Home Fan Not Spinning/Starting After Overturning: Engine Model, Propeller Block, Capacitor Issue
28359 17
Why does my home fan no longer start after it was overturned and the blades were blocked, and is it repairable?
The fan likely has a damaged motor, not just a bad capacitor, because a long stall can burn the windings or overheat the bearings. Check whether the rotor turns freely and whether 230 V actually reaches the motor; if the rotor stops after a second or the windings show no continuity, the motor is probably bad [#16651334][#16651405][#16651874] The capacitor in this type of fan is typically 1 µF / 450 V AC 50/60 Hz, so it can be replaced, but that alone may not fix a burned motor [#16651375][#16651377] If you do not have proper measuring tools or experience with mains voltage, it is safer to have an electrician or someone knowledgeable diagnose it [#16652255][#16747987] Several replies conclude that if the motor has overheated bearings or windings, buying a new fan is the safest option [#16651669][#16651817]
  • #1 16651311
  • #2 16651334
    rafcio_21
    Help: 137
    Rate: 299
    Since it lay for a long time with the propeller blocked, the winding may have burned to be sure, measure it with an ohmmeter and try to replace this capacitor.
  • #3 16651361
  • #4 16651375
    michalek1988
    Help: 68
    Rate: 181
    Do you have a multimeter? 1uF / 450V capacitor
  • #5 16651377
    rafcio_21
    Help: 137
    Rate: 299
    First of all, it was necessary to check these windings and whether the motor is under voltage so that it turns out that you will buy a capacitor for free and the winding will be burned. The condenser has everything you need: 1 micro farad 450V AC 50 Hz / 60 Hz power supply.
  • #6 16651382
  • #7 16651389
    rafcio_21
    Help: 137
    Rate: 299
    At least check if the motor reaches 230V.
  • #8 16651405
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    At least the rotor rotates loosely. Because this is the most common cause of failure in this fan. And unfortunately, in the absence of basic instruments, it will be best to take them to a neighbor's electrician.
  • #9 16651447
  • #10 16651669
    beatom
    Help: 421
    Rate: 877
    Detach yourself from this capacitor. You have overheated bearings or windings. Fan in the trash.
  • #11 16651674
  • #12 16651817
    krzysiek7
    Moderator of Electricians group
    Help: 678
    Rate: 1953
    Marek57698 wrote:
    These are the measurements from the meter on the winding (Nothing has electricity)
    But it is on this cube or a block of flats.
    You don't measure anything else yourself, don't check it, because it will end tragically. Buy a new fan, it's safest.
  • #13 16651859
    mawerix123
    Help: 482
    Rate: 951
    Marek57698 wrote:
    The recording adds from the measurement
    By making measurements, I improved my mood this cloudy morning :D
    Seriously, I really recommend it to a person who knows about it.
  • #14 16651874
    michalek1988
    Help: 68
    Rate: 181
    It's about someone who has basic tools and elementary knowledge. The cheapest multimeter costs PLN 20 in construction supermarkets. But if you've never used it, buying it will also be of little use. The fan does not start in any gear? You will probably have 2 wires between the motor and the control board (one common and one coming out of the other buttons). There were also when each button came out with one wire to the motor, in addition to the common one. This is not very visible here so it is impossible to decide clearly which of these cases is taking place here. You can use a bulb in the lampholder to check if you have voltage on the wires entering the motor. It will not be a measurement, but only a primitive diagnosis. However, remember that if you make a mistake, damage to the fan is the least problem. You work at a risk that threatens your health and life!
  • #15 16652186
  • #16 16652255
    michalek1988
    Help: 68
    Rate: 181
    Whether it is for repair will turn out when someone checks it and diagnoses the fault. If the engine died, the repair will not pay you. Apply the bulb between the common path and the motor leads on the control board, use one with less power (even 40 W as you will find) but not LEDs. By the brightness of the light you will even know if the tension appears or not. Instead of applying the light bulb, you can also solder it, I can't explain it anymore because I can't see it. On the other hand, if it doesn't explain much to you what I wrote, ask someone who repairs electronics or electrician to check it for you.
  • #17 16747983
  • #18 16747987
    retrofood
    Help: 1140
    Rate: 4798
    Have it with someone who knows about security. Don't fuck a hero. I close the topic.
The discussion revolves around a home fan that stopped working after being overturned, leading to a blocked propeller. Users suggest that the motor windings may have burned out due to prolonged blockage, and recommend measuring the windings with an ohmmeter or multimeter to diagnose the issue. A capacitor replacement is also discussed, with specifications provided (1uF / 450V). Some users advise checking if the motor receives voltage and whether the rotor rotates freely. Concerns about safety and the potential need for professional help are raised, with some suggesting that the fan may be beyond repair if the motor is damaged.
