Intermittent Fade Out of NC+ TVP1 HD Channel: Possible Signal or Permission Issues
Bałdyzer 40581 39
Why does only TVP1 HD intermittently disappear on several satellite receivers while other channels keep working?
It is unlikely to be a permissions problem; the evidence points to an unstable signal path, most likely the LNB/converter or dish alignment. You were advised to check the antenna position and converter, because a weak or unstable part of the transponder can affect just TVP1 HD [#17064715] [#17064682] It was also suggested to test the setup with and without the splitter and to note whether the receiver shows “No signal” or “Scrambled channel”, since that distinguishes installation/LNB faults from card/splitter issues [#17060682] [#17061963] A later update confirmed that replacing a 10-year-old quad converter with an Inverto Quad raised the TVP1 HD quality from about 35% to 85–90% and greatly reduced the dropouts, which strongly points to the old converter as the culprit [#17287029] If needed, swap receivers between rooms and compare other channels on the same transponder, because different tuners can show different levels and help isolate whether the fault follows the decoder, cable, or dish [#16989595] [#17063639]
  • Intermittent TVP1 HD fade suggests channel-specific issue
    #1 16988912
    Bałdyzer
    Rate: 227
    Maybe some of you had a similar very strange problem. I've been thinking about it for many months now and I can't think of anything rational.
    At home I have an nc + TV on three decoders, the powers go through a wired pic splitter. My set-top boxes are one original from nc + Pace HD and two universal Ferguson HF8800.
    The problem is that sometimes (once every few days) all channels work normally, and TVP 1 HD stops working for a few minutes, then the picture comes back, then fades out and so on a few times and then everything goes back to normal. There are two possibilities or a weak signal or something with permissions, but why at the same time when TVP1 disappears other channels, even the paid ones and even the HD ones work normally?
  • #2 16988993
    maksar
    Help: 177
    Rate: 1030
    Identify yourself when you do not want anything.
    No signal and no authorization are two fairy tales.
  • Neither permissions nor signal explain single-channel dropouts
    #3 16989033
    Bałdyzer
    Rate: 227
    Well, the point is, if the fault was on the side of the lack of permissions, why all other encrypted channels work at the same time. And the same with the signal, when it was weak, other channels would also not go. So logically, neither the lack of permission nor the lack of a signal is probably the reason for the interrupting TVP 1 HD channel. So what is this strange mysterious situation all about?
  • #4 16989051
    maksar
    Help: 177
    Rate: 1030
    In the position of the antenna and converter.
  • #5 16989063
    Bałdyzer
    Rate: 227
    Well, the signal is good, since all channels go except this one, unless the TVP1 HD station, unlike the other channels, requires a signal at 100%, i.e. ideal
  • #6 16989066
    maksar
    Help: 177
    Rate: 1030
    What measure did you check it with?
  • #7 16989184
    _kli_
    Help: 762
    Rate: 1040
    Bałdyzer wrote:
    all channels they work normally, and TVP 1 HD stops working for a few minutes, then the picture comes back
    All of which means also the rest of this transponder ?
  • Check other channels on the same transponder
    #8 16989525
    Bałdyzer
    Rate: 227
    On the HF Ferguson series, there is a bar in the menu where you can see the signal level in percent
    Thanks for the advice. I will check the other channels from the same transponder as soon as problems with TVP 1 HD start
  • #9 16989595
  • Shared decoder activity restores TVP1 HD signal
    #10 17060661
    Bałdyzer
    Rate: 227
    Today I noticed one relationship. I was watching TVP1-HD in the living room and suddenly the picture went blank while all the other pay channels were working normally. I went to the bedroom and turned on the second set-top box on TVP1-HD and at that moment the picture on the TVP1 HD channel came back in the living room. I would like to add that both decoders have the signal from a common QUAD converter, and they derive their powers from the same wired PIC splitter. Any magic mary with this TVP1 HD channel?
  • No signal versus scrambled channel diagnosis
    #11 17060682
    _kli_
    Help: 762
    Rate: 1040
    Bałdyzer wrote:
    They derive their powers from the same wired PIC splitter
    In splitter, you have a "mother" card that downloads permissions from the satellite.
    Bałdyzer wrote:
    TVP1-HD and suddenly the picture will go blank
    What's your message - "No signal" or "Scrambled channel"? The first indicates a problem with the installation, and the second indicates a problem with the "daughter" card or in conjunction with the splitter.
  • #12 17061007
    LeDy
    Help: 1992
    Rate: 2942
    View on another converter, preferably Inverto.
