Samsung Q1457AT Washing Machine: Error 3E After TNY254P Installation, PCB Schematic Needed
Willi76 27804 4
  • #1 16664171
    Willi76
    Rate: 13
    Hello, I would like to ask specialists from the forum for some tips for my case with the washing machine Samsung Q1457AT. Anticipating all cases with this error that were discussed were analyzed.
    To introduce: for some time the washing machine unblocked and locked the door during washing, then resumed the washing itself, then in addition to this situation, error 13e began to appear and intensified, which prevented further washing.
    After pulling out, plucking and analyzing the PCB I replaced the elements from the power supply section. After this procedure, the washing machine turns on but for programs with washing the display shows error 3E. The washing machine normally takes in water, and after a minute this error appears. The spin program works correctly at all revolutions. Now the question due to the lack of the TNY267PN system in place, I installed the TNY254P - is it because of this problem, or the causes should be looked elsewhere.
    PS: does anyone have a PCB schematic because the forum is but quite different from my model because it is with the TMP86FS 49FG prock and I have STK 621-140b on the board
    Attached is a fragment with replaced elements
    • Samsung Q1457AT Washing Machine: Error 3E After TNY254P Installation, PCB Schematic Needed WP_20170826_11_26_15_Pro.jpg (2.23 MB) You must be logged in to download this attachment.
  • #2 16664277
    Piotr2608
    Help: 851
    Rate: 4488
    3E - motor defect - Switch off the appliance at mains then wait 30 seconds. Switch appliance back on again and start a new program.
    To check everything that is directly related to the engine and thus: the engine itself, wiring, engine block, engine relays, engine relay controls (probably ULN2003).
    ZimTech Piotr Zimny
  • #3 16664338
    Willi76
    Rate: 13
    Even though the motor is running on a centrifugation program?
  • #5 16684239
    Willi76
    Rate: 13
    Hello, the engine is good, the wiring is good. The correct layout finally arrived at the local store TNY267PN - after installing it - everything started to work, wife happy; o) I close the topic.
