74Ah 680A Battery: Decreased Starting Current (650A to 530A) – Causes, Restoration, & Expectations
luckyboy 50478 9
Why has my new 74Ah 680A battery's measured starting current dropped from 650A to 530A, could a 0.7A car draw or repeated starts cause it, and will charging restore it to 680A?
The measured cranking current can change with battery charge level, temperature, and the test method, so a drop from 650A to 530A does not automatically mean the battery is failing [#7002489][#7003264] One reply notes that the Banner tester does not actually load the battery at the rated current; it measures internal resistance and calculates the maximum current, and a 10–15% error is normal [#18099710] Another reply says to charge it, drive it for a while, and recheck it under the same conditions; if the battery still starts the car, there is nothing urgent to worry about [#7002928] A starting current below about 70% of the factory value is what should raise concern, and your 530A reading is still above that threshold [#7003264]
  • #1 7002439
    luckyboy
    Rate: 10
    Hello!
    A month ago I bought a new 74Ah and 680A battery.
    After the purchase, I measured the starting current - the result is 650A, the steel in the warehouse may have lost a little ...
    Now when I measured the result was at 530A
    Could the value of this starting current be caused by something pulling from the car 0.7A??
    I noticed that each start of the car reduced the starting current by 3-5A, which is logical since energy was consumed, or rather not??
    Will now, when it is topped up, will "this" starting current return to 680A??
    Please help because I'm green in this topic and I don't know if the battery is just a little discharged and will regain efficiency or it sits down slowly ...
  • #2 7002489
    niutat
    Level 36  
    Help: 288
    Rate: 758
    Cranking current depends on battery charge level and temperature.
    " The second important feature is the starting capacity. It is expressed in the discharge current specified by the manufacturer that the battery can deliver at minus 18 degrees in 60 seconds to obtain a voltage of 8.4 V. The high starting current is especially appreciated in winter, when the starter draws a current of about 200-300 amperes. The value of the starting current can be measured according to German DIN or American SAE standards. These standards provide for different measurement conditions and, for example, for a battery with a capacity of 55 Ah, the starting current according to DIN is 266 A, and according to the American standard as much as 423 A. "
    And here's a bit about that;
    https://www.elektroda.pl/rtvforum/topic468588.html
  • #3 7002556
    forestx
    Rest in Peace
    Help: 299
    Rate: 496
    How are you measuring the inrush current?
    How often do you measure the inrush current?
    I suspect what does the most damage to your battery... measuring the cranking current frequently :twisted:
    The battery (every one) ages and, among other things, the starting current drops - until it is finally unable to spin the engine.
    What can you do about it? Absolutely nothing. So give him a break.
  • #4 7002666
    luckyboy
    Rate: 10
    forestx wrote:
    How are you measuring the starting current?
    I use a special Banner brand device to measure the inrush current: before the measurement, you enter the data (Ah A and temp.), and I measured twice after the purchase and yesterday :)
    If my battery, as you say, is aging at the rate of 1/6 of the nominal current per month, then in 2-3 months it will be suitable for the trash, so I believe that this is not normal and you should not let it rest :)
  • #5 7002928
    bati1986
    Rate: 29
    you should drive it for a while and then check it. Anyway, if it fires, there's nothing to think about it for now.
  • #6 7003264
    Darrieus
    Help: 406
    Rate: 289
    You kill him yourself and you blame the hunchback for having simple children :)
    The starter will never draw 600A... draws 100-150A.....
    Starting current below 70% of the factory value can only worry, not such changes. Apart from that measurement conditions!!!! or a battery from a store shelf? after the car has been parked for a long time? after one night? after a week of standing? after a long journey? I do not mention the temperature, a change of 5 degrees will significantly change the result, so instead of looking for problems, wash the car ;)
  • #7 7003627
    luckyboy
    Rate: 10
    Thanks for the factual answer ;) And I'm already washing the car ;)
  • #8 18099684
    nasu
    Help: 11
    Rate: 251
    Old topic, but problem not solved. I have a similar case. Battery manufactured April 2019, purchased July 24, 2019 Autopart 110Aha 950A EN Measurement with a fully charged tester shows 910A at 20°C. make a complaint?
  • #9 18099710
    kortyleski
    Help: 957
    Rate: 3860
    This tester does not load the battery with such current. It simply measures the Rw of the battery and on this basis calculates the maximum current. With this method of measurement, 10-15% error is normal.
  • #10 18099802
    nasu
    Help: 11
    Rate: 251
    Maybe so, but I use a total of 9 batteries in various vehicles and machines, and even a few-year-old no-name batteries have a higher current than declared when measuring with a tester. At temperatures above +20C, the EN current should be much higher.
    The previous Autopart 110 G+ worked flawlessly for almost 8 years and was replaced with the same one.
    September 14, 940A
The discussion revolves around a user's experience with a new 74Ah 680A battery, which showed a decrease in starting current from 650A to 530A within a month. Participants highlighted that cranking current is influenced by battery charge level, temperature, and measurement conditions. Frequent measurements may contribute to battery aging, and a drop below 70% of the factory value raises concerns. Suggestions included allowing the battery to rest and checking performance after driving. The user expressed concern about the battery's longevity and whether it could regain its original starting current after being topped up. Other users shared experiences with different battery brands and models, noting variations in performance and measurement accuracy.
