Samsung J5 - SD Card Not Detected: Troubleshooting & Solutions After Quick Format & Restoration
rafal5518 12141 3
  • #1 16638590
    rafal5518
    Rate: 10
    Hello. After inserting the memory card into the phone, I turn on the phone, further settings / memory and there is no SD card displayed just what it was. The computer sees the memory card when I connected it with a USB reader. I have marked "restore default capacity" and made a quick format. The phone still can not see the card. I am asking for advice.
  • #2 16638671
    brofran
    Help: 650
    Rate: 1406
    Visibly damaged SD slot, or the chip responsible for them. Does the card work on the computer or is it only detected?
  • #3 16638775
    rafal5518
    Rate: 10
    The first attempt to open was a problem, then I took it out of the reader and put it in again and opened it without a problem and copied two files for checking. I was inserting the card into another phone and it was visible.
  • #4 16638797
    brofran
    Help: 650
    Rate: 1406
    If it works in another phoneme, then yours has an SD input. :cry:
