The game doesn't see my steering wheel - Forza Horizon 4 doesn't see my
mateq121 26217 9
How can I get Forza Horizon 4 to recognize my steering wheel instead of showing that it must be connected as a controller or that the profile is incompatible?
Try calibrating the wheel in Windows 10 and install the steering wheel’s drivers, because the thread suggests Forza may only see it correctly with proper driver support [#18955663] [#19854048] The replies also point to a Forza compatibility discussion for the Logitech Formula Force EX, which may mean this older wheel is not fully supported on your system [#18955663] [#18955611] In the thread, Windows controller calibration did not solve the problem for the Logitech Formula Force EX on Windows 10 [#18955658] [#18955687]
  • #1 18955579
    mateq121
    When I start Forza Horizon 4, I get the following problem:
    "The steering wheel must be connected as a controller" and it is connected or "The profile is not compatible with the currently connected steering wheel"
    Please help me as soon as possible.
  • #2 18955591
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    You can't provide the system version, you can't provide the steering wheel model, you can't tell whether it's installed correctly, but you need help as soon as possible...
  • #3 18955596
    mateq121
    Model: Logitech formula force ex
    Everything is well installed.
    I corrected the spelling. RADU23
  • #4 18955611
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Will you provide the system version or not?
    The last controllers are over 10 years old, did the steering wheel work with the system you have before?
  • #5 18955658
    mateq121
    I have Win 10 and I don't know. All I know is that on foreign YouTube, other people played Forza Horizon 4 without any problems on this steering wheel.
  • #7 18955687
    mateq121
    Unfortunately, this didn't help.
  • #9 18955729
    mateq121
    Nothing, I've already downloaded it 10 times and nothing.
    Please help, I've been sitting at the computer for 14 hours now, looking for a way to fix it, and to no avail.
  • #10 19854048
The user is experiencing issues with Forza Horizon 4 not recognizing their Logitech Formula Force EX steering wheel, receiving error messages indicating that the steering wheel must be connected as a controller or that the profile is incompatible. Despite confirming that the steering wheel is properly installed and operational on Windows 10, the user has not found a solution after extensive troubleshooting, including calibration attempts and driver installations. Other users suggest checking compatibility with older controllers and installing specific drivers to resolve the issue.
