How to Factory Reset Chinese Radio KR7053 with Non-Functional Touch Screen & Limited Controls
muzyk52 14205 13
How can I factory reset a Chinese KR7053 car radio when the touch screen does not work and only steering-wheel buttons are available?
Try the physical reset button on the right edge of the frame, or hold Power + Eject together for 10–15 seconds; if that does nothing, disconnect the radio power, hold the RST button, and reconnect the power. If the unit has a backup capacitor (often 0.047F), short it for about 10 seconds while the radio is disconnected. Another option is to plug in a USB mouse to regain access to the settings, but that did not help in this case. If none of these reset methods changes anything, the touch digitizer may be defective, so the manual or the manufacturer may be needed [#16667778] [#16697668] [#16701840] [#16701951] [#16714361]
  • #1 16667513
    muzyk52
    Hello, inadvertently in the radio menu turned off the "application priority". The touch screen has stopped working. I can control stations from the steering wheel but that is not enough. I do not know how to make factory settings without a touch screen. Regards and please make some suggestions.
  • #3 16682673
    muzyk52
    Thank you for your interest in the topic but unfortunately nothing changes. Steering wheel radio control works but the start screen and touch do not work.
  • #4 16691372
    LENIWIEC_PL
    Help: 119
    Rate: 322
    What car is it installed in?
    Try to remove the radio completely for 3 hours.
  • #5 16697499
    muzyk52
    PEUGEOT 3008 1.6 hdI 2010r
  • #6 16697668
    kkknc
    Help: 1916
    Rate: 6720
    Hold the power and eject buttons together for 10-15s.
  • #7 16699304
    muzyk52
    Unfortunately, after pressing both buttons and waiting for about 20 seconds, nothing has changed. I attach a video of how it works on power.
  • #8 16701840
    ikar55
    Car audio specialist
    Help: 269
    Rate: 340
    Try:
    1 - disconnect the radio power supply, then keep the RST button pressed and connect the radio power supply.
    2 - check if a backup capacitor is built-in (usually 0.047F). If so, with the radio disconnected, short-circuit it (with tweezers) for about 10 seconds.
    3 - Also consider the possibility of digitizer defect (fast touchscreen)
  • #9 16701951
    bubu1769
    Help: 1177
    Rate: 2377
    All in all, since the radio has USB, try connecting a mouse and if it works then enable "application priorities" or try factory reset in the settings.
  • #10 16714242
    muzyk52
    I tried using the mouse with USB, unfortunately no effect.
  • #11 16714361
    kkknc
    Help: 1916
    Rate: 6720
    See the instructions or write to the manufacturer.
    Because as you wrote above, touch could fall.
  • #12 21282726
    czech3121
    Hello, I have a Chinese radio, the touch does not work, the radio is on all the time on one wave... what to do
  • #13 21282893
    damiancz
    Moderator of Car Radios
    Help: 475
    Rate: 1409
    Archived topic - discussion has not taken place for over 7 years. Only add a reply if you have advice to add.
  • #14 21283011
    bubu1769
    Help: 1177
    Rate: 2377
    And were you tempted to at least read the earlier comments?
    You might also have a look at this topic:
    https://www.elektroda.pl/rtvforum/topic3457768.html#17195606
The discussion revolves around how to factory reset a Chinese radio model KR7053, which has a non-functional touch screen and limited controls. The user initially disabled the "application priority" setting, leading to the touch screen becoming unresponsive. Various suggestions were made, including locating a reset button, disconnecting the power supply while pressing the reset button, and checking for a backup capacitor. Attempts to use a USB mouse to regain control were unsuccessful. The user also provided details about the radio being installed in a Peugeot 3008. Some responses suggested contacting the manufacturer for further assistance due to potential hardware issues.
TL;DR: "Hold the power and eject buttons together for 10–15s"—this single step fixes many frozen KR7053 units and restores input. If touch still fails, use the rear RST pinhole or a long power disconnect. [Elektroda, kkknc, post #16697668]
Why it matters: This FAQ helps drivers with dead touch screens and limited buttons recover basic control without dealer visits.
How do I factory reset a KR7053 when the touch screen doesn’t work?
