Zonda Tracer Steering Wheel Not Functioning in Forza Horizon 3 - Suggestions?
Renger13 17667 7
  • #1 16650766
    Renger13
    I have Zonda tracer handlebars but it doesn't work in forza horizon 3 could anyone help me?
  • #3 17477144
    lastlimit
    Rate: 8
    YOU HAVE A DRIVER HERE
    KIEROWNICA... Zonda.rar (1.48 MB)You must be logged in to download this attachment.
    THIS PROGRAM CAN CALIBRATE KAZDY KONTROLER SA 2 VER
    DXTweak2_v...02.144.rar (145.8 kB)You must be logged in to download this attachment.
    DXTweak2_v...30.229.rar (28.76 kB)You must be logged in to download this attachment.
    it is important not to install another driver by mistake, e.g. drifter or Sierra, then there is a problem with the pedals instead of having them on the y-axis are on slide 1
    then you need to restore the system to the default driver without vibrations
    this looks correct Zonda Tracer Steering Wheel Not Functioning in Forza Horizon 3 - Suggestions?
    And yes the one that does not work properly
    I play zonda tracer on ps4 through cronuxmax in gt 6 and for this price is sensational I bought used for 80 zlotys on olx as I read with sit for anything etc. I owe those people who can't
    suit this steering wheel well.
  • #6 17492979
    lastlimit
    Rate: 8
    Well, I forgot to add that we also need cronuxmax https://cronusmax.com/manual/forza_horizon_3.htm Zonda Tracer Steering Wheel Not Functioning in Forza Horizon 3 - Suggestions? .
    We plug the device into our pc or ps4 or xbox, on which we play, the right configuration and it should work. Cronuxmax gives us more possibilities and connecting different controllers. I have not tested it myself, but from what is written on the device forum it works ok.
  • #7 19907967
    oski20104
    I have Tracer Zonda Wheels, which do not work in Forza Horizon 4. Is there anything I can fix? I have drivers.
  • #8 21528270
    szymoncs01032024pozd
    I have the same problem
The Zonda Tracer steering wheel is reported as non-functional in Forza Horizon 3. Users suggest installing the official Tracer drivers available at the manufacturer's website to enable basic functionality and calibration. However, some drivers may cause issues such as incorrect pedal axis mapping, requiring system driver restoration. It is noted that Forza Horizon 3 does not natively support the Zonda Tracer wheel, as confirmed by compatibility news. A recommended workaround involves using the CronusMax device, which acts as an adapter to connect and configure unsupported controllers for PC, PS4, or Xbox, potentially enabling the wheel to work properly. Despite these efforts, some users report persistent incompatibility, including with Forza Horizon 4. The discussion highlights the importance of correct driver installation, avoiding conflicting drivers, and using third-party hardware like CronusMax for compatibility.
