Ariston Pro Eco 80L Electric Boiler: Cutting Electricity Costs for 3-Person Family & G11 Tariff
Pawelko4 93732 11
  • #1 17181514
    Pawelko4
    Hello, I wanted to know how to reduce the cost of electricity for the electric boiler or better to turn it off during the night or the day after bathing etc. Is it better to have turned on 24 hours a day, I am asking for advice because I have very large electricity bills here are a few of my data: I have an electric boiler ARISTON PRO ECO 80 liters, the temperature most often 50 degrees, a family of 3 (2 adults, 1 child), tariffs for normal electricity G11.
  • #2 17181565
    Sstalone
    Help: 72
    Rate: 397
    Since you have a 24-hour tariff, you should keep the temperature in the tank as low as possible and heat when needed, and avoid long storage of hot water. At night you should not heat, or if you need to heat up the hot water, the heater should turn on just an hour before the residents get up.
    If you consume a lot of electricity for heating hot water, I would consider switching to a dual zone tariff.
  • #3 17181634
    sp3ots
    Help: 523
    Rate: 673
    Hello !
    I am surprised by such questions as yours on the forum, it is so difficult to check for yourself how to heat up "cheaper".
    I had a 120L boiler, turned it on two and a half hours before the planned bath, then turned it off.
    In the boiler there was always hotter water than the one that flies directly from the water supply and in the morning you could wash, it was not ice cold.
  • #4 17181695
  • #5 17182464
    Strumien swiadomosci swia
    Help: 1404
    Rate: 6404
    ALe exceeds PLN 120-150 per month?
  • #6 17183050
    Pawelko4
    yes, unfortunately, it exceeds PLN 150.
  • #7 17188130
    Szczecin62
    Help: 44
    Rate: 123
    None of your proposals will actually save you electricity. Container insulation is so good that the parking loss is several pennies a day and you can practically avoid them. What does it mean for big electricity bills and how can I be sure it's a boiler effect? 3 people, let everyone use about 70 liters of hot water per day, that is, a total of about 200 liters. the average temperature of cold water is 10 * C you use water not hotter than 45 * C (these 50 * C mix with cold). Heating 200 liters by 35 * C is about 8 kWh of energy for which you will pay 4-5 zlotys, that is 120-150 zlotys per month and you will not turn off any noticeable savings.
    Greetings
  • #8 17188146
    Dominik_31
    Rate: 18
    Hello. It heats the water electrically in the summer. Boiler 100 liters. One tariff. I have set about 45 - 47 degrees on the thermostat. Do I turn off for the night or all the time, the difference can not be seen and for PLN 20 a month there is nothing to cling with shutting down because a few times to bath and there is no hot water because someone forgot to attach. Every day you use it does not make sense to turn it off. Like every other day, it makes sense. The boiler I have in the attic and I warmed it up with wool, the heater turns on twice a day as you wash your hands after a pee or a pile.
  • #9 17188201
    vodiczka
    Help: 1185
    Rate: 4301
    It's good or it's not, that's the question :?:
    Heat losses are proportional to the temperature difference between the water and the boiler's surroundings. Without playing in the calculation of how much pennies we lose or gain, it is advantageous to keep the boiler turned on for 24 hours with the lowest temperature, which will ensure continuous consumption of hot water.
    For me, the plot is 40 ° C.
  • #10 17188299
    BANANvanDYK
    Help: 1162
    Rate: 2573
    For me, I spent 180 zlotys for two months for the WHOLE HOUSE with hot water heating in the second tariff (G12w).
    You'd better ask your wife how much energy she spills into the sink. Not only in the form of CWU, but also from cooking.
    Personally, for one hand wash, I use about 0.5-1 l of water, and for shower 7-10 l of water. Recently, when I was finishing the bath, only warm water came, that is, everything would agree. A lot more clean, cold water will be used to flush the toilet.
