Connection of TP-Link TLMR3420 router with INEA modem (Nokia G-241W-A) no wifi.
frantz1988 8355 10
How do I configure a TP-Link TL-MR3420 to work behind a Nokia G-241W-A modem so the router gets internet?
Set the TP-Link to Wireless Router mode and choose Only WAN; with the modem connected to the TP-Link WAN port, the internet should work. [#16643251][#16643284] The modem can stay connected to the router’s WAN port, and it may help to reboot the ISP modem after connecting the TP-Link while leaving the TP-Link connected. [#16643239] In the thread, this single setting change was enough and internet started working immediately. [#16643302]
  • #1 16643159
    frantz1988
    I will start with the fact that I did not purchase the Inea wifi service through their modem (I need to connect the modem to my router). The internet works over a cable connected to the modem, but it doesn't work when connected through a router (as if the modem was not communicating with the router). I checked and all ports were well connected, I restarted the modem. I also called INEA and they gave me information that the problem may be in the router configuration. I currently have cameras connected to the router (they are still working on the previous configuration), I have already tried to change its settings, but unfortunately there is still no internet connection. Please help. What screenshots should I make and throw, what information should I give you help me diagnose where the problem lies. Below I upload photos of the router and modem in question.
    Connection of TP-Link TLMR3420 router with INEA modem (Nokia G-241W-A) no wifi. Connection of TP-Link TLMR3420 router with INEA modem (Nokia G-241W-A) no wifi. Connection of TP-Link TLMR3420 router with INEA modem (Nokia G-241W-A) no wifi. Connection of TP-Link TLMR3420 router with INEA modem (Nokia G-241W-A) no wifi.
  • #2 16643173
    jimasek
    Help: 3783
    Rate: 2681
    frantz1988 wrote:
    however, it does not work when connected through a router (as if the modem was not communicating with the router).
    How do you connect devices (which ports)? Do you have Internet access on your Nokia modem on all Ethernet ports?
  • #3 16643189
    frantz1988
    When I connect to a computer via cable, I have internet on the first port. As for the modem and router connection, modem (port 1) to the router (I tried the WAN port according to the instructions and port 1).
  • #4 16643197
    jimasek
    Help: 3783
    Rate: 2681
    The diode on the TP-link responsible for the port lights up after connecting the cable from the modem? What IP address do you get from the modem after connecting the computer?
  • #5 16643237
    frantz1988
    When I connect the router to the modem, the LED lights up green.
    IPv4 address: 100.68.225.238
    IPv4 DNS servers: 62.21.99.94
    62.21.99.95
    Producer: Realtek
    Description: Realtek PCIe GBE Family Controller
    Driver version: 9.1.406.2015
    Physical address (MAC): 08-62-66-06-59-CD
  • #6 16643239
    jimasek
    Help: 3783
    Rate: 2681
    Connect the modem to the TP-LINK WAN port and show the Status tab from the TP-LINK or something appears there in the WAN address. Do the current reset of the supplier's modem after connecting to TP-Link. Leave your TP-link connected at all times.
  • #7 16643250
    frantz1988
    this is how it looks before restarting the modem from the provider
    after restart
  • #8 16643251
    jimasek
    Help: 3783
    Rate: 2681
    The router must be set to Wireless Router (operation mode).
  • #9 16643277
    frantz1988
    option 3 here
    at the moment I have cameras connected to the router (work offline) and I would like to configure it so that it both sends a wifi signal and that the cameras can work (Indoor Securcam MT4050 mediatechu)
    jimasek
    Help: 3783
    Rate: 2681
    Set Only WAN.
  • #11 16643302
    frantz1988
    There is internet :) Thank you for helping Jim. One click was enough, but I would probably circulate in options for so long that in the end I would dig too much. Subject to close.
The discussion revolves around connecting a TP-Link TLMR3420 router to an INEA modem (Nokia G-241W-A) to enable Wi-Fi access. The user reports that while the modem provides internet through a direct cable connection, it fails to communicate with the router. After troubleshooting steps, including checking port connections and restarting the modem, the user receives advice on configuring the router settings. Key recommendations include ensuring the router is set to Wireless Router mode and connecting the modem to the TP-Link WAN port. Ultimately, the user successfully establishes an internet connection by adjusting the router settings to "Only WAN."
