[Solved] Blaupunkt RD4 n1 - Radio citroen c4, the display does not respond
robi139 25332 6
  • #1 17223869
    robi139
    I recently bought the car mentioned in the title. Everything is nice, but the display does not work. After removing the radio, only one composite cube and the antenna are connected. The radio works, of course, it plays very nicely, but you can't tune in neither the sound nor the station properly, because it doesn't display. Does a separate cable go to the display? Perhaps someone has replaced the radio with one that does not support this type of display. If anyone could tell me if the connection is ok, I'd be grateful. I don't see any loose plug. I will add that the rest of the functions work as they should. The computer shows combustion and other functions.
    • Blaupunkt RD4 n1 - Radio citroen c4, the display does not respond 20180516_164733.jpg (1.14 MB) You must be logged in to download this attachment.
    • Blaupunkt RD4 n1 - Radio citroen c4, the display does not respond 20180516_164422.jpg (867.7 KB) You must be logged in to download this attachment.
    • Blaupunkt RD4 n1 - Radio citroen c4, the display does not respond 20180516_164408.jpg (636.4 KB) You must be logged in to download this attachment.
    • Blaupunkt RD4 n1 - Radio citroen c4, the display does not respond 20180516_164343.jpg (629.17 KB) You must be logged in to download this attachment.
    zadam64
    Help: 552
    Rate: 741
    And does selecting functions from these four middle buttons work? Pinout of the RD4 Citroen radio cube in the attachment. The radio looks original, but is it connected to the system in the car?
  • #3 17224047
    robi139
    The note button works, when I press and move darkly, the sound changes. Others don't seem to work, when I press it, nothing happens. The radio is factory, the only question is whether the previous owner changed or pulled it out, because there are traces of unprofessional disassembly on the frame. Okay, I'll take a look at that schematic right now.
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1710
    The display has an uncoded radio function.
    LEXIA and 10 minutes of work.
  • #5 17224083
    robi139
    I don't have Lexia, can you do this for me? If so, how much? I could drive up. I understand that the connection is ok? It's like someone has been digging before and you don't know what they were doing.
    LWD11
    Help: 223
    Rate: 486
    You can also rewrite the eeprom in the display and enable radio support, but I recommend Lexia as Szymon wrote.
  • #7 17224387
    robi139
    Ok thank you, everything goes through CAN, tomorrow I'm going to Lexia and after the problem.
    Lexia helped.
The discussion revolves around a Blaupunkt RD4 radio installed in a Citroen C4, where the user reports that the display is unresponsive despite the radio functioning properly. The user seeks clarification on whether a separate cable is required for the display and if the connections are correct, given signs of previous unprofessional disassembly. Responses suggest checking the pinout connections and using a diagnostic tool, Lexia, to enable the display's radio support. The user confirms that Lexia resolved the issue, indicating that the connection was indeed correct.
