- PCI Sound Card for Windows 10: Affordable Options & Creative Sound Blaster Audigy SE OEM
dawciobiel 6366 10
Can I buy a PCI sound card that has Windows 10 drivers, and what cheap options are available?
Yes—look for a PCI sound card with Windows 8 drivers, because those usually work on Windows 10 [#16478104] One inexpensive example mentioned was the SPEEDLINK SOUND CARD SL-8861-SRD for PLN 37 plus shipping, and the manufacturer lists Windows 8 drivers for it [#16477818] The Creative Sound Blaster Audigy SE OEM PCI was also mentioned, but at PLN 95 it is above your target budget [#16477668]
  • #1 16477362
    dawciobiel
    Rate: 18
    Is it possible to buy a sound card on the PCI connector (not to be confused with PCI-E) which will have drivers for Windows 10?
    Update question:
    Creative Sound Blaster Audigy SE OEM (PCI)
    https://www.x-kom.pl/p/10339-karta-dzwiekowa-...-blaster-audigy-se-oem-pci.html#specification
    price: PLN 95
    so I am looking for cards within PLN 50 or cheaper.
    Update # 2:
    morele.net prices start from 56 PLN
    https://www.morele.net/komputery/podzespoly-k...karty-dzwiekowe-11/,,,,,,,p,0,,7187O342358/1/
  • #2 16477668
    humbel
    Help: 84
    Rate: 198
    You can know why you decide to buy a new card?
  • #3 16477779
    dawciobiel
    Rate: 18
    If the card used will be much cheaper, the shipping costs will compensate for the difference in price between the new and used. So I don't see the point in buying a card that is often used without warranty. Well, unless used used would be personal collection. Ot the whole philosophy.
  • Affordable SpeedLink SL-8861-SRD PCI sound card suggestion
    #4 16477818
    dandi20
    Rate: 10
    I once bought a SpeedLink Stage 7.1 sound card, Logitech X-620 6.1 speakers, I'm happy and it's been a few years, but you won't get a new one, I found something like this at alledrog:
    link
    Price: PLN 37 + shipment from PLN 8.60
    As for drivers, if you have 7/8 wines then 10 will work for 99%, that's how it is with me, you have a manager and rudders. I can see on the producer's website that there are win8 rudders for this card so there should be no problem.
    Greetings
  • #6 16477842
    dandi20
    Rate: 10
    They suit me, but I won't cut my hand or it will be the same for you. I was more worried if the manager would move, but he went off the shot. As for me, the rudders should work and if, for example, the manager does not start, you can control the settings from under the system, but you can not have all the settings.
  • Windows 8 drivers should work on Windows 10
    #7 16478104
    humbel
    Help: 84
    Rate: 198
    I meant rather what caused that you decide to buy a new one. Is it broken? Integra not working? Are you looking for better sound? Do you want 7.1?
    dawciobiel wrote:
    the card has drivers for Windows 8, but will they match the same for Windows 10?
    Drivers from 8 are compatible with 10 in most cases.
  • Windows 10 installs VIA AC'97 drivers automatically
    #8 16478153
    dandi20
    Rate: 10
    I think, like a humbel, that he should fly.
    For me, the reason for buying a new card was the integrated realteka sound card. When I was still an avid player of Battledield 3 it caused the computer to freeze only with this game, somewhere on the forum I read about this problem and even played moments with the BIOS disabled.
    Later I bought a USB sound for testing, it did the trick. I wanted the sound to be better and I didn't have to switch cards manually so I bought a second SpeedLink and it's still good with 10 wines.
    Today, on another set I was putting the winde 10, some VIA chipset with the sound card still on the old AC'97 hehe win 10 installed the rudder and the manager myself, I think it's good because all the options available, icons without exclamation marks or crossings, but not anymore I connected the speakers because I was in a hurry.
  • Soldering audio cable to motherboard front-panel pins
    #9 16478557
    dawciobiel
    Rate: 18
    Why i search Well, because in one of the hosts "someone" simply bent the plates inside the mini-jack socket. Hell, they know how to get it right now so as not to break it down. That's why I decided that it would be easier to spend about PLN 50 on another (weaker) music card, but by the way do not spoil the motherboard to the rest.
    I was also thinking about USB cards, but I'm afraid that they will just buzz in the background.
    aha. one of the attempts to "fix" the situation was to connect to the pins from the front panel of the audio cable from the DVD-RW drive. And the front of the headphones. It works. But unfortunately buzzing in the background - probably a matter of grounding.
    For now, I will probably solder to the cable instead of the mini-jack socket and connect all this to the pins on the motherboard from the front panel. If it buzzs, I will buy one of the cards I mentioned or users in the replies.
  • Use rear speaker output as front channels
    #10 16478722
    dandi20
    Rate: 10
    I came up with another idea :)
    In the sound card manager you can often change the position of the speakers, if you do not use surround sound then you can move the front speakers to the back and physically connect the front to the rear speakers socket, no cost :)
    You can also buy an audio / usb front panel if you have an additional output on the motherboard to the panel and plug it in, most motherboards have this option.
  • #11 16478809
    dawciobiel
    Rate: 18
    I have already written about hooking up the front panel pins - it works.
    About changing speaker settings - I checked it some time ago, but I will check it again today.
    For this idea, the idea "if you do not use surround sound then you can move the front speakers to the back and physically connect the front to the rear speakers socket" is new to me. I'll try to experiment tonight.
The discussion revolves around the search for affordable PCI sound cards compatible with Windows 10. Users express concerns about the availability of drivers for older models, particularly the Creative Sound Blaster Audigy SE OEM, which is priced at PLN 95. Alternatives such as the SpeedLink Stage 7.1 sound card are mentioned, with prices starting around PLN 37. Users share experiences regarding driver compatibility, noting that drivers for Windows 8 often work for Windows 10. Some participants discuss the reasons for upgrading sound cards, including issues with integrated sound solutions and the desire for better audio quality. Suggestions include using USB sound cards and modifying speaker connections to optimize sound output without additional costs.
