Best Way to Convert 120V AC (3A Switch) to 12V DC for 10A Peltier Module and Fans
990 9
Can I convert a 120V AC mains switch into a 12V DC supply for a 10A Peltier module and fans, and what is the best way to do it?
The best way is to use a commercial regulated switching power supply rated at about 12V and at least 10A, rather than trying to build your own from a transformer and rectifier [#21680094][#21680097] Your existing 120V/3A foot switch can simply be wired in series with the mains input of that supply, since it only switches the AC feed on and off [#21680097] If you do build a supply, you would need a transformer, bridge rectifier, large electrolytic smoothing capacitors, and regulation, and raw rectified AC should not be fed directly to the Peltier [#21680095][#21680094] A 15V supply was suggested if you want to push the Peltier a bit, but only if the module is rated for up to 16V, and a 7812 regulator can drop that to 12V for the fans [#21680097]
  • 120v ac switch cannot power 12v dc load
    #1 21680093
    Nathan Frail
  • 120V 3A switch is fine for 12V 30A load
    #2 21680094
    David Ashton
  • Recommend buying a 12 V 12.5 A switching supply
    #3 21680095
    Rick Curl
  • Foot switch can switch the power supply input
    #4 21680096
    Nathan Frail
  • Recommend a 15V supply with 7812 for fans
    #5 21680097
    David Ashton
  • #6 21680098
    David Ashton
  • #7 21680099
    Rick Curl
  • Need for 5v load on computer psu rails
    #8 21680100
    Nathan Frail
  • #9 21680101
    Nathan Frail
  • #10 21680102
    Rick Curl
A project involves powering a 10A DC thermoelectric Peltier module and associated cooling fans from a 120V AC source switched by a 3A switch. The original attempt using a 10A 12V power adapter from eBay failed due to circuit protection triggering, likely from insufficient current capacity. Testing with a car battery showed the Peltier draws about 5A at ambient temperature, dropping as it cools. Recommendations include purchasing a reliable commercial 12V power supply rated for at least 10A, preferably 12.5A or higher, from reputable suppliers such as Newark, Mouser, Digikey, or Farnell. Building a custom transformer-rectifier-regulator power supply is possible but bulky, complex, and less practical. Using raw rectified AC is discouraged due to potential damage to the Peltier. For higher current and voltage, a 15V supply can be used cautiously, with a 7812 voltage regulator to provide 12V for fans. Standard CPU fans can tolerate slightly higher voltages but may run faster. A foot switch can be used to control the power supply input. An alternative explored was repurposing a 300W computer PSU by jumping the PS-On wire and adding a load resistor on the 5V rail to stabilize the 12V output; however, PC PSUs typically provide limited current on the 12V rail, likely insufficient for the Peltier’s 10A demand. Proper load calculations for resistors and bulbs were discussed to ensure stable PSU operation.