    You can pay attention to the connection of the boiler, as a result of which there is no gravitational leakage of heat into the pipes. The boiler should hold heat for 24 hours when no hot water is drawn and the heater is turned off. Of course, the temperature will drop a little. By turning on the heater again and measuring the working time or measuring the wattmeter, you will measure how much you lose on the so-called parking losses.
  • #11 17188488
    Lisek64
    Help: 218
    Rate: 588
    Nice few years back, a colleague brought me from Germany a used electric heater 60 l Stiebel. I have it so far and I will not exchange it for another unless it falls apart from old age :-) The tank is made of thick copper sheet plus excellent foam insulation. About three years ago, the last heaters were burnt so I was supporting new ones. But to the point. The boiler has two sections of heaters. "Duty" who (original something about 1500W) and thermostatic, which maintains the temperature of the water to a temperature of about 20-30 degrees. This temperature is enough for "ordinary" use. When I want to take a bath in a bathtub or take a shower, just press the button on the thermostat and the second section of heaters (probably 2500W originally were). he then heats up to the max without regulation, perhaps up to 65 degrees. All you need to do is wait a few minutes to get a long shower in a comfortable environment. Even if I forget to turn off the "turbo" option, after reaching temp, I will turn off all heaters. The boiler is in an insecure attic and even in the winter it keeps warm water until morning. My total electricity bills are around PLN 125 per month
  • #12 17197123
    gaz4
    Help: 77
    Rate: 2947
    Although the higher the temperature in the boiler, the greater the losses on the special methods of switching on / off will not save much. If you do not eat it, you do not take it as my mother said. Therefore, it is worth going to the tariffs from the G12 group, probably the most profitable will be G12w. For this a time switch that keeps you warm when the electricity is cheap, with the "manual" button to easily heat it in the first tariff when you need it. Remaining with G11, you can additionally insulate it and add a layer of aluminum foil (or thermal blanket) to limit the infrared escape. For me, the old metallized foil that was after the renovation clearly reduced the downtime losses. Add a few cm additional warming to the upper lid, because this is where most heat escapes. It can be wrapped with a layer of wool or an additional polystyrene housing, but all of the above (together with a reduction in temperature) will give less savings than a non-investment tariff change. In G12w it is cheap between 13-15, 22-6 in the morning and all day on Saturdays, Sundays and holidays. It saves not only on the boiler switched on when electricity is cheap but also on computers, TV, household appliances working in this time.
✨ The discussion revolves around strategies to reduce electricity costs associated with the Ariston Pro Eco 80L electric boiler for a family of three. Users suggest keeping the boiler's temperature low and using a timer to heat water only when needed, such as shortly before bathing. Some recommend switching to a dual-zone tariff (G12) for better savings, while others argue that insulation and minimizing heat loss are crucial. The consensus is that continuous heating at a lower temperature may be more efficient than frequent on/off cycles, especially given the high insulation of modern boilers. Users also share personal experiences with different heating schedules and tariff plans, emphasizing the importance of monitoring water usage to identify potential savings.
TL;DR: For a 3-person home, heating 200 L by 35°C uses ≈8 kWh/day; "Container insulation is so good that the parking loss is several pennies a day." Keep setpoint low, schedule heating, or switch to G12w. [Elektroda, Szczecin62, post #17188130]
Why it matters: Families running an Ariston Pro Eco 80L on G11 can lower hot-water costs without cold showers or hassle.
Should I keep my electric boiler on 24/7 on G11?
Yes—leave it on and set the lowest temperature that still meets demand. Heat losses scale with temperature difference. "It is advantageous to keep the boiler turned on for 24 hours with the lowest temperature." This approach avoids frequent reheats and preserves comfort on a single-rate tariff. [Elektroda, vodiczka, post #17188201]
Will turning the boiler off at night save money on G11?
For daily use, users report little to no saving from nightly shutoff. It also risks cold water if someone forgets to switch it back on. One user at 45–47°C saw “no difference” whether left on or off overnight. [Elektroda, Dominik_31, post #17188146]
What temperature should I set to reduce costs but stay comfortable?
