Optimal Load Value for Battery Tester Simulating Vehicle Start-Up Conditions
zasilaczen 10047 14
What load current should I use in a simple battery tester to simulate engine starting and check whether the battery voltage stays above 10 V?
Use a load of about 100–125 A; that is the range used in ready-made battery testers, and the exact value should match the battery’s rated cranking current and the test standard rather than a single universal number [#16653155][#16653503] A 3-second load is usually enough to get a stable reading, so your planned 5 seconds is more than necessary [#16653503] If you want a more proper diagnosis, measure the battery’s internal resistance instead of forcing a heavy constant load; a healthy battery is roughly 3–5 mΩ and good testers infer starting current from a much smaller load, around 10 A, or even AC measurement [#16653647] One forum member also noted that a built-in 0.12 Ω load corresponds to about 100 A, and warned not to read the voltage through the tester’s built-in voltmeter because it lowers the measured value [#16755380]
  • 5-second battery load test needs starter-current estimate
    #1 16653127
    zasilaczen
    Rate: 73
    I need a simple tester to check the dry condition of the batteries.
    The tester is to simulate the start of the car if the battery voltage does not drop below 10V.
    Construction: a piece of wire on the section of which resistors or other components giving an artificial load will be attached.
    The problem is choosing the right load value. I have browsed a few topics with inrush current and some say that the starter takes 100-150A from the battery, and others that 300-350A.
    Another problem is that at the moment of start-up, these values jump significantly because many factors of work change, and with such an artificial load, the current is constant.
    What value will be the most optimal for such a test?
    On the one hand, I want to get a strong load so that the measurement is reliable, and on the other hand, I don't want to finish the battery.
    I will add that the measurement length would take about 5 seconds for the multimeter to have a moment to stabilize the values.
    eumox
    Help: 10
    Rate: 63
    Original testers available for purchase load 100A or 125A
  • #3 16653170
    zasilaczen
    Rate: 73
    This is already concrete, thank you
  • 100W resistors switched by car relay for 350A load
    #4 16653222
    funak
    Help: 101
    Rate: 461
    It should be realized that to load 350A you have to take into account the power of 4.2kW.
    For example, if you load a copper wire of an appropriate length, its temperature will change for a few seconds, which will cause the resistance to change as well.
    Maybe I would focus on 100W resistors.
    For example like this:
    Such a resistor can be loaded 5x with a time of 5 seconds, which gives us 500W / piece.
    http://www.tme.eu/pl/details/ax100wr-0r47/rezystory-100w/te-connectivity/5-1625999-3/
    Counting on ...
    470mOhm, it gives it at:
    = 10V, current: 21A, power 212W
    = 12.6V, current: 27A, power 340W
    220mOhm, it gives it at:
    = 10V, current: 45A, power 454W
    = 12.6V, current: 57A, power 718W
    Here, the activation time is max. 3.5 seconds.
    Connect the load with a car relay, each resistor separately - for example a time relay.
  • #5 16653292
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Probably wind a few turns of steel wire cooled with a PC 12V fan.
  • #6 16653363
  • Glow plugs as a low-resistance battery tester load
    #7 16653406
  • #8 16653408
    Aleksander_01
    Help: 1167
    Rate: 3436
    It will be cheaper to buy a new one (100 A) for up to PLN 100, or a stimulant (professional equipment 150/300 A) for about PLN 250.
    I would like to make a 100 ? resistor with a power of 0.1 W, but the cost is about 14 cents and in the store they are 10 cents. Advise on how to go below 10 cents, I need two such resistors.
  • Starter current depends on engine and temperature
    #9 16653503
    vodiczka
    Help: 1185
    Rate: 4311
    Both are right. It depends on the engine model and temperature at start-up.
    Longer than normal boot time? 3 seconds is enough to stabilize the measurement result, unless you want to check if the voltage above 10V is maintained for at least 5s.
    The value will depend on the rated inrush current of the battery under test.
    Do you want to test "so-so" or according to the standard? The standard specifies the method of performing the measurement.
  • Glow plugs suggested as a compact 125A load test option
    #10 16653565
    zasilaczen
    Rate: 73
    So yes gentlemen.
    I will aim at 125A, i.e. how well I counted 1500W.
    On resistors, it would definitely work fine, but the cost of three is almost PLN 100.
    The scale of my needs is also not such that I should immediately obtain a professional tester.
    I am more inclined towards something "Home Made". I have workshop facilities, so there is nothing to prevent me from doing something like this myself, I just need your substantive help to make it all have hands and feet.
    The idea with wire is nice, but I'm afraid it will have to be a lot to get this load, and I need something more handy.
    The idea with sheet metal is equally interesting, but I am not an electronics engineer and I do not know how 60m? is up to 125A
    I really like the idea of glow plugs, small, handy and power-hungry, this could be it :) 5 seconds of connect should be enough. Describe something more about it and how you have built the structure
    @vodiczka Tester is only to exclude batteries where the voltage drops below 10V. For more accurate measurements, I would already invest in a testing device.
  • Battery testing by measuring internal resistance
    #11 16653647
    mkpl
    Level 37  
    Help: 306
    Rate: 863
    To test the condition of the battery, it is not necessary to load it with electricity. You have to measure its internal resistance. Then you can easily determine the starting current and the condition of the battery very accurately. A healthy battery is approximately 3 to 5 mOhm which gives a starting current of approximately 350A.
    Good quality testers measure the voltage difference with no load and with a load of about 10A and from this they determine the internal resistance and the possible starting current. Even better instruments, e.g. Hioki, measure the battery resistance for 1kHz AC current and do not require any current load (but the cost is considerable).
