Choosing a Wireless Alarm System: 5 Detectors, SMS Notifications, No Fakes, & Webcam Option
zegnallo 9063 19
What wireless alarm system should I choose for a 5-detector apartment setup with SMS alerts, low false alarms, and possible future webcam integration?
The thread points you toward a branded wireless alarm such as Satel Perfecta WRL; if your budget is higher, Versa + ABAX is another option, and the same reply also names Jablotron and DSC Alexor as comparable systems [#17286285] Other wireless platforms mentioned are Ropam with Aero, Genevo with Evolink, and EBS CALLISTO / MW Power CG-7P9W [#17294126] The key selection criteria are the radio band used and whether device communication is one-way or two-way, because that affects reliability and how the system handles lost communication or interference [#17286285] If you consider Ropam, note that NeoGSM is being phased out and its successor is NeoGSM-IP-PS, which adds Wi‑Fi and widgets but works only with the newer LCD keypads TPR-4, TPR-4WS, or TK-3 [#17300758]
  • #1 17284205
    zegnallo
    Rate: 9
    I am looking for an alarm with wireless detectors for an apartment in a block of flats.
    Number of detectors needed - 5 pcs.
    It's nice to send SMS notifications. I also want it not to generate fakes.
    A nice option in the future would be to expand it with a webcam to keep track of what is happening at home in your absence.
    For example, I found something like this but I don't know if this set is ok
    http://allegro.pl/ShowItem2.php?item=7350657373
  • #2 17285904
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    Sorry, but you won't find Chinese toy enthusiasts in this forum.
    I will not promote any of the companies so I will write this:
    Look for something invented in Poland, the Czech Republic, Canada or already from poverty in Israel (order not accidental) Only not in China, if you do not want to get upset later.
    tomaszns
    Help: 7
    Rate: 17
    Take an interest in Satel Perfecta WRL, if the budget is bigger, for example Versa + ABAX, from our backyard you also have Czech Jablotron and Canadian DSC Alexor. Read and you will definitely choose something, mainly be interested in communication how it takes place between devices (on what band) and whether the communication is one-way or two-way.
  • #5 17286405
    zegnallo
    Rate: 9
    Thanks for the answer. I will read about it all.
    Well, the budget is a bit cut and I do not know if I will decide on one or two detectors and will expand the set with time.
  • #6 17294126
    raffin
    Help: 86
    Rate: 109
    There is also Ropam (with Aero), Genevo (with Evolink), EBS CALLISTO (CPX220NWB) / MW Power CG-7P9W
  • #7 17298197
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    And I'll add Visonic but the price kills!
    OMNI-SAT
    WP 11, Wołów, 56-100 | Company Website: www.omnisat.pl
  • #8 17299253
    zegnallo
    Rate: 9
    Thanks, gentlemen, for the hints.
    I am thinking of such a set if the budget allows:
    1x Ropam NeoGSM PS alarm control panel
    1x Ropam TPR-2 LCD touchpad (white / graphite)
    2x indoor wireless Smart PIR Aero detector
    1x loud acoustic-optical siren SL-550
    1x metal case for the control panel
    1x 7Ah / 12V backup battery
    1x APm-Aero wireless device module
    1x AT-GSM-MAG antenna
    be a little truncated like this:
    1x Ropam TPR-2 LCD touch keypad
    1x Paradox PRO + indoor PIR detector
    What do you think about it?
  • #9 17300758
    raffin
    Help: 86
    Rate: 109
    Kits OK.
    NeoGSM - it "ends" its life, exists on the market while stocks last. Although this switch is not bad at all.
    Currently, the successor of that control panel is NeoGSM-IP-PS, much better, with wifi communication, widgets ..., a bit more expensive, works only with new LCDs (TPR-4 (capacitive), TPR-4WS (resistive), TK- 3 (zone / only numbers)) and has just been sold.
  • #10 17301411
    zegnallo
    Rate: 9
    Tell me what is better to choose and whether there is a big difference between the Smart PIR Aero detector and the PIR Paradox PRO + detector
  • #11 17301618
    tomaszns
    Help: 7
    Rate: 17
    The Aero detector is wireless but the Paradox is not ;) . In the first post you indicated that you need wireless.
  • #12 17301644
    zegnallo
    Rate: 9
    Sorry, sorry my oversight
  • #13 17954558
    stachu_18
    Rate: 18
    This Satel counts beautifully for a piece of printed circuit board for Satel Perfecta WRL - PLN 350. Forgive me above, gentlemen, but I chose CHINESE EQUIPMENT for 400 PLN and I am satisfied with it / it works flawlessly.
