Lenovo Tab 2a8 50L - Diagnosing Screen Rotation Issue: Accelerometer or Other Reasons
Rudder 7140 10
Why does my Lenovo Tab 2 A8-50L not rotate the screen even though auto-rotate is enabled?
If an accelerometer test app rotates correctly but the Android system does not, the accelerometer is probably working and the fault is more likely in Android/software settings than in the sensor itself [#16629427] Start with a hard reset and then install the latest firmware [#16629605] If the problem still remains, contact Lenovo support [#16631013] Lenovo support later directed the user to ctdipolska.pl, which repairs Lenovo tablets [#16631169]
  • #1 16629253
    Rudder
    Rate: 102
    Screen rotation does not work on my Lenovo Tab 2a8 50 L Tablet. How do you diagnose whether the accelerometer has broken down or what could be the reason for the screen rotation not working?
  • #2 16629255
    koala106
    Help: 471
    Rate: 1240
    Maybe you turned off auto rotation in the options?
  • #3 16629399
    Rudder
    Rate: 102
    It is enabled in the options. If it was turned off, I wouldn't ask. What could be the cause of the fault? How to diagnose a fault?
  • #4 16629423
    nutergsm
    Help: 1034
    Rate: 1663
    You need to replace it with a new one to exclude the accelerometer itself.
  • #5 16629427
    Rudder
    Rate: 102
    The problem, however, lies not in hardware but in the android settings. The accelerometer analyzer from the Google Play store rotates the screen. However, the entire android system does not rotate the screen despite the auto-rotate function enabled. What's the problem in the android settings if such an error occurs?
    If you don't prompt, I will have to call the android company.
  • #6 16629605
    nutergsm
    Help: 1034
    Rate: 1663
    Start with a hardset. You can still upload the latest firmware.
  • #7 16629841
    Rudder
    Rate: 102
    Hardreser made but screen still not rotating
    Latest software uploaded
    How do you make the screen rotate by itself?
    Added after 17 [hours] 9 [minutes]:
    Okay, I understand you don't know why this error occurs. That's why I would like to ask you the phone number for android technical support or contact us for remote support.
  • #8 16631013
    nutergsm
    Help: 1034
    Rate: 1663
    Write to Lenovo support.
  • #9 16631022
    Rudder
    Rate: 102
    Give us a good bearing for this support in Polish so that he doesn't write to someone else.
  • #10 16631025
    nutergsm
    Help: 1034
    Rate: 1663
    Go to the Lenovo website and you have everything there.
  • #11 16631169
    Rudder
    Rate: 102
    I have been corrected by Lenovo technical support to the company www.ctdipolska.pl which repairs Lenovo tablets
✨ The discussion revolves around diagnosing a screen rotation issue on the Lenovo Tab 2a8 50L tablet. The user initially checks if the auto-rotation feature is enabled, which it is. Suggestions include replacing the accelerometer to rule it out as the cause, but the user believes the problem lies within the Android settings. They mention that an accelerometer analyzer app can rotate the screen, indicating a software issue. Recommendations include performing a hard reset and updating the firmware, but these actions do not resolve the problem. The user expresses frustration and seeks contact information for Android technical support, leading to suggestions to reach out to Lenovo support or a specific repair service in Poland.
