Wireless Door Opening Sensor: Reed Switch + Siren for Store Security, 15m Range, Budget Options
Jacek_P. 3735 6
  • #1 16644997
    Jacek_P.
    Rate: 8
    I ask my colleagues for help in choosing equipment that will meet my expectations.
    Namely, I need something like a wireless reed switch with a siren. More precisely, I would like to mount the equipment in the store because there are cases that when a saleswoman goes to the back of the store someone enters and individual pieces of percentage drinks die :-)
    Pulling the wires to the door is unlikely. That's why I'm looking for a set that would consist of a wireless reed switch mounted on the front door and a siren that would be placed in the back room that would signal the entrance to the store. The distance between the siren and the door is about 15 meters. I can easily draw power to the siren. The reed switch is the problem.
    I realized that all control panels have such a function, but to be honest, invest a minimum of PLN 1000 for such a purpose to use only this function is a bit much so I am looking for a cheaper solution.
    I would be very grateful for your help :-)
  • #2 16645035
    czareqpl
    Help: 196
    Rate: 580
    Look for a single-channel remote control.
    Reed switch you can buy separately.
    Essentially, the remote control button should be short-circuited when the door is opened.
  • #4 16645147
    bhtom
    Help: 446
    Rate: 604
    In addition to the reed switch, I would think of a motion detector. The reed switch itself may not pass the exam, it is enough that one person does not close the door and the other one enters without violating the reed switch. Read about sensors from the Elmes offer:
    http://www.elmes.pl/pl/kategorie-produktow/detekty and the receiver from their offer and a sounder with volume control, e.g. https://www.itchome.pl/sawa-2r-sygnalizator- internal-acoustic-adjustable-p-2816.html
    Of course, you will need a power supply.
    Greetings.
  • #5 16686406
    fad
    Rate: 28
    I will stick to the topic with a small question. It's also about the basement. Will I find such an alarm kit with at least one entrance to which a door contact would be connected. Alarm without any siren, only notification via GSM on phone. I have AC 230V in the room. Preferably something in the range up to approx. PLN 200.
  • #6 16686458
    Zbigniew 400
    Help: 283
    Rate: 794
    Visitor chime. Look for.
  • #7 16686470
    fad
    Rate: 28
    As much as I noticed that this device is with a motion sensor, I would like it on a reed switch. Secondly, it has a gong, and I don't want any sounds in the basement just a phone notification. And I didn't find a device with a GSM module.
    What about the Satlink VS-GSM10AB set? I know it's Chinese but is it worth anything? Or maybe something better type ELMES CB32 + reed switch?
The discussion revolves around finding a budget-friendly wireless door opening sensor solution for store security, specifically a wireless reed switch paired with a siren. The user seeks a setup that can be installed without running wires, with a range of approximately 15 meters between the door and the siren. Suggestions include using a single-channel remote control with a separate reed switch, input beacon devices with PIR detectors, and considering motion detectors as alternatives. Brands like Elmes and Eura-Tech are mentioned, along with specific products such as the Elmes sensors and the Eura-Tech input beacon. The conversation also touches on the need for a GSM notification system without a siren, with inquiries about the Satlink VS-GSM10AB set and ELMES CB32.
