Clutch Pump Symptoms in Renault Megane 2009 1.5 dCi - Cold Engine Jerking & Frequent Brake Bleeding
brtk90 17610 6
  • #1 16661783
    brtk90
    Hello. I would like to know from you what symptoms are damaged or not properly functioning clutch pump. Because the car on the cold engine starts jerking off at one, and in no other situation. To this end, brakes are aerated every two weeks to the floor. Do you have any ideas?
    My suggestion is a clutch pump.
    The car is Renault Megane 2009 1.5 dci 110km 81kW
  • #2 16661971
    ociz
    Help: 1379
    Rate: 3486
    Your theory does not make sense.
  • #3 16662020
    nici
    Help: 266
    Rate: 979
    He can always have a joint tank for both systems which is empty ... but you are still right. No sense.
  • #4 16663046
    Staszek49
    Help: 228
    Rate: 1140
    Buddy, do you have loss of brake fluid and if there is a light indicating the loss of fluid. You probably have a common fluid reservoir, i.e. for "brakes and clutch". Check whether the "clutch cylinder" is leaking, or the brake piston, and if you feel a weaker braking effect. Whether under the car, after a long stop there are spots after the leak w / wym. fluid.
  • #5 16663089
    brtk90
    One small screw cap for two weeks. When you release the brakes on the razor when the face is 2 weeks. From day to day, the pedal is getting lower in the floor and brakes only after the second press. Mega dangerous ... unfortunately, you can not see the losses totally nowhere just what puzzles me after the removal of the front wheels around where there are room for screws is greasy in the back of the drought or can it have a connection in this small leakage? I do not smoke any controls And these jerks are springing in the clutch because it tugs more or less in the middle of releasing the clutch
  • #6 16663309
    ociz
    Help: 1379
    Rate: 3486
    Before the fluid for the clutch runs out, the indicator lights up and for the brakes it can go down a lot.
    As it's not the clutch pump and the clutch, if it leaks from it on the shield, there may be some temporary slips.
  • #7 17004476
    bartosz323
    Rate: 14
    Hello, tugged up from the one and backward guilty bimonth. greetings
The discussion revolves around symptoms of a potentially faulty clutch pump in a 2009 Renault Megane 1.5 dCi, specifically cold engine jerking and frequent brake bleeding. The original poster reports that the car jerks when starting from cold and experiences a significant drop in brake pedal pressure, requiring bleeding every two weeks. Responses suggest checking for brake fluid loss, potential leaks in the common reservoir for brakes and clutch, and inspecting the clutch cylinder and brake piston for issues. The possibility of temporary slips due to leaks from the clutch pump is also mentioned.
