[Solved] Boosting Power: Can a 12V DC Computer Fan Handle 30V DC and 0.4A from a Lexmark Printer?
emil362 9543 9
  • Questioning 30V supply for 12V fan
    #1 16653459
    emil362
    Rate: 9
    I looked at a few topics on the elektroda.pl forum on a similar topic in which experienced users said that you can power a 12V DC (120 mm) computer fan with 12V and 1A current, which gives 12 watts. Now my question is, can I increase the value of the supply voltage to 30V DC and the current to 0.4A (power supply from Lexmark printer) which gives the power of 12 watts. Nevertheless, the tension is raised more than twice.
    Karaczan
    Help: 869
    Rate: 1127
    Hardly any fan will consume 1A. As a rule, they take about 0.5A.
    But you can't increase the voltage to 30V anyway.
    Most fans will handle around 17V, but not all.
    Generally, it should be max 12V +/- 5%
  • #3 16653516
    Jawi_P
    Level 36  
    Help: 260
    Rate: 715
    And most importantly, you do not "tell" such a fan to take electricity as much as you want, but he will take himself as much as he needs. You can only enter the correct voltage. Unless the power supply fails to deliver it.
    And if you can and how much it has already been written by your friend.
  • #4 16653656
    emil362
    Rate: 9
    If I connected a 36? 9W resistor in series to the system, would it be a good solution?
    Or is it better to use the LM317 stabilizer ???
    All this talking about a DC 30V, 0.4A power supply
  • Series resistor divider is inefficient for fan power reduction
    #5 16653676
    Pan Korsarz
    You are probably thinking about creating a voltage divider out of such a system, where you will treat the fan as a resistor with a resistance of 12 ohms (assuming that the rated voltage is 12V and the current is 1A), to which you connect a 36om resistor in series. Then about 1/3 of the voltage, i.e. 10V, will be deposited on the windmill. Note that the total impedance of the circuit will then be 48 ohms, the power supply has a nominal voltage of 12V so the current forced by such a circuit will be I = U / R approx. 0.65A which means that your power supply cannot handle it. Note also that then only 1/3 of the energy will be used to power the fan, and the rest will be radiated as heat on the resistor. Moreover, the voltage divider is not a very effective power supply due to its low efficiency.
  • #6 16653691
    emil362
    Rate: 9
    So I have the LM317 stabilizer left.
  • Recommend using a 12V step-down converter
    #7 16653713
  • #8 16653750
    emil362
    Rate: 9
    Ok. without combining, just buy a 12V, 1A power supply.
  • #9 20447392
    flutek01
    el LM317 es la mejor opción (con disipador)
    yo probé con resistencias en serie y encontré problemas de arraque en algunas marcas de ventilador
  • #10 20453284
    Mirek Z.
    Help: 1132
    Rate: 531
    The main topic from a few years ago lowers the level of the forum, a new addition is unnecessary.
    I'm deleting the topic, trash.
The discussion centers around the feasibility of powering a 12V DC computer fan with a 30V DC supply from a Lexmark printer. Users emphasize that while fans typically operate at 12V, exceeding this voltage can damage them, as most can only handle up to 17V. The consensus is that a fan draws the current it needs based on the supplied voltage, and using a voltage divider or series resistors is inefficient and may lead to overheating. Suggestions include using an LM317 voltage regulator or a step-down converter to safely reduce the voltage to 12V, with a recommendation to simply purchase a dedicated 12V, 1A power supply instead.