    It's nice that you promote domestic brands, but from the consumer's point of view it is not justified, because it is simply overpaying.
    And SATEL is far behind Negroes in terms of available amenities and functions. Buy a switchboard, buy a GSM module, buy a module blah blah blah.
    It's cool, how are you doing it on a job, it's ok, because you know, Polish warranty, service and the CUSTOMER pays, but privately? No.
  • #14 17954823
    kood
    CCTV and Stationary Alarms specialist
    Help: 259
    Rate: 443
    stachu_18 wrote:
    but I chose CHINESE EQUIPMENT for PLN 400 set and I am satisfied with it / it works flawlessly.
    We will ask for information on what frequency the transmission takes place, whether it is bi-directional, what the system will do when jamming occurs, what it will do when for some reason the detector stops working or loses communication with the control panel, what with emergency power, what battery capacity, what operating time on the emergency power supply, whether the control panel, detectors, sirens, keypad are protected against tampering.
    We will ask for these functions and amenities, unless the point is that the correct installation of the control panel requires much more from the installer than putting up a dummy in the form of a Chinese toy.
  • #15 17954853
    xury
    Help: 878
    Rate: 1498
    In the "control panel and keyboard in one" type, it is necessary to consider whether it will be able to signal something after intrusion into the facility.
  • #16 17955050
    alster1
    Help: 352
    Rate: 540
    @kood @yszne that you want too. After all, Chinese for PLN 400 is the best, and what to discuss here.
  • #17 17955877
    sosarek
    Help: 9320
    Rate: 15542
    Maybe hide with your theories - in a minute this "Mega super hyper system" will drown out and take everything away - you have no idea about systems, you assigned to the installation thinking that you are clever and you will lose a lot more, and probably the control panel built into the keyboard 0 I wonder what he will say to a hammer blow?
    Z
    Pka, Poznań, 60-850
  • #18 17957863
    wexors
    Level 19  
    Help: 22
    Rate: 40
    will not say anything because to whom? rather, there is no notification module in this miracle of technology.
  • #19 17957916
    suworow
    Help: 650
    Rate: 1278
    And why not. You think it throws stones at the windows in the event of an alarm. At this price, you have full blast. Only - as colleagues have already noticed - on duck feet. Only who would care there ;)
    In alarm room, that's how it is. You can press various kits. "Control" comes in quite rarely ;)
  • #20 17957959
    marek216
    Help: 1077
    Rate: 932
    See, and I retard thought that when you do it for yourself, you do the best you can.
    And now a few words about the set from the first post.
    - 24h standby time
    - the most popular frequency is 433MHz
    - no two-way communication
    - no certificates for the control panel
    - no attestations for sensors
    I like it:
    Notifies by phone about the alarm even after the funds on the SIM card are exhausted - the control panel calls at the recipient's expense.
    Only the operator must give this option.
    RF noise immunity: 10MHz-1GHz at a field strength of 20V / m
    Space technology - I bet the coins against the nuts that I will jam it with any kind of jammer.
    And the icing on the cake is the battery for the remote control: 6F22 - no options, I have such remotes for the car. The seller does not know what he is selling.
The discussion revolves around selecting a wireless alarm system suitable for an apartment, emphasizing the need for five detectors, SMS notifications, and the potential for future webcam integration. Participants recommend avoiding Chinese brands and suggest looking into local options from Poland, the Czech Republic, and Canada. Notable brands mentioned include Satel, Ropam, Jablotron, and DSC. Specific models discussed include Satel Perfecta WRL, Ropam NeoGSM PS, and various detectors like Smart PIR Aero and Paradox PRO. Key considerations include communication methods between devices, the reliability of the system, and the ability to expand the setup over time.
TL;DR: Most cheap 433 MHz kits claim 24h standby, and "no two-way communication" undermines reliability; choose certified wireless systems for SMS and future IP camera support. [Elektroda, marek216, post #17957959]
Why it matters: Flat owners who want five wireless detectors, SMS alerts, and low false alarms can avoid toy kits and plan clean upgrades.
What wireless alarm brands should I shortlist for a flat?
Installers recommend Satel Perfecta WRL or Versa with ABAX, Czech Jablotron, and Canadian DSC Alexor. Focus on radio specifics, not just price. Verify the operating band and whether communication is one- or two-way. These families support wireless peripherals and expansion paths. Match the platform to your layout and your need for SMS alerts. [Elektroda, tomaszns, post #17286285]
Is a 433 MHz, one-way kit with 24h standby a good idea?
