[Solved] Automatic Boot Lid Issue & Solutions for Nissan Qashqai 07: Timers, Modules, & More!
pgcolin 20193 3
  • #1 17256500
    pgcolin
    Hello to all forum users!
    I would ask for help very much. I already explain what's going on:
    first I will paste a video on youtube so that you can see exactly what and how, time of the movie just 14 sec:
    I will just add that in some models it can be set in the vehicle comfort module, but not in mine and not in cars with comfort modules from France from 2007, module replacement is not an option due to the costs, so I advise you to enable the function in the above module or buy newer, thank you.
    I saw a forum member post elkard in this topic on elektroda.pl:
    https://www.elektroda.pl/rtvforum/topic1642396.html#7968673
    it seems to me that this problem would be partly solved, but partly. Anyway, for me it is more arduous to present the whole scheme immediately with the timer preferably ne555 because I have a few such systems at home :)
    I admit that I made this layout and the relay was on all the time; (, made without Timer but it didn't work anyway, I must have done something wrong.
    so what I mean exactly after seeing this video and topic above is:
    as a standard, after 1 pressing the remote control the door opens and the luggage compartment unlocks / a short 12V signal / and now I would like the system that after opening the door within 5 sec press the opening button again at this moment the speaker would turn on / as ready as for reversing / and after 2 pressing would start counting to 10 sec during this time I would have to press the button 3 times and then the signal would go to the relay that would work for example 2 sec / the relay would short-circuit 2 wires in the trunk lid / connecting the contactor for opening the manual damper via the micro built-in contact in the factory lock - link below in the Nissan forum and the opening itself also described in this forum more powerful cylinders + springs /
    Then, if after 1 pressing the opening within 5 sec I do not press the opening button again, the system resets and you need to press from the beginning the same after 2 pressing / only the buzzer described above will start beeping / if I do not press 3 once within 10 sec, the whole will be reset and you will have to start the procedure again.
    I reached the man from the movie, he claims that this system for 25 zlotys was made to him by some electronics but now he does not have this car to take pictures of this system and he has no contact with the said electronics only described the operation of this system and I described it to you above .
    The exact description I found here on the Nissan forum is almost exactly what I mean only there is control via radiolonia and an additional remote control and for me to work as it is described there except for control from my remote control system should be triggered after electrical impulsesand not radio from another remote control / if someone asks why I will answer that I already look like a keyman and a couple of remote controls I take with me ;) :
    author of the thread Tutorial Michalmiko / there is everything described mechanical and electronic solutions with photos and diagrams /.
    http://forum.nissanklub.pl/topic/103260-tutorial-zdalne-otwieranie-klapy-bagażnika
    For quick help in advance, Thank you very much.
  • #2 17256702
    Jacko29
    Rate: 8
    To be honest I would be interested in such a conversion myself, Chinese products are hardly an option ... they rarely work
  • #4 17793215
    pgcolin
    I bought the system from a friend IMEX, it works great. Regards.
