Nissan Micra K12 - Tailgate Battery Discharge, Boot Lock Issue, Fuse & Possible Causes
COBRA-C3 8007 5
  • #1 16632162
    COBRA-C3
    I have a problem with the boot lock. It used to be able to open while driving, now it is ok, the microstatic works correctly, ie on the meters, it closes the circuit after switching on. Now the problem is in a discharged battery after a few days.
    Where to look for the cause? Which fuse is from the rear lock?
    I am asking for help, and maybe the problem lies elsewhere?
  • #2 16632214
  • #3 16632250
    alien8_6
    What is the consumption after locking the car?
    The batteries in the k12 were not of quality and reliability if it is original.
  • #4 16634610
    COBRA-C3
    The battery is now 3 years old since it was purchased 4 years ago. Or maybe there is a fuse from the central and remove it? Then how will not discharge the battery. Ie. That's the problem. And what could be the beard contacts option? I take measurements overnight when it comes to the current of a standing car.
  • #5 16634638
  • #6 16634651
    Gamlling
    I would check the charging current from the alternator to exclude the electronics 100%. Perhaps the battery is just too weak.
