Aqualtis AQ113D697 Washing Machine Fault: Power Issues, Blinking Start Button, LNK625PG & PCB
BOYXBA 7935 6
  • #1 18423131
    BOYXBA
    hello i have a malfunction with my washing machine....after 3 corrupt power from power grid it worked for 1 time and after that remains with the power on and the start button blinking....you can change program but it does not respond on start button....unplug it from power but it still has the same problem....it does not power off.......i have removed main pcb.....idd0211 ....i have checked the capacitor ...mosfets....is it possible this cause can be done from failure of lnk625pg ?? the pcb does not have obvious damage on parts...what else can i check....?? error fault does not have on display...the power light remains without blinking...have anyone any idea what is the cause of this malfunction....????
    Aqualtis AQ113D697 Washing Machine Fault: Power Issues, Blinking Start Button, LNK625PG & PCB Aqualtis AQ113D697 Washing Machine Fault: Power Issues, Blinking Start Button, LNK625PG & PCBAqualtis AQ113D697 Washing Machine Fault: Power Issues, Blinking Start Button, LNK625PG & PCB
  • #2 18433375
    skryn
    Home appliances specialist
    Help: 268
    Rate: 1011
    BOYXBA wrote:
    does anyone have any idea what is causing the malfunction ... ????
    Thrust self-test , will show you the error code.
    You do it like this:
    Turn off the machine. It must be in standby mode (machine connected to a power socket, panel off ).
    You press the sensors one to six in turn, then with two fingers you hold the sensors one and six for five seconds .
    PS. Once = one
  • #3 18437623
    Jacis
    Rate: 9
    I will connect to the topic.
    Motherboard the same. Error F15 pops up. Measured water heater - burnt, replaced with a new one. Still the same. Disc pulled out - measured and the only thing I could stick to is a single relay that doesn't work. Just from the water pumps.
    It is based on this diagram. disc a little different but connections are the same.
    http://servicenet.indesitcompany.com/data/img_sm/sm52961.pdf
    I didn't check the heater from the dryer. Maybe someone had a similar problem ?
  • Self-test fails and machine stays powered on
    #4 18446546
    BOYXBA
    PS. Once = one
    it does not make any function does not turn off.....just changes programmes..you pull out the plug and after you reconnect the power unit still remains open ....
  • #5 18447084
    kecajk49
    Help: 501
    Rate: 890
    The power cord for this heater has probably burned!
  • Faulty relay coil likely causing F15 error
    #6 18450288
    BOYXBA
    check with multimeter the relay coil for resistance(if you did not have readings you have faulty relay....you check on the side of 3 legs the two at the edges ) or replace it with new one with the same voltage ...
  • #7 20004118
    metincoding
    Greetings from Turkey. I have this card in my hand and I have a new fault. A few components on the board exploded. I need your help because I can't reach the datasheet over the internet. Could you please take a photo with the following components read?
    -R293
    -R294
    You can also contact us via telegram.
    90 537 460 60 03
The discussion revolves around a malfunctioning Aqualtis AQ113D697 washing machine, characterized by a blinking start button and inability to power off after power interruptions. The user has attempted troubleshooting by checking the main PCB (idd0211), capacitors, and MOSFETs, but the issue persists. Suggestions from other users include performing a self-test to retrieve error codes, checking the relay coil for resistance, and considering potential damage to the power cord or components on the PCB. One user also mentioned a similar issue with an F15 error related to a burnt water heater and a faulty relay. The conversation highlights the need for further diagnostics and component checks to identify the root cause of the malfunction.