For security, it is a weak choice. Such kits often lack certificates and supervision. They can be easy to jam, leaving you unaware. A standby of only 24h limits resilience during outages. Some even use 6F22 batteries in remotes. As one expert listed: "no two-way communication." [Elektroda, marek216, post #17957959]
What’s the difference between Ropam Smart PIR Aero and Paradox PRO+?
Smart PIR Aero is a wireless motion detector. Paradox PRO+ is a wired PIR. If you require wireless detectors, choose the Aero line. This aligns with the original wireless requirement. [Elektroda, tomaszns, post #17301618]
Is the Ropam NeoGSM PS still current, or should I get NeoGSM‑IP‑PS?
NeoGSM‑PS is nearing end-of-life and sells while stocks last. The successor, NeoGSM‑IP‑PS, adds Wi‑Fi, widgets, and new LCDs (TPR‑4, TPR‑4WS, TK‑3). It costs more but improves communication and usability. As one pro notes, it "ends" its life. [Elektroda, raffin, post #17300758]
What should I check about wireless communication to avoid gaps?
Demand clarity on fundamentals. Ask the radio frequency and whether it’s bidirectional. Ask "what the system will do when jamming occurs." Confirm what happens if a detector stops or loses communication. Verify emergency power, battery capacity, and backup runtime. Ensure tamper protection on panel, detectors, sirens, and keypad. [Elektroda, kood, post #17954823]
Will an all‑in‑one keypad+panel protect me if intruders smash it?
In keypad+panel combos, consider whether it can signal anything after intrusion. If an intruder neutralizes the keypad, you may lose alarms. Ask this explicitly before buying. [Elektroda, xury, post #17954853]
Can the system notify me by SMS if my SIM card has no credit?
Some kits claim to notify by calling at the recipient’s expense. That only works if your mobile operator supports this feature. Confirm with your operator before relying on it. [Elektroda, marek216, post #17957959]
What components make a solid starter kit?
A practical list: Ropam NeoGSM‑PS control panel, one TPR‑2 LCD keypad, indoor wireless Smart PIR Aero detectors, an SL‑550 acoustic‑optical siren, a metal enclosure, one 7Ah/12V backup battery, an APm‑Aero wireless module, and an AT‑GSM‑MAG antenna. This covers control, detection, power, and signaling. [Elektroda, zegnallo, post #17299253]
Are there other reputable non‑Chinese systems to consider?
Yes. Consider Ropam with Aero wireless, Genevo with Evolink, and EBS CALLISTO (CPX220NWB). MW Power CG‑7P9W appears in related kit discussions. Use these as a shortlist when comparing reliability and support. [Elektroda, raffin, post #17294126]
Is Visonic worth considering despite price?
Visonic is an option in wireless alarms, but pricing can be high. As one installer put it, "the price kills!" Choose it if your budget allows and you want premium features. [Elektroda, Fotodetektor, post #17298197]
How do I choose a wireless alarm in 3 steps?
  1. Verify the radio band and confirm two‑way communication.
  2. Shortlist platforms like Satel, Jablotron, DSC, or a Satel Versa with ABAX.
  3. Map detector zones, then pick the keypad and modules to match. [Elektroda, tomaszns, post #17286285]
Does two‑way communication really matter for detector health checks?
Yes. Installers explicitly advise verifying one‑way vs two‑way communication. Two‑way links enable supervision and reduce silent failures. One‑way links cannot confirm device status in real time. [Elektroda, tomaszns, post #17286285]
Are China‑made kits always a bad idea?
Forum pros advise against them for reliability and service reasons. "Look for something invented in Poland, the Czech Republic, Canada or already from poverty in Israel." This steers buyers toward supported regional brands. [Elektroda, xury, post #17285904]
What do pros criticize about cheap all‑in‑one “toy” systems?
They flag missing essentials: unspecified frequency, no bidirectional radio, and unclear jamming response. They ask what happens if a detector stops or loses communication. They also question backup capacity, runtime, and tamper protection for all devices. "We will ask for information on what frequency the transmission takes place." [Elektroda, kood, post #17954823]
Can I add a webcam/IP camera later for visual checks?
Yes, plan for a panel with Wi‑Fi to support modern remote features. The NeoGSM‑IP‑PS adds Wi‑Fi and updated interfaces. For video, add IP cameras separately and align app workflows. Integration specifics vary by vendor and app. [Elektroda, raffin, post #17300758]