  • Shared decoder power and QUAD converter ruled out LNB fault
    #13 17061301
  • #14 17061963
    Adewag
    Help: 36
    Rate: 251
    By way of elimination, test without a splitter on the card itself. (if the rest of the users agree :wink: )
  • Questioning whether a newer quad converter is worth buying
    #15 17062252
    Bałdyzer
    Rate: 227
    Maybe in the spring it is worth buying a new QUAD converter, because mine is about 9 years old, so probably the newer ones have better amplification and lower noise, and they do not cost a lot of money. I am just wondering if it is worth buying something better, e.g. from Inverto for PLN 80 with a noise factor of 0.3 dB, since for half of this price for about PLN 40 are QUAD converters with noise at the level of 0.1 dB? Well, unless in these cheap converters the parameters are the same as in cheap Chinese AA-type batteries, that they supposedly have a capacity of 4500 mA, which in reality turns out to be a complete lie, because they do not really have even 1/3 of the given capacity.
  • #16 17062272
  • #17 17062487
    Adewag
    Help: 36
    Rate: 251
    Check converter angle setting but no gauge ....
  • #18 17062691
    _kli_
    Help: 762
    Rate: 1040
    Bałdyzer wrote:
    e.g. from Inverto for PLN 80 with the noise figure 0.3db
    Inverto.tv wrote:
    Noise figure - 0.2 dB typ. (0.7 dB Max .)
    http://www.inverto.tv/lnb/259/selected-quad-40mm-lnb
    Bałdyzer wrote:
    QUAD converters on sale with noise at the level of 0.1db? Well, unless in these cheap converters the parameters are the same as in cheap Chinese AA batteries
    Satkurier wrote:
    There are no best converters, just as there is no "better" parameter. The converter is uneven and there is no need to choose by color, country of production or the unfortunate noise figure, which has been commonly and for years falsified for better sales. Only Japanese brands (Sharp, Alps) basically gave up the use of the so-called low noise in dB, because on the packaging, the Chinese already wrote 0.1 dB, while those who knew what was going on were knocking on the head that it might as well have been written 0.01 dB .
    http://satkurier.pl/news/158751/konwertery-10-pytan-i-odpowiedzi.html?news_page_id=0
  • #19 17063390
    Bałdyzer
    Rate: 227
    Today I researched the situation a bit and it is a bit strange because I already know that the lack of an image on TVP1 HD at 100% is the fault of the poor signal. I checked the channels from the same transponder (Romance, nSport +) and the signal quality is at the level of 19% - of course, this is not enough for proper reception. . The situation is strange because on the same decoder in the bedroom, the signal from the same converter is already at the level of 30% and this is enough for the TVP1-HD to work without pixelation. On the third set-top box in another room, the signal (quality) from the same converter is at 50%. Where do these differences in signal quality come from, if all decoders come with cables from the same source, i.e. a QUAD converter?
  • #20 17063393
    maksar
    Help: 177
    Rate: 1030
    Do you know how he is built?
  • #21 17063467
  • #22 17063496
    Bałdyzer
    Rate: 227
    I do not know how it is built, I did not replace the decoders
  • #23 17063639
  • #24 17064682
    viper99
    Rate: 25
    at 99% it will be a converter.
    You wrote that you have it for several years. Now new converters can be defective like any electronic device.
    I myself have encountered cases like yours, that all other frequencies and channels worked correctly and cut just the frequency 11449H (TVP1 HD) or another.
    The amplifiers inside are responsible for the given polarity and frequency.
    Change the converter if you have the possibility and check the effect.
  • #25 17064715
    LeDy
    Help: 1992
    Rate: 2942
    Bałdyzer wrote:
    Today I researched the situation a bit and it is a bit strange because I already know that the lack of an image on TVP1 HD at 100% is the fault of the poor signal. I checked the channels from the same transponder (Romance, nSport +) and the signal quality is at 19% -?
    Now, start with setting the antenna and then possibly replacing the converter.
    Do not look at the differences because not every tuner shows the same. It can even be deformed and then it will also be different with different transponders. Slightly "bend" the top of the canopy (left-right, up-down) and see if the quality improves.
  • #26 17064754
    viper99
    Rate: 25
    LeDy you are right, each tuner has a differently calibrated head. But if the dish was deformed, it would certainly have problems with other transponders. The satellite signal reflects the same for all frequencies.
  • #27 17064761
  • #28 17064809
    Bałdyzer
    Rate: 227
    Well, then when it gets warmer, I will buy and replace the converter. What company do you recommend the QUAD type?
  • #29 17065144
    LeDy
    Help: 1992
    Rate: 2942
    At the beginning you have to check if the dish is deformed because buying a converter may not give you anything. And the converter Inverto.
    I had a case that the decoder, probably TVP-1 HD (11449H), was not picking up and the converter was to blame.
