What's Better: Makita or Dewalt? Comparing Hammer Drills & Understanding Dewalt's Symbols
filip8015 58224 12
What do DeWalt model symbols and designations mean when choosing a hammer drill?
The thread does not give a universal explanation of DeWalt symbols; the practical advice is to compare the technical data of the exact models and choose based on the intended use [#16670120][#16670118] For the specific comparison mentioned, users treat Makita DHR243 and DeWalt DCH254 as the same class, but one opinion says Makita has better hammering power, battery performance, and spare-part availability, while DeWalt feels more handy [#16893357] Another user reports good long-term results with DeWalt DCH253 after 3 years and about 30,000 holes, but warns that batteries hate freezing temperatures and SDS tools need periodic cleaning and regreasing [#16895061] A different comparison says Makita was stronger on 230V tools, while DeWalt was preferred among 18V tools, although one DeWalt 230V model had thermal-protection issues [#17549360] Overall, the advice is to pick the concrete model for your work rather than the brand name alone, and to consider battery system compatibility if you buy multiple tools [#20447556]
  • #1 16670030
    filip8015
    Rate: 35
    Hello I have a question.
    Does anyone know anything about Dewalt's signs and symbols? I want to buy a hammer drill and what is looking at is another designation.
  • #2 16670034
    filip8015
    Rate: 35
    I am asking for help or advice on what better to buy - Makita or Dewalta hammer drill? Your opinions will be helpful.
    Thank.
    I've merged themes. We do not assume new ones with the same or convergent topic.
    Moderator; Krzysztof Reszka.
  • #3 16670045
    maly_maly
    Help: 25
    Rate: 53
    I have a reference to Makita and DeWalt's screwdrivers. After three years of use, the Makita screwdriver has made the head and clutch work while DeWalt is unbeatable (6 years). Of course, the NI-CD battery in DeWalt is now available for exchange.
  • #4 16670118
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 355
    Rate: 1620
    First of all, specify what models you are interested in and what purpose of this equipment.
  • #5 16670120
    Topolski Mirosław
    Help: 355
    Rate: 1620
    Because they have different technical data - compare them.
  • #6 16670382
    filip8015
    Rate: 35
    as for the choice of Makita Dhr 243 Dewalt, I do not know Dch 243 254
    the purpose of window installation plus minor housework.
    And as for checking the symbols, the technical data is the same from what I was looking at
  • #7 16893357
    godoy
    hello !!!! personally uses makite dhr 243 I had dewalta dch254 is the same class drilling with and without stroke, the function of shaking exchangeable handles, however, in my opinion the power of stroke is in the makita's advantage not to mention the strength of the battery (makita beats on dewalta !!! ) dewalt kind of handy and nicer ?? hahah drs system (dust sucking) in the makita does not change in dewalę so I did not have the general expression of spare parts and strength issue again the advantage of the makita, however, think well because the new set is quite a large expense and whether you get it back ???? the pickles are cheaper but I advise against using some source because it's the hardware that the builder kataja and does not save !!!!
  • Battery care and SDS lubrication tips for hammer drills
    #8 16895061
    MariuszX49
    Help: 43
    Rate: 82
    I have been using Dewalta DCH253 for 3 years and I can confidently recommend having already drilled in various materials about 30,000 holes (I count worn packs) and one thing I will add no battery will have a long life as winter will be in the pace of a frozen car for the night just you have to take home and it's OK. I have a makita some small at 10V and by laziness last winter a couple of nights after the batteries have died. Of course, like any equipment with an SDS holder, it does not like dry and sandy drill rinsing WD40 once a few weeks and the new grease is applied on the drill and the hula equipment is nice. Diameters with which the drill is a 6-12mm range and occasional to pierce 22mm.
  • #9 17422239
    johny604
    Rate: 82
    I have a DEWALTA DCF899P2 impact wrench, after half a year of use, the tool attachment end flew off.
    Warranty 3 years (theorism) rejected because the tip worn and the service paid.
    Normally, the embarrassment. It looks like the tools can not be used. That I am not advocating this brand
  • #10 17549360
    Jan_Werbinski
    Help: 76
    Rate: 671
    I use the Makita HR2610 hammer on 230V and recently DeWalt DCH273 18V. Both devices work perfectly. Once I also had DeWalt D25303 at 230V and there were problems with it - after a short time of work, drilling a few holes probably turned off as a result of thermal protection. She would not allow it for about two weeks! After which she acted again.
    Makita even drilled holes in concrete with a 85mm core bit drill and gave advice. It heated strongly so as it burned in hands, it cooled down.
    The thickest DeWalt 18V holes in concrete are about 30mm and there were no problems.
    Makita has an average protection of batteries - electronics blocks them after a voltage drop even if the cells are operational.
    To sum up: DeWalt OK - my favorite 18V tools. I already have 7 pieces.
    Makita OK - my favorite 230V tools. At the moment 3 items
  • #11 17549507
    archanoid
    Help: 76
    Rate: 250
    Hello . Drill Dewalt DCD791P2 screwdriver price around 1200 PLN and the quality worse than lidl parkita. The battery loosely holds, the handle has a beating. For such a company I expected better quality. The equipment will go to exchange because only 4 days ago purchased.
  • #12 17566634
  • Brand quality varies, so check current reviews
    #13 20447556
    Witek_2
    Rate: 35
    Today, the decision to choose a manufacturer can be difficult. Why? I do not attribute anything to a given brand - I would just like to mention the problem. There are known cases of deliberate aging of components, equipment calculated to work properly during the warranty period, etc. The market is constantly changing, we have a flood of cheap equipment from China, which takes profits from respectable companies producing decent equipment.
