[Solved] BCS NVR0401-P & NVR08025M-P: Finding Dahua Equivalent Models for Firmware Update
szydas 13008 18
Can I find the Dahua equivalent models for BCS NVR0401-P and NVR08025M-P and safely use their firmware to update the recorder?
You can update these BCS recorders with firmware from the matching Dahua twin model if the hardware parameters match, and the reported working method was to upload it through the recorder’s web browser, not Smart PSS, then restore factory settings afterward [#16915754][#16929677] One user reported that after this upgrade there was no trace of BCS and the recorder gained Easy4ip cloud support [#16915754] BCS also has an FTP server with newer firmware releases, including versions that add P2P support: ftp://ftp.bcscctv.pl/ [#17176799] Be careful, though: flashing third-party software can kill the device even if it appears identical [#16672075]
  • #1 16671889
    szydas
    Help: 6
    Rate: 20
    Good day.
    I need help finding Dahua equivalents for BCS NVR0401-P and NVR08025M-P. I have tried on my own at http://www.dahuasecurity.com but I have fallen - I probably can't, for this the site comes very slowly. And I'm looking for answers to download the appropriate firmware file to update. BCS doesn't respond to my emails (yes, I checked the Spam folder). Someone will save?
  • #2 16672075
    szymon122
    Help: 302
    Rate: 762
    Uploading third-party software to the recorder may end up killing the device even though it appears to be identical ;)
  • #3 16672919
    jpl
    Help: 240
    Rate: 223
    Then call me, there really are people who know each other and often help.
    And that I will ask - why are you updating?
  • #4 16673339
    szymon122
    Help: 302
    Rate: 762
    And why update the BCS? That people would not break in ...
  • #5 16673477
    jpl
    Help: 240
    Rate: 223
    Therefore, if it is so - then bcs will help even more
  • #6 16673486
    szymon122
    Help: 302
    Rate: 762
    For a fee of 60 PLN ;)
    It used to be PLN 80, you can see that more and more of these devices are coming back to them ...
  • Reasons to update: motion detection and no-plugin browser access
    #7 16674454
    szydas
    Help: 6
    Rate: 20
    Two reasons:
    - the first is motion detection by cameras; this cannot be brought about because they detect the movement of air particles and do not see the truck approaching. New versions are new algorithms ... Camera software is the latest available (cameras also BCS). New software versions allow direct access to the camera interface from the recorder, maybe there you can tune something by the way.
    - the second is "beloved" Webplugin: new versions allow logging into the recorder through a browser WITHOUT a webplugin, it is only needed for preview, and new versions work in new MS browsers under Windows 10.
  • #8 16675469
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    You wrote to the right address that I would ask ;)
    I have never had problems with communication with BCS.
    OMNI-SAT
    WP 11, Wołów, 56-100 | Company Website: www.omnisat.pl
  • Recorder firmware won’t improve IP camera motion detection
    #9 16675519
    jpl
    Help: 240
    Rate: 223
    Unfortunately, here I have to worry you. The firmware update of the recorder in this case will not do anything, because in the case of the KAMERAIP-> NVR connection - the camera is responsible for motion detection. So for motion detection to work better - you need to update your IP cameras.
    And here I immediately say - yes, do not look that it could be different.
    The second thing is that you have a specific processor (hisilicon) in the camera - which is weak by design - and there are 2-3 detection algorithms to it - which are also weak. Manufacturers are unlikely to improve them - because it gives nothing (restrictions).
    I will agree with this - and it will help as much as possible.
  • #10 16676101
    raffin
    Help: 86
    Rate: 109
    szydas wrote:
    That's the right question. By calling the NSS / BCS helpline at 100% we will hear the question: "And what is wrong with you, that you want to update?"
  • #11 16676506
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    @raffin? seriously ; DDD you are a shock
    OMNI-SAT
  • #12 16915518
    bronek1307
    So how ... can you upload dahue to bcs or not? I have bcs-nvr16025me and I would like to upload something with cloud support (easy4ip)
  • #13 16915633
    raffin
    Help: 86
    Rate: 109
    I have not tried - although I intend to, but I suggest asking this question to dahua technical support and give them the BCS symbol, the other way round the help may not work or the answer will be almost sure that "no".