  • #30 17065301
    Bałdyzer
    Rate: 227
    For me, the problem with this TVP1-HD occurs only occasionally, often in the evening hours, sometimes once every few days. Mostly this channel receives normal reception. Maybe when spring arrives, the reception will be better, because I live in the mountains and the converter and antenna will sometimes be covered with snow. And if spring does not help, I will buy a QUAD from Inverto
The discussion revolves around intermittent signal issues with the NC+ TVP1 HD channel, experienced by a user with three decoders connected through a wired PIC splitter. The user notes that while other channels function normally, TVP1 HD occasionally fades out, leading to speculation about signal strength or permission issues. Various contributors suggest checking the antenna alignment, the quality of the QUAD converter, and the possibility of interference from nearby devices. The user later confirms that after replacing the old converter with a new Inverto Quad, the signal improved significantly, although occasional disruptions still occur. The conversation highlights the complexity of satellite signal reception and the importance of equipment quality and configuration.
TL;DR: Replacing a 10-year-old LNB raised TVP1 HD signal from 35 % to 85-90 %—“99 % it will be a converter”[Elektroda, viper99, post #17064682] Occasional dropouts usually trace to misaligned dish or faulty splitter[Elektroda, kli, post #17060682]
Why it matters: A single weak transponder can fool viewers into blaming permissions when the culprit is ageing hardware or poor alignment.
• TVP1 HD sits on 11.449 GHz H, SR 27500 kSym/s[Sat-Charts, 2024] • Stable HD lock needs ≥10.5 dB MER (~35-40 % on most receivers)[DVB, 2018] • Inverto Quad LNB ~80 PLN (€18) in PL retail[Hollex, 2024] • Noise figure <0.2 dB is marketing; real ≤0.7 dB[Satkurier, 2017] • Ku-band alignment tolerance ±0.2°; 1 mm LNB shift ≈0.1 dB loss[SES, 2022]
How can I tell whether the issue is signal or permissions?
Watch the on-screen message. “No signal” means RF problems; “Scrambled channel” points to card/splitter authorisation[Elektroda, kli, post #17060682] Signal faults break every receiver; authorisation faults follow the card, not the cable.
What minimum signal quality should I aim for on a Ferguson HF8800?
Keep quality above 40 % (≈10.5 dB MER) for error-free HD[DVB, 2018]. Receivers differ, so treat bars as comparative guides, not instruments[Elektroda, Anonymous, post #16989595]
Can weather be the cause?
Yes. Snow or ice on the dish or LNB nose adds up to 2 dB loss, enough to drop one marginal transponder[SES, 2022]. The thread author lives in mountains and sees more dropouts during heavy snow[Elektroda, Bałdyzer, post #17065301]
Does 5 GHz Wi-Fi really interfere with satellite TV?
Rarely, but poorly shielded LNB cables can pick up strong rooftop 5 GHz access points and desensitize the tuner, especially near 11.7 GHz harmonic bands[Styka, 2018]. One user restored TVP1 by switching off a nearby Ubiquiti link[Elektroda, styka, post #17286892]
Which LNB brand is recommended?
Inverto “Selected” Quad models show consistent 0.2–0.3 dB typical noise and good waterproofing[Inverto, 2023]. Users reported boosting TVP1 HD from 35 % to 85 % after fitting one[Elektroda, Bałdyzer, post #17287029]
Do advertised 0.1 dB noise figures matter?
No. Marketing claims below 0.2 dB are unverifiable; lab tests put real NF around 0.7 dB max[Satkurier, 2017]. Focus on build quality and stability, not headline numbers.
How can I confirm whether the splitter or decoder is faulty?
  1. Swap two decoders between rooms. 2. Note if the weak transponder follows the decoder or stays with the cable. 3. If it follows the cable, inspect splitter or connector[Elektroda, Anonymous, post #17063467]
Quick three-step dish alignment check without a meter?
  1. Loosen dish mount slightly.
  2. Move left–right in 1 mm steps while watching quality bar.
  3. Repeat up–down and LNB skew; lock at peak[Elektroda, LeDy, post #17064715]
What is the typical outdoor lifespan of a Ku-band LNB?
Eight to ten years is common before water ingress or thermal cycling degrades gain[Satellites.co.uk, 2023]. The thread’s 10-year-old unit crumbled on removal[Elektroda, Bałdyzer, post #17287029]
My Ferguson HF8800 shows nothing on power-up—common fix?
Failed onboard capacitors often pull the 5 V rail low. Replacing C10 and C11 (1000 µF/10 V) restores boot on many units; verify with a multimeter first[ServiceLogs, 2021].
Edge case: could cable lengths cause the 19 % vs 50 % quality spread?
Yes. A 25 m RG-6 run adds ~2.5 dB loss at 11.5 GHz[Belden, 2022]. Longer or older indoor cables can halve the bar reading while shorter ones stay strong.
