Turning Off Store Demo Mode on Lenovo Yoga Tab 3: Experiencing Persistent Issue
wania326 6072 5
  • #1 16402184
    wania326
    Hello, I have a Lenovo Yoga tab 3. The problem is that I cannot turn off the demo version (store demo). After the screen goes blank, the tablet goes into this mode immediately.
  • #2 16402381
    Foxtrott
    Help: 253
    Rate: 944
    See Personalization - Screen Saver - Blank Screen
  • #3 16402768
    wania326
    There is nothing like that, you can't do it in the menu ... I know that in the Sony brand, it goes to do it with a code.
  • #4 16403889
    Foxtrott
    Help: 253
    Rate: 944
    Sony is * # * # 73556673 # * # *, if you still have a "fresh" tablet, do a factory reset, check in the applications if you have a Demo - uninstall, as a last resort, upload a new soft from the manufacturer's website, it will definitely be without "garbage".
    Display -> Wallpaper-> Live wallpapers (and or Screen saver)
  • #5 16403951
    wania326
    I have Lenovo not Sony. Uninstalling the application does not work, no permissions, reset does not do anything. The Lenovo technical department also knows shit about it ... I guess I only have root ....
  • #6 16405572
    Foxtrott
    Help: 253
    Rate: 944
    I know you don't have Sony = info for others with a similar problem.
    Reload the system from the manufacturer's website, unless you need root.