    In addition, a product produced today does not necessarily have to be as durable as the same one produced years ago, so the quality lead can float between different companies. The matter is not facilitated by some problems - because it is better to buy all the tools from one company, especially the battery ones, where the same battery can be embedded in different task-specific equipment.
    My advice - follow the current opinions of a given product, because even the best brands sometimes have their mishaps and even such equipment can be terribly faulty.
    Added after 5 [minutes]:
    One more thing - here you have an interesting video material about the leading brands:
    https://www.youtube.com/watch?v=lUsXXxpqUoc
    or here:
    https://www.youtube.com/watch?v=Y5OkFERItYA
    enjoy reading :)
The discussion centers around the comparison between Makita and Dewalt hammer drills, with users sharing their experiences and preferences. Key points include the durability and performance of specific models, such as the Makita DHR 243 and Dewalt DCH 254, with some users favoring Makita for its battery strength and overall power. Concerns about Dewalt's symbols and technical specifications were raised, with users suggesting that potential buyers should consider the intended use and specific model features. Issues with battery longevity and product quality were also highlighted, particularly regarding Dewalt tools. Overall, the conversation emphasizes the importance of current product reviews and the variability in quality across different manufacturing periods.
TL;DR: One user logged about 30,000 holes with a DeWalt DCH253, noting “I can confidently recommend.” For light installs, both Makita DHR243 and DeWalt DCH254/273 fit; compare features and battery care. [Elektroda, MariuszX49, post #16895061]
Why it matters: This FAQ helps DIYers and pros choose a hammer drill and decode DeWalt markings without wasting budget or performance.
Which is better for hammer drilling: Makita or DeWalt?
Both brands perform well; pick by model and job. Reports praise DeWalt for cordless breadth and Makita for robust corded units. A user favors DeWalt for 18V tasks and Makita for 230V heavy drilling. Compare specific models, not logos. [Elektroda, Jan_Werbinski, post #17549360]
Are Makita DHR243 and DeWalt DCH254 in the same class?
Yes, users compared them as equivalent class tools with drilling with/without hammer and quick-change options. One noted Makita’s stronger hammer feel. “Makita beats on DeWalt!!!” reflects that perception, not lab data. [Elektroda, godoy, post #16893357]
How many holes can a DeWalt DCH253 realistically drill?
A field report counted about 30,000 holes across materials using a DCH253. That figure reflects long-term use with proper care, not a rated lifecycle. Store batteries warm and maintain the SDS chuck to sustain output. [Elektroda, MariuszX49, post #16895061]
What do DeWalt model symbols and letters mean?
They distinguish technical differences—power class, features, and kit contents. Don’t rely on letters alone. Compare the full technical data and functions between models you shortlist. “Because they have different technical data—compare them.” [Elektroda, Topolski Mirosław, post #16670120]
What’s the best hammer drill for window installation and small home jobs?
The thread’s use case matches mid-class SDS‑Plus tools like Makita DHR243 or DeWalt DCH243/254. Either fits light anchors and masonry plugs. Choose based on availability, kit (batteries/charger), and dust options. [Elektroda, filip8015, post #16670382]
Are SDS chucks sensitive to dust and dry debris?
Yes. Users warn SDS systems dislike dry, sandy dust. Rinse bits with a light solvent occasionally and re‑grease shanks to reduce wear and vibration. This simple maintenance preserves performance. [Elektroda, MariuszX49, post #16895061]
How should I maintain my SDS-Plus hammer drill?
Do this monthly in dusty work: 1. Clean bit shank and chuck with a light solvent. 2. Apply fresh SDS shank grease. 3. Test rotation and percussion before load. This keeps the clutch and chuck smooth. [Elektroda, MariuszX49, post #16895061]
Do batteries suffer in cold weather?
Yes. Cold reduces effective capacity and can shorten life if left in a freezing vehicle. Store packs indoors overnight and fit them warm before work to keep runtime and cycle life steadier. [Elektroda, MariuszX49, post #16895061]
Is DeWalt’s 3‑year warranty reliable?
One owner reported a denied claim on a DCF899P2 due to a worn anvil tip, despite the advertised 3‑year term. Treat warranties as conditional and inspect wear items early. [Elektroda, johny604, post #17422239]
Cordless vs corded: when to choose each?
Choose cordless (e.g., 18V DeWalt) for mobility and typical anchors up to ~30 mm in concrete. Choose corded (e.g., 230V Makita) for long, heavy drilling or large core bits where sustained power matters most. [Elektroda, Jan_Werbinski, post #17549360]
Any known overheating or shutdown edge cases?
A DeWalt D25303 corded unit reportedly tripped thermal protection and wouldn’t run for about two weeks, then recovered. Allow cooldowns, clear vents, and match bit size to spec to avoid thermal lockouts. [Elektroda, Jan_Werbinski, post #17549360]
Are Makita batteries too conservative on cutoff?
One user observed Makita battery electronics blocking output after voltage drop even when cells still seemed usable. Expect protective cutoffs to prioritize cell safety over squeezing extra runtime. [Elektroda, Jan_Werbinski, post #17549360]
How durable are the brands long-term?
Anecdotes vary: a Makita driver’s head and clutch failed after three years, while a DeWalt driver kept running six years, though its Ni‑Cd needed replacement. Track actual models and usage, not just brands. [Elektroda, maly_maly, post #16670045]
Should I stick to one battery ecosystem?
Yes. Picking one brand lets the same battery power drills, drivers, and saws. Also watch current product reviews since quality leadership can shift with new generations. [Elektroda, Witek_2, post #20447556]
Any heavy‑duty experiences with larger hammers?
A user ran about a 7 kg DeWalt SDS‑Max hard for years, finally failing during demanding core drilling on a church job. Even pro‑grade tools have limits under extreme loads. [Elektroda, Anonymous, post #17566634]