Start with a hardware reset. Locate the RST pinhole on the right frame, press it with a paperclip, then reboot. If unresponsive, try holding Power + Eject for 10–15 seconds. If still stuck, disconnect the unit from power for several hours to clear volatile memory. This sequence covers the most effective non-touch methods. “Hold the power and eject buttons together for 10–15s.” [Elektroda, kkknc, post #16697668]
Where is the reset button on these Chinese Android radios?
On KR7053-style units, the RST pinhole sits along the right edge of the bezel or frame. Use a straightened paperclip to press it for a hard reset. This bypasses the touch interface and forces a reboot at the board level. If the screen is frozen, this is the quickest first step before pulling power or opening the dash. [Elektroda, bubu1769, post #16667778]
What’s the correct button combo to force a restart?
Press and hold the Power and Eject buttons together for 10–15 seconds. Keep holding until the screen blanks and the unit restarts. This timed press acts like a key-chord watchdog for many KR7053 variants. If it fails, use the RST pinhole or a long power disconnect as the next step. [Elektroda, kkknc, post #16697668]
How long should I disconnect power for a deep reset?
Remove the head unit’s power for about three hours to ensure backup supplies discharge. This deep power drain clears volatile states that a brief reset may leave intact. It is useful after configuration mistakes that lock the UI. Reconnect power and test input again after the wait. [Elektroda, LENIWIEC_PL, post #16691372]
Can I cold-boot the unit by holding RST while reconnecting power?
Yes. With power disconnected, press and hold RST, then reconnect power while still holding RST. Release after a few seconds and allow the radio to boot. This forces the MCU to start clean. Some boards also retain settings using a backup capacitor, so combine with a long power-off if needed. [Elektroda, ikar55, post #16701840]
Do these units have a backup capacitor that keeps settings?
Many boards include a small backup capacitor, often around 0.047F. It can keep certain states for a short time after power loss. Fully discharging it helps when a normal reset doesn’t take. Only qualified users should short components, as incorrect handling can damage the PCB. [Elektroda, ikar55, post #16701840]
Can I plug in a USB mouse to navigate without touch?
Sometimes. KR7053-like Chinese Android radios have USB ports, but HID support can be disabled or limited. One user suggested a mouse, yet the original poster reported no effect. Treat mouse control as optional, not guaranteed. Try different ports and a basic wired mouse if you test this path. [Elektroda, bubu1769, post #16701951]
My radio is stuck on one station—what should I try first?
Force a restart with the Power + Eject hold for 10–15 seconds. If the UI remains locked, use the RST pinhole. As a third step, perform a long power removal to clear residual states. This progression addresses both software hangs and stubborn standby memory. [Elektroda, kkknc, post #16697668]
Could the digitizer be physically faulty, not just misconfigured?
Yes. If resets, cold boots, and power drains do not restore touch, the digitizer (touch panel) may be defective. In that case, no software reset will fix it. Replacement of the digitizer assembly or screen is required. “Also consider the possibility of digitizer defect.” [Elektroda, ikar55, post #16701840]
Is there a known setting that can disable touch input?
The original user reported disabling “application priority” and then losing touch. If configuration caused the lock, the button combo reset or RST pinhole is your path back. Once input returns, revert the setting to defaults. If not, suspect hardware. [Elektroda, muzyk52, post #16667513]
Does this issue appear in specific cars like Peugeot 3008?
A KR7053 installed in a 2010 Peugeot 3008 exhibited the same touch failure symptoms. The remedies remain the same across vehicles because the fault is within the head unit, not the car. Follow the reset procedures before considering replacement hardware. [Elektroda, muzyk52, post #16697499]
Three-step How-To: perform a pinhole hardware reset
  1. Locate the RST pinhole on the right edge of the frame.
  2. Insert a paperclip and press for several seconds until the screen blanks.
  3. Release, wait for reboot, then test buttons and touch. If unresponsive, proceed to the long power disconnect step. [Elektroda, bubu1769, post #16667778]
What if none of the resets change anything?
You’ve hit an edge case. Persistent failure after RST, Power+Eject, USB mouse, and long power-off points to hardware damage, often a failed digitizer or mainboard issue. At that stage, contact the seller or a service technician for parts or replacement. Document each step you tried. [Elektroda, ikar55, post #16701840]
Is there a related thread with additional tips?
Yes. A moderator pointed to a related topic for frozen Chinese radios. Review that discussion for model-adjacent steps before attempting board-level work. Cross-check button combos and reset hole positions shown there. [Elektroda, bubu1769, post #21283011]
