Citroen C3 - The display in the middle of the panel does not work.
kiss39 25974 5
  • #1 16656509
    kiss39
    Help: 397
    Rate: 636
    As in the description above, the Citroen 3 car. When turning on the radio, the display does not show information, for example, radio stations, etc., and after starting the car, the display is also dead. What could be the cause of such a malfunction?
    panstalin2
    Help: 30
    Rate: 216
    Check the fuses, log in to him what errors it shows.
  • #3 16660842
    kiss39
    Help: 397
    Rate: 636
    @ panstalin2
    How and where to log in? I can see fuses under the hood of the car, and there are ok. And under the steering wheel I do not see fuses as in the description in the book for individual elements, such as display fuse NR 8 current 20A (yellow fuse)
  • #5 16661391
    kiss39
    Help: 397
    Rate: 636
    On this Citroen C3 there are fuses under the hood of the engine.
  • #6 16662001
    panstalin2
    Help: 30
    Rate: 216
    Well, do diagnostics with a tester of the set of indicators - and what error is it writing?
    Added after 6 [minutes]:
    Check if the backlight of this display has gone off?
    Turn on the radio and shine a flashlight on it, do you see outlines of letters and numbers?
    In Bielsko-Biała they have used in the store:
    https://www.eurofrance.pl/pl/p/Wyswietlacz-Ra...3-Lift-96661369XT-503550290414-Oryginal/16682