    It should also be remembered that the "starting" current given on the battery is the maximum permissible current, which in a sufficiently short time (specified in the standard which is written opposite) allows to charge the battery without damaging it. Otherwise, the lead connectors between the cells will burn out or the lead plates will bend.
  • #12 16653663
    kkknc
    Help: 1916
    Rate: 6712
    I do not see any sense with the construction. You have ready both load and newer electronic ones. Cheap as dirt, so why bother and think about it.
    The cheapest electronics are $ 20 with a $ 30 resistor. So what will you build below PLN 100?
  • #14 16654261
    sebap
    Help: 538
    Rate: 1083
    On the well-known Yato auction site, you can buy for less than PLN 100, I do not see any sense in DIY in this case.
  • #15 16755380
The discussion revolves around determining the optimal load value for a battery tester designed to simulate vehicle start-up conditions without excessively draining the battery. Users suggest various approaches, including using resistors, steel wire, and glow plugs to create the necessary load. The consensus indicates that a load of around 100A to 125A is suitable for testing, with considerations for the power ratings of components used. Some participants emphasize the importance of measuring internal resistance to assess battery health accurately, while others advocate for purchasing ready-made testers due to cost-effectiveness. The conversation highlights the balance between achieving a reliable measurement and avoiding battery damage during testing.
TL;DR: For car‑battery crank simulation, typical testers load 100–125 A; “Original testers available for purchase load 100A or 125A.” [Elektroda, eumox, post #16653155]
Why it matters: This FAQ helps DIYers and technicians choose a safe, realistic load to spot weak 12 V batteries without guesswork.
What load current should I use to simulate a vehicle start?
Use 100–125 A for a quick, realistic crank simulation. This mirrors many retail load testers and stresses most 12 V SLI batteries without excessive risk during short pulses. It’s a practical middle ground when you only need to flag batteries that sag below 10 V. [Elektroda, eumox, post #16653155]
How much power does a heavy cranking simulation really dissipate?
At 350 A, you’re dumping about 4.2 kW as heat. That level requires robust conductors, short duty cycles, and dedicated cooling. Design with thermal rise in mind, or scale the test current down to safer levels and shorter bursts. [Elektroda, funak, post #16653222]
How long should I apply the load during a drop test?
Apply the load for 3–5 seconds. This duration stabilizes the reading while staying close to a real crank event. Longer pulses add heat and risk. Short, controlled bursts protect the battery and your load hardware. [Elektroda, vodiczka, post #16653503]
Can I build a tester with power resistors?
Yes. High‑wattage resistors can be pulsed above their continuous rating for a few seconds. Select values around 0.22–0.47 Ω and switch them with an automotive relay for short tests. Add airflow and monitor temperature. [Elektroda, funak, post #16653222]
Do glow plugs make a good DIY load?
Glow plugs work well for compact, high‑surge loads. Their cold resistance is much lower than hot, so current rises sharply at start, then tapers. Use brief pulses and sturdy wiring. “You can make a good tester on this basis.” [Elektroda, Anonymous, post #16653406]
Is a stainless strip or steel wire a practical load element?
Yes. A 0.5 mm 316 stainless strip, cut and rolled, forms a low‑ohm resistor suitable for short pulses. Mount it securely and provide airflow, as resistance and temperature will vary during the pulse. [Elektroda, 2974068, post #16653363]
Should I buy a commercial 100–300 A tester instead of building one?
If cost and time matter, buying wins. Basic 100–150 A analog testers are inexpensive and ready to use, avoiding thermal design and safety headaches common in DIY loads. [Elektroda, sebap, post #16654261]
How should I measure voltage during the load test?
Measure with a separate digital multimeter directly at the battery posts. Built‑in panel meters and wiring drops can under‑read, masking the real terminal voltage during the pulse. Use short, heavy leads for the load. [Elektroda, Adamcyn, post #16755380]
Do I need hundreds of amps to judge battery health?
No. You can infer health from internal resistance. Good automotive batteries measure about 3–5 mΩ, which corresponds to strong cranking capability without huge test currents. Some testers estimate this using a ~10 A load. [Elektroda, mkpl, post #16653647]
What does the ‘starting current’ on a battery label really mean?
It indicates the maximum permissible current per the referenced standard for a short interval. Exceeding that risks damage to internal connectors or plate deformation. Use short pulses and respect the rating. [Elektroda, mkpl, post #16653647]
What resistance gives about 100 A at 12 V for a quick check?
Approximate with 0.12 Ω. At 12 V, that implies around 100 A initially, falling as voltage sags and the element heats. Use stout wiring and very short pulses. [Elektroda, Adamcyn, post #16755380]
Why do cars differ between 150 A and 350 A cranking draw?
Engine design and temperature drive the variation. Cold conditions and larger engines raise starter torque demand and current. Expect wide spreads and design your tester for brief, controlled loads. [Elektroda, vodiczka, post #16653503]
Are 100 W resistors enough for a DIY tester?
Yes, if pulsed. A 100 W resistor can handle several times its rating for a few seconds with cooling. Choose values to set current and use relays or a timer for safe pulse control. [Elektroda, funak, post #16653222]
Quick How‑To: perform a safe battery drop test
  1. Connect the load clamps; attach a DMM directly to the battery posts.
  2. Trigger the load for 3–5 seconds and watch voltage drop.
  3. Stop the load; if it sags under ~10 V, plan service or replacement. [Elektroda, Adamcyn, post #16755380]
