HITACHI DH26PC (3.2J) vs MAKITA HR2470 (2.7J): Comparing Parameters, Performance & Recommendations
porlock 10746 10
Will the power difference between the Makita HR2470 2.7 J and the Hitachi DH26PC 3.2 J be noticeable, and which one should I choose?
Yes, the 2.7 J vs 3.2 J difference is noticeable; the Hitachi hits harder, but the Makita is a bit weaker, less sensitive to construction dust, more durable, and cheaper to service [#16434059] One reply also says the DH26PC exists in cheaper China and more expensive Japan versions, with the same numbers but different country marking, and that both models are sensitive to building dust [#16434059] Another recommendation was to skip both and consider a Bosch GBH 2400 or GBH 2-26DFR instead [#16434263]
  • #1 16433917
    porlock
    Rate: 58
    I know that Makita HR2470 (2.7J) has slightly worse parameters than HITACHI DH26PC (3.2 J) but will it be felt?
    In general, which one would you choose and why, and maybe something else?
  • #2 16433965
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    porlock wrote:
    I know that Makita HR2470 has a little worse parameters than HITACHI DH26PC but will it be felt?
    Taking into account my experience, I focus clearly on the mock-up. It's like VW and Ford.
  • #3 16433984
    porlock
    Rate: 58
    I associate it more like Kawasaki and Honda :D even a stylist similar :-)
  • #4 16433985
    tonsileg
    Help: 8
    Rate: 22
    I also confirm that Makita is quality in itself and not any china but a good product by supporting everyday life and completed work.
    In addition, as far as I know, I don't know if the drills themselves are assembled, but the drills for the Polish market are also manufactured by us according to Japanese technology.
  • #5 16433987
    porlock
    Rate: 58
    And what about 2.7J vs 3.2J will it be clearly felt with Makita weaker?
  • #6 16434059
    qadam12
    Help: 62
    Rate: 254
    It is so felt. DH26PC is available in cheaper China, more expensive Japan - the same numbers and only the inscription on the body of another (given country of origin), but the class is completely different. Both are sensitive to building dust. Makita is a bit weaker, but less sensitive to dust and more durable. I have both models, they perform quite well on construction sites. I will add that any Makita service is much cheaper.
  • #7 16434087
    porlock
    Rate: 58
    qadam12: which one would you buy :-)
    Unfortunately, they do not write in "boarders" which tab they have DH26PC :(
  • #8 16434099
    qadam12
    Help: 62
    Rate: 254
    Below 500 - China, above 700 - Japan
  • #9 16434263
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 355
    Rate: 1620
    Makita has its production in China (and who does not have it now), and when it comes to Makita drills, they are shabby (quality incomparable with power tools - much worse than power tools).
    When it comes to choice, think about GBH 2400 BOSCH or GBH 2-26DFR.
  • #10 16434677
    porlock
    Rate: 58
    I just ordered GBH 2-26DFR thanks :)
  • #11 17896774
    Kapelmajster
    And how does Bosch work? I want to buy 2-24DFR
The discussion compares the HITACHI DH26PC (3.2J) and MAKITA HR2470 (2.7J) in terms of performance and durability. While the DH26PC has higher impact energy, users note that the difference may be felt in practical applications. The Makita model is recognized for its quality and durability, particularly in dusty environments, despite its lower power rating. Some users suggest considering alternatives like the Bosch GBH 2400 or GBH 2-26DFR, with one participant confirming an order for the latter. Overall, the choice between the two brands may depend on specific needs, including service costs and performance in construction settings.
