels whose frequency is not received, the following message is displayed: no signal.
    There is also the possibility of a problem with the lack of signal on some of the channels, in case of damage to one of the converter heads or the decoder.
    If you are sure that the problem does not lie with the antenna installation, we recommend that you go with the set-top box along with the accessories to the Authorized Sales Point in order to check the correct operation of the equipment.
    The list of points can be found at:
  • #2 16626075
    sanfran
    Help: 958
    Rate: 2994
    As it was written, the converter receives signals in two polarizations and two frequency groups. The tuning of the converter to the transmitted signal is controlled by the decoder by supplying the appropriate voltage and frequency to the converter.
    It can also happen that one channel is polarized horizontally and the other one vertically or are on other frequency groups and hence these differences.
    So, apply to the operator's advice, check the decoder on a different antenna and if it is working, replace the converter.
  • #3 16626081
    D214d3k
    Help: 543
    Rate: 631
    Wikipedia: "At present, there are three active satellites at 13 ° E: Hot Bird 6 (Eutelsat Hot Bird 13A), Hot Bird 8 (Eutelsat Hot Bird 13B) and Hot Bird 9 (Eutelsat Hot Bird 13C)."
    They are distant from each other and it may happen that you aim at one on the limit of range and the other 2 are out of range. The problem may be further aggravated by the redirection of beams to different parts of Europe.
    Adjust the antenna.
  • #4 16626106
    dariusz_pt
    Rate: 18
    Thank you for the remarks. I have already set the antenna in various ways, moving the plate slightly to the sides or vertically causes no signal. The antenna does not obscure anything. Before I wrote to CP, I was thinking about buying a new converter. I was thinking about two: INVERTO TWIN BLACK ULTRA or INVERTO TWIN BLACK PREMIUM HDTV. The difference in price is around PLN 40. Is it worth overpaying and buying the more expensive one, or it will be a significant difference in my perception.
  • #5 16626142
    D214d3k
    Help: 543
    Rate: 631
    Price comparison shows that one costs from 50 zlotys and the other from 75 so it is not so much. But regardless of the beautiful marketing names, the measure of the quality of the converter is the noise figure. Both have 0.2. "If you can not see the difference then why overpay" :) .
    Here you have a topic to read https://www.elektroda.pl/rtvforum/topic1574071.html
  • #6 16626335
    andpol 33
    Help: 512
    Rate: 1144
    You need to replace the decoder and that's it.
  • #7 16626417
    dariusz_pt
    Rate: 18
    However, this is the fault of the converter. I connected the decoder to the neighbor's antenna installation, and despite the worse parameters, strength and quality, the decoder received correctly on all channels.
  • #8 16629205
  • #9 16629230
    dariusz_pt
    Rate: 18
    The bowl is new, undeformed. I have CP Familijny Max HD, I checked and from 200 channels only on 23 I do not have a picture and the board displays no signal. In the decoder menu in the antenna settings, the quality and strength of the signal is at 0. On the other channels, the quality and signal strength are 80 and 83, respectively, and it is very stable. If I start to set the antenna on channels where there is no signal, all other channels will disappear. I have noticed this problem for about two weeks. First, I explained it with storms and strong and discharges that could damage something. At about the same time, the decoder software was automatically updated, but it probably has nothing to do with it.
  • #10 16629272
    mocu
    Rate: 12
    The channels are broadcast from various transponders. I know from my own experience how I set up my antenna in my truck (and I do it several times a week) that sometimes when I set a perfect signal, for example on Discovery, TVN channels have too low signal. A slight adjustment of the bowl, or twisting the converter sometimes helps. Maybe the wind slightly moved the antenna and there are effects. Also take into account the elevation angle.
  • #11 16629292
    D214d3k
    Help: 543
    Rate: 631
    I'm just going to ask you this way. Slant converter set?
  • #12 16629342
    dariusz_pt
    Rate: 18
    Yes, slightly to the left looking from the back of the canopy.
  • #13 16629444
    _kli_
    Help: 759
    Rate: 1035
    Looking from behind the antenna should be twisted clockwise. Assuming that the handle is vertical, the turn should be around 7 ° in Dębica. With a bad twist you can have a shoulder to pick up some frequencies.
  • #14 16629850
  • #15 16633116
    dariusz_pt
    Rate: 18
    Thank you all for your comments. Today I founded a new Televes LNB twin 747802 converter and without the slightest problem in 20 minutes I was able to properly set up the antenna. In the decoder menu, the antenna's signal strength setting is 89% and the 100% quality is still on all channels that I did not receive on the Inwerto converter. Thank you again for the comments, but not everyone who said them read my post carefully.
✨ The discussion revolves around reception issues with the CP HD 6000 decoder, specifically regarding poor signal quality on certain channels, such as CBS Europa (Channel 42), while other channels like Comedy Central show good quality. Users suggest that the problem may stem from incorrect antenna settings, the converter's polarization, or issues with the converter itself. The author considers replacing the Inverto TWIN RED EXTEND HDTV converter with either the INVERTO TWIN BLACK ULTRA or INVERTO TWIN BLACK PREMIUM HDTV models. After testing the decoder with a neighbor's antenna, the author concludes that the converter was at fault. Ultimately, the author successfully resolves the issue by installing a new Televes LNB twin 747802 converter, achieving optimal signal strength and quality across all channels.
