[Solved] Opening the wicket to the garden - electric door opener - remote and direct opening
jenot666 3375 4
  • Wireless key fob and direct gate opener selection
    #1 19367622
    jenot666
    Good afternoon,
    I'm new to the forum and a slight layman in my knowledge of electro-hook control.
    I am in the process of building a new fence, unfortunately I don't have the house connection to the fence (cable) brought in to use a wired intercom, and the elevation is already done so there is no chance of ripping up the walls. I have power outside directly from the box.
    I would like to solve the problem by using a wireless key fob to open the wicket (in case someone comes in) and a key fob to open both sides of the wicket when entering/exiting directly.
    Can I ask for help in selecting devices so that this has arms and legs?
    Regards Kacper
    Visitor signaling method for gate opening
    #2 19368589
    Ircys
    Intercoms specialist
    Help: 1342
    Rate: 2085
    You need:
    1. electric door strike e.g. http://www.bira.pl/produkty/elektrozaczepy-standardowe/bira-seria-es1,p872220876
    2. 12V DC power supply e.g. https://www.pulsar.pl/PL_386_PSC12015_psc-12v,1,5a,66mm-zasilacz-impulsowy
    3. an RFID reader e.g. https://www.roger.pl/pl/kontrola-dostepu/syst...j/prt62em-czytnik-zblizeniowy-em-125-khz.html
    It is best to mount it so that it is accessible from either side so as not to multiply the hardware.
    4. a radio station e.g. http://www.elmes.pl/pl/produkty/odbiornik-1-kanalowy-dwa-piloty-1-przyciskowe-zasilanie-12vdc
    5 RFID key fobs
    6. hardware
    Have you thought through how (with what) the visitor should signal that he is standing in front of the gate and it needs to be opened for him (stone in the glass, wireless bell)?
    Greetings
  • #3 19368830
    jenot666
    Thank you for your reply and choice of equipment.
    Stone damage to the windows of course ;) wireless battery operated button and in house bell for 230V contact.
    Will such a scheme (handwritten) work when connected? As for the key fob module, I will actually reduce to 1 in the space between the wicket so as not to generate costs and connections.
    Regards
    • Opening the wicket to the garden - electric door opener - remote and direct opening 170083972_3842358299163226_3173591642927734738_n.jpg (342.68 KB) You must be logged in to download this attachment.
    Ircys
    Help: 1342
    Rate: 2085
    Terribly messed up and you can't actually see from this how you want to power the electric door opener. I'd suggest you draw out just how to switch on the electric door opener without powering the reader and radio, because I think you're getting lost here.
    Regards
  • #5 19492595
    jenot666
    my scheme has worked. Thank you for your help. Closing.
