Inea Agreement: Using Asus RT-N16 with Tomato Firmware & Compatible Optical Modem with TV Output
Tal-Rash 4089 2
  • #1 16272151
    Tal-Rash
    Rate: 50
    I am moving and in the new place I will have internet with TV provided by INEA.
    I received an Alcatel-Lucent G-241W-A wifi router from them
    I would prefer to use my own router on which I have tomato (asus rt-n16)
    But it's not that simple because Alcatel has a TV output and an optical modem.
    Does anyone know if I could buy, for example, an optical modem with a TV output to which I would connect the TV and my router and could work like that?
    Am I stuck with this unknown device?
  • #2 16272309
    jimasek
    Help: 3783
    Rate: 2681
    The provider's modem must remain in place. What you connect to it is up to you.
  • #3 16272318
    Tal-Rash
    Rate: 50
    This is a terrible bowel because it is probably impossible to switch the provider's router into bridge or "modem only" mode and use your own router.
    ---EDITION---
    I found. The router can work in BRIDGE mode. You can turn it on in the settings. So I connect it in this mode to my router and that's it.
