Air Bag or Pretensioner Seat Belts Faulty Message on Peugeot 407: Experiences?
Maudi93 10800 7
  • #1 16647628
    Maudi93
    Some time ago I bought a Peugeot 407, I get the message airbags or pretensioner seat belts faulty, I have already checked under the plug seats, I started but nothing disappears ...
    I moved with the seat belt fastened but also nothing disappears, and on the OBD) the computer displays nothing with an error.
    Did any of you have a similar situation?
  • #2 16647959
  • #3 16647984
    Maudi93
    Maybe I put it wrong at the beginning of the topic.
    I get a message on the AIRBAG display in the triangle.
    Now what can I do to make it disappear? I pressed the plugs under the seats, checked the belts but nothing helped.
    I meant to the computer that when I connected to VAG I missed that word. in Vag there is no error and it appears on the display.
  • #4 16648273
    zubereq
    Help: 13
    Rate: 89
    Vagiem is not diagnosed with Peugeot, first and secondly, come to someone who has Peugeot Planet and will check you exactly where the problem lies.
  • #5 16648364
    andrzej20001
    Help: 1578
    Rate: 6669
    Pressing gives nothing. You may as well have a tape in COM. Diagnostics only with a tester, not an iron.
  • #6 20581359
    ireneuszkujawa75
    Can't get any specific answer here.
  • #7 20581361
    DiZMar
    Help: 2892
    Rate: 6652
    After almost 6 years, you woke up on a topic not yours?
  • #8 20581397
    m fox
    Help: 92
    Rate: 236
    Post #4 and #5 gave you the exact answer.
The discussion revolves around a Peugeot 407 displaying a message indicating faulty airbags or pretensioner seat belts. The user has checked the seat plugs and fastened the seat belt, but the warning persists without any error codes appearing on the OBD system. Responses suggest that the issue may require specialized diagnostics using Peugeot Planet, as generic tools like VAG may not provide accurate results. The importance of using the correct diagnostic equipment is emphasized, with some users expressing frustration over the lack of specific solutions in the thread.