On G11, keep the tank temperature as low as still comfortable and heat when needed. Avoid long storage of hot water. "Keep the temperature in the tank as low as possible and heat when needed." If heating at night, start about an hour before wake-up. [Elektroda, Sstalone, post #17181565]
How much electricity does a 3-person family use for hot water?
Estimate ~200 L/day of hot water. Heating a 35°C rise needs about 8 kWh/day. That equals roughly 4–5 PLN/day, or 120–150 PLN/month on G11. "You will not turn off any noticeable savings" by toggling power. [Elektroda, Szczecin62, post #17188130]
Is switching to G12w worth it for hot water?
Yes, if you can shift heating into off-peak windows. G12w is cheap 13–15, 22–6, and weekends. Use a time switch with a manual ‘boost’ for occasional needs. "It is worth going to the tariffs from the G12 group… G12w." [Elektroda, gaz4, post #17197123]
How should I schedule heating with a programmer or smart plug?
Use a timer to match usage. Run short morning/afternoon cycles for washing and kitchen needs. Schedule a longer evening cycle for showers or baths. Adjust durations until you consistently finish with a little hot water left. "Use a programmer that will switch on the boiler at the right time." [Elektroda, Anonymous, post #17181695]
How can I cut standby (parking) losses on my 80L tank?
Add insulation and a metallized foil or thermal blanket to the cylinder. Add extra centimeters on the top lid, which leaks the most heat. Lower the setpoint modestly to reduce temperature difference. Expect smaller savings than a tariff switch, but still measurable. [Elektroda, gaz4, post #17197123]
How do I measure my boiler’s standby losses?
Do a simple test.
  1. Heat the tank to setpoint, then switch the heater off and stop drawing hot water.
  2. Wait many hours, e.g., 24 h, without any hot-water use.
  3. Turn the heater on and time the reheating or read kWh on a wattmeter. "Measure the working time or measuring the wattmeter." [Elektroda, BANANvanDYK, post #17188299]
My pipes feel warm with no water running—whats happening?
You likely have gravitational heat leakage into the pipes, which wastes energy. Check the boiler connection and verify there is no unintended thermosiphon path. "The boiler should hold heat for 24 hours when no hot water is drawn." Confirm by the standby-loss test and adjust plumbing if needed. [Elektroda, BANANvanDYK, post #17188299]
Does extra foil or blanket insulation actually help?
Yes. Users report metallized foil clearly reduced downtime losses. Wrap the cylinder and add several centimeters on the top lid. You can use wool or a polystyrene shell. Note: these upgrades save less than changing to G12w, but they are low-cost. "Add a few cm additional warming to the upper lid." [Elektroda, gaz4, post #17197123]
What real-world bill can I achieve on G12w?
One user paid 180 PLN over two months for the entire house with hot water heating in the second tariff. Shift other loads, like laundry and dishwashing, into cheap windows to compound savings. Results depend on habits and appliance efficiency. [Elektroda, BANANvanDYK, post #17188299]
How much water do typical tasks use, and why does it matter?
Reported use: 0.5–1 L for one hand wash and 7–10 L for a shower. Reducing draw volume directly lowers energy use and bills. Monitor flow and shorten showers to see immediate savings on any tariff. [Elektroda, BANANvanDYK, post #17188299]
My boiler sits in an unheated attic; can it still hold heat?
Yes, with good insulation it can. A user’s 60 L tank in an uninsulated attic kept water warm overnight. They used a ‘turbo’ boost only before longer showers. Their total electricity bills were around 125 PLN per month. [Elektroda, Lisek64, post #17188488]
What if my G11 bill exceeds 150 PLN/month?
Check whether your hot-water volume exceeds ~200 L/day or your setpoint is higher than needed. At 200 L and a 35°C rise, expected cost is 120–150 PLN/month. Toggle strategies won’t add “noticeable” savings; focus on volume, setpoint, and insulation. [Elektroda, Szczecin62, post #17188130]