TL;DR: A user saw 0% signal/quality on one channel while another showed 80/83%, and “channels are broadcast on 4 frequencies.” The fix was LNB alignment or swap. [Elektroda, dariusz_pt, post #16625977] Why it matters: This FAQ helps CP HD 6000 owners fix selective “No signal” issues fast without costly service calls. For: CP HD 6000 + Hot Bird 13°E users troubleshooting missing channels or poor quality.
Why do some CP HD 6000 channels show “No signal” while others are OK?
Different channels use different bands and polarizations. If the dish or LNB is slightly off, only some bands arrive. The operator notes channels span four groups: high/low and horizontal/vertical. Align so the LNB sees all four. “A properly set antenna should receive… all 4 frequencies.” [Elektroda, dariusz_pt, post #16625977]
What’s the fastest way to confirm if my LNB is bad?
Move only your decoder to a known-good dish. If every channel works there, your LNB or dish setup is at fault. In the thread, this test proved the converter was the issue despite weaker overall readings on the neighbor’s system. [Elektroda, dariusz_pt, post #16626417]
How do I set LNB skew on Hot Bird 13°E for Poland?
Stand behind the dish and rotate the LNB slightly clockwise. One installer advised about 7° in Dębica, assuming a vertical mast. Incorrect skew can make some frequencies vanish even if others look fine. [Elektroda, kli, post #16629444]
What does “four frequencies” or “four bands” mean here?
Consumer LNBs switch among low/high bands and horizontal/vertical polarizations. The receiver commands the LNB to pick the right combination. If alignment or LNB switching is off, channels in the missing band show zero signal. [Elektroda, dariusz_pt, post #16625977]
What is a transponder, and why do small adjustments fix some channels?
A transponder is a satellite frequency block carrying multiple channels. Slight aim or skew errors can favor one transponder while degrading others. A tiny antenna tweak or LNB twist often recovers the missing set. [Elektroda, mocu, post #16629272]
Could the dish or cable be the real problem, not the LNB?
Yes. A deformed reflector or damaged cable can selectively attenuate bands. One responder warned against eyeballing alignment and noted physical faults can mimic LNB failure. Use proper tools or swap parts methodically. [Elektroda, 1098678, post #16629205]
Which LNB should I buy: Inverto Twin Black Ultra vs. Black Premium?
A member compared them and highlighted the same 0.2 dB noise figure. With equal specs, paying more brings little benefit for this fault. Quote: “If you can not see the difference then why overpay.” [Elektroda, D214d3k, post #16626142]
Did swapping to a Televes 747802 Twin actually solve it?
Yes. The OP replaced the Inverto unit with a Televes LNB twin 747802, then set the dish in 20 minutes. Signal stabilized at 89% strength and 100% quality across previously missing channels. That’s a clear success metric. [Elektroda, dariusz_pt, post #16633116]
Could a firmware update in the CP HD 6000 cause missing channels?
The user noticed an update around the same time, yet the pattern matched RF alignment or LNB issues. Adjusting the dish on missing channels broke others, pointing back to alignment, not firmware. [Elektroda, dariusz_pt, post #16629230]
What signal numbers should I aim for on the CP HD 6000?
Working examples showed about 80% strength and 83% quality. After the LNB swap, the system reached 89% strength and 100% quality on all channels. Use these as practical targets during peaking. [Elektroda, dariusz_pt, post #16633116]
Are multiple Hot Bird satellites at 13°E relevant to alignment?
Yes. The cluster consists of separate spacecraft near 13°E. Aiming at the edge for one can weaken others, especially with regional beams. Precise pointing keeps all in range. Adjust the antenna. [Elektroda, D214d3k, post #16626081]
How do I fix missing channels without special tools?
Try this:
  1. Test your decoder on a neighbor’s dish to isolate the fault.
  2. Set LNB skew slightly clockwise; about 7° was suggested.
  3. Fine-tune azimuth/elevation until all bands read stable, then tighten. These steps restored full service in the thread. [Elektroda, kli, post #16629444]
Why did Channel 42 (CBS Europa) fail while Comedy Central worked?
They sit on different transponders and, potentially, different bands/polarizations. The receiver showed 0% on one and 80/83% on another. That mismatch screams skew/aim or LNB switching trouble. [Elektroda, dariusz_pt, post #16625977]
What’s an LNB, in simple terms?
It’s the “converter” at the dish focus. It selects band and polarization, amplifies the signal, and downconverts it for your receiver. If one selection path fails or alignment is off, only some channels vanish. [Elektroda, sanfran, post #16626075]
Edge case: aligning on one channel breaks others. Why?
You peaked the dish or skew for a single transponder. Slightly re-aim and re-skew so multiple transponders hold good margins. “A slight adjustment of the bowl, or twisting the converter sometimes helps.” [Elektroda, mocu, post #16629272]
