[Solved] Lenovo Yoga TAB 3 LTE YT3-X50L - How to dial a number on your tablet
fonexpl 10104 9
Can I dial a phone number or service code from a Lenovo Yoga Tab 3 LTE YT3-X50L tablet that has no phone app?
No, the stock software on this tablet version does not let you make calls or dial service codes. One reply says that in this software version you cannot call at all [#17702683] The only workarounds mentioned are to flash the YT3-X50M firmware, which adds calling and SMS functions, or—if the tablet is rooted—to install a dialer APK from the Play Store [#16838128] A separate reply also notes that the Contacts-to-phone-number call method applies to the YT3-X50M only [#16836985]
  • #1 16829568
    fonexpl
    Level 4  
    Rate: 68
    I have a tablet with a theme. The tablet has a built-in application for sending SMS / MMS. There is nowhere a phone application to dial. Is it possible to dial a number from this tablet? I don't mean talking anymore, but I want to enter the service code to run the internet package. Am I forced to pull the card out, put it on the phone, start the service and then move it again?
  • #2 16831808
    Freddy
    Help: 1394
    Rate: 2821
    The exact type is ZA0H, ZA0J, ZXA0K.
    What is the very good support on the producer's website?
  • #3 16836399
    fonexpl
    Level 4  
    Rate: 68
    The exact model is: ZA0J
  • #4 16836985
    Freddy
    Help: 1394
    Rate: 2821
    NOTE: This topic applies to Lenovo YT3-X50M only.
    Go to Contacts, choose a name, and then tap the phone number,
    to connect.
    Try it, maybe it will work for you too. :)
  • YT3-X50M ROM enables calling and SMS
    #5 16838128
    koala106
    Help: 471
    Rate: 1240
    It will not work - advice without sense.
    Two methods - changing the software to a soft one from the YT3-X50M model - there will be functions for calling and sending sms - minus is the lack of a Polish menu (you can polish with an overlay) and no gapps - although for me it is an advantage :) ROM from YT3-X50M is much faster - I installed on two pieces and it flies.
    The second method - if you have root should be flickering - downloading from the app's apk dialer - is from the thunder in the play store - on some tablets without a phone app it worked for me.
  • #6 16838656
    Freddy
    Help: 1394
    Rate: 2821
    You tried? Probably not, and this is not harmful advice.
    It is not known exactly how the tablet will behave after uploading a foreign (YT3-50M), not dedicated software.
    Will everything work fine?
  • #7 16838670
    koala106
    Help: 471
    Rate: 1240
    Yes - I tried - I had to do two such tablets. Tablets with L and M tips are identical - only different regions and, as a consequence, different soft.
  • #8 16838690
    Freddy
    Help: 1394
    Rate: 2821
    Well that's OK - I didn't have the M version on the table, that's why I asked.
    Therefore, I could not compare the PCB after opening.
  • #9 17585566
    chorichori
    You can write how to upload soft from version M
    best regards
    Added after 4 [minutes]:
    Because I tried QcomDLoader with soft from M but I do not want to start and I have no idea and I do as in the instructions https://androidmtk.com/use-lenovo-downloader-tool
  • #10 17702683
    fonexpl
    Level 4  
    Rate: 68
    Well, unfortunately, you can't call in this version of the tablet's software.
The discussion revolves around the Lenovo Yoga TAB 3 LTE YT3-X50L and the user's inquiry about dialing a number to enter a service code for an internet package. The tablet lacks a native phone application for dialing, leading to suggestions for alternative methods. One proposed solution involves changing the software to that of the YT3-X50M model, which includes calling and SMS functionalities, albeit with a Polish language limitation. Another suggestion is to root the tablet and install a third-party dialer app from the Play Store. Users express concerns about the risks of using non-dedicated software and share experiences with software modifications. Ultimately, it is confirmed that the current software version does not support calling.