TL;DR: After a tip-over with the propeller blocked, check the 1 µF/450 V start capacitor; as one expert said, "The condenser has everything you need: 1 micro farad 450V AC." [Elektroda, rafcio_21, post #16651377]
Why it matters: This FAQ helps DIYers safely diagnose and decide if a household fan is worth repairing or should be replaced.
Why did my fan stop after it tipped over with the blades jammed?
A jammed propeller can stall the motor, causing heat buildup that damages windings. First, check coil continuity with an ohmmeter to confirm a viable motor. If the winding is open or shorted, replacing a capacitor will not help. [Elektroda, rafcio_21, post #16651334]
How do I tell if the rotor is seized or dragging?
Spin the fan rotor by hand with power disconnected. It should turn smoothly and continue coasting. If it stops almost immediately or feels gritty, suspect seized or overheated bearings and plan for replacement rather than capacitor swap. [Elektroda, Krzysztof Reszka, post #16651405]
What capacitor value does this household fan use?
This thread’s fan uses a 1 µF capacitor rated 450 VAC for 50/60 Hz. Match both capacitance and voltage rating when sourcing replacements from brands like CBB61 form-factor units. "1uF / 450V capacitor" is the referenced spec. [Elektroda, michalek1988, post #16651375]
Can I just replace the capacitor without testing the motor?
Do not skip tests. Verify the windings and confirm the motor actually receives mains voltage. Otherwise, you may buy a capacitor for nothing if the winding is burnt. "First... check these windings..." is expert guidance here. [Elektroda, rafcio_21, post #16651377]
How can I check if 230 V reaches the motor without a meter?
Use a simple test lamp: a 40 W incandescent bulb in a safe lampholder. Place it between the common and motor lead on the control board to see if voltage appears. Avoid LEDs for this test and follow strict safety practices. [Elektroda, michalek1988, post #16652255]
Is a CBB61 capacitor from an online listing acceptable for this fix?
CBB61 is a common fan capacitor package. If the listing specifies 1–2 µF at 450 VAC, it aligns with the thread’s discussed value. Ensure correct microfarads, voltage rating, and AC type before purchase. When uncertain, share the exact link for confirmation. [Elektroda, 2874813, post #16651447]
Quick 3‑step: how do I diagnose a no‑start fan safely?
  1. Unplug and inspect; confirm the rotor spins freely.
  2. Use a test lamp on the control board to confirm voltage reaches the motor.
  3. If voltage is present and windings are intact, replace with a 1 µF/450 VAC capacitor. Work cautiously around mains. [Elektroda, michalek1988, post #16651874]
Is repairing a fan with a dead motor economically sensible?
No. If the motor has failed, the repair generally doesn’t pay off. Parts and labor exceed the value of budget pedestal or desk fans. Focus on safe diagnosis to avoid sunk costs, then replace if windings are damaged. [Elektroda, michalek1988, post #16652255]
I don’t have instruments—what should I do next?
If you lack basic tools, avoid risky improvisation. Seek help from a qualified electrician or a knowledgeable neighbor. They can check bearings, voltage to the motor, and winding continuity safely and quickly. [Elektroda, Krzysztof Reszka, post #16651405]
What inexpensive meter should I buy, and will it be enough?
A low‑cost multimeter exists, but owning one is not the same as using it correctly. Skill and safety matter more than price. If you’ve never used a meter, supervised guidance is essential before testing mains equipment. [Elektroda, michalek1988, post #16651874]
How do I measure the motor winding with an ohmmeter?
Disconnect the fan from mains. Isolate the motor leads. Measure resistance across the winding. A reading near zero indicates a short, while infinite suggests an open coil. Either condition means a bad motor, not a capacitor fault. [Elektroda, rafcio_21, post #16651334]
What are the key safety risks when testing a mains fan?
Mains testing can cause severe shock or worse. Use proper insulation, isolation, and protective equipment. As an expert warned, "You work at a risk that threatens your health and life!" If unsure, do not proceed. [Elektroda, michalek1988, post #16651874]
The rotor turns a little, then stops—what does that mean?
Quick stopping suggests mechanical drag or heat‑stressed bearings. In such cases, even a new capacitor won’t restore reliable operation. The practical advice is to retire the fan to avoid further risk and expense. [Elektroda, beatom, post #16651669]
Why was the forum thread ultimately closed?
A moderator ended the discussion due to safety concerns and urged seeking expert help. Avoid heroic DIY on live mains equipment. When risk is high, consulting a professional is the responsible step. [Elektroda, retrofood, post #16747987]