  • #14 16915754
    bronek1307
    Managed to! I downloaded firmware from a twin dahuy. I was not successful by smart pss so I uploaded via a web browser! after the upgrade I had to restore the factory settings. There is no trace of BCS. What's better - the recorder had no cloud support option. NOW LOGIN TO Easy4ip! I recommend - GOOD CHANGE :)
  • #16 16928594
    szydas
    Help: 6
    Rate: 20
    then tell me how did you solve the firmware problem - contact with Dahua or BCS?
  • #17 16929677
    bronek1307
    dahua politely sent me to contact bcs, but before I just downloaded the update for dahua with the same parameters as bcs moth.
  • #18 17176799
    mzielarz
    Rate: 8
    There is an FTP link on the BCS website where you can download all new updates available. Also those with P2P support, which appeared in some new soft versions. link: ftp://ftp.bcscctv.pl/
  • #19 17348332
    szydas
    Help: 6
    Rate: 20
    For now, I was able to dig up a slightly newer version of the firmware from BCS. Since only the cameras are responsible for detection, the case is closed, there is no newer software.
The discussion revolves around finding Dahua equivalent models for BCS NVR0401-P and NVR08025M-P to facilitate firmware updates. Users express concerns about the risks of uploading third-party firmware, as it may damage the device. The need for updates is justified by improvements in motion detection algorithms and browser access without plugins. Some users successfully updated their BCS devices with Dahua firmware, achieving features like cloud support. However, it is emphasized that the cameras primarily handle motion detection, and updating them may yield better results. Users also mention the availability of firmware updates on the BCS website and the importance of contacting technical support for assistance.
TL;DR: For BCS NVR0401-P/NVR08025M-P, motion detection lives in the cameras (typically 2–3 detection algorithms), not the NVR; browser‑based firmware updates can help usability—"it will help as much as possible." [Elektroda, jpl, post #16675519]
Why it matters: This FAQ helps installers decide when to update firmware, how to do it safely, and where to get files.
Can I flash Dahua firmware onto a BCS NVR?
Yes, at least one user flashed a matching Dahua “twin” firmware onto a BCS recorder, then reset to factory settings. Branding changed and Easy4ip appeared. Browser upload succeeded where Smart PSS failed. Proceed only if models truly match. [Elektroda, bronek1307, post #16915754]
What are the risks of installing third‑party firmware?
“Uploading third-party software to the recorder may end up killing the device,” even if the hardware looks identical. This is a real risk with cross‑flashing. Confirm equivalence before any attempt, and have a recovery plan. [Elektroda, szymon122, post #16672075]
Will updating the NVR improve motion detection?
No. In an IP camera → NVR setup, the camera handles motion detection. One expert notes Hisilicon‑based cameras expose only about 2–3 weak algorithms. Update or replace cameras for better detection. [Elektroda, jpl, post #16675519]
How do I perform the update if Smart PSS won’t upload the file?
Try the web interface instead.
  1. Find a Dahua/BCS firmware that matches your unit’s parameters.
  2. Upload via the NVR’s web browser interface.
  3. After flashing, restore factory settings. Smart PSS failed for one user; browser upload worked. [Elektroda, bronek1307, post #16915754]
Where can I download official BCS firmware (including P2P builds)?
BCS publishes updates on its FTP, which includes builds that add P2P features to some models. Use the official FTP to avoid mismatched images. [Elektroda, mzielarz, post #17176799]
Why should I consider updating at all?
Common reasons include improved browser login with fewer plugins, compatibility with newer Windows 10 browsers, and direct camera interface access from the NVR menu. These can streamline daily use. [Elektroda, szydas, post #16674454]
How do I find a Dahua “twin” for my BCS NVR?
Match on core parameters, then obtain the Dahua firmware that aligns with those specs. One user did this after Dahua support redirected him to BCS. Verify before flashing. [Elektroda, bronek1307, post #16929677]
Will flashing Dahua firmware remove BCS branding?
Yes, the reported cross‑flash resulted in “no trace of BCS” after a reset. Features like Easy4ip also appeared in the menus following the update. [Elektroda, bronek1307, post #16915754]
Do I need to factory‑reset after updating?
Plan to reset. The successful cross‑flash case required restoring factory settings post‑update to stabilize the system and expose new options. [Elektroda, bronek1307, post #16915754]
How responsive is BCS support, and what might they ask?
Call them. Experienced members report helpful staff and that helpline agents often ask, “What is wrong that you want to update?” Be ready with specifics. [Elektroda, raffin, post #16676101]
How much could vendor assistance cost?
A community member cited a 60 PLN fee for assistance, noting it had been 80 PLN before. Costs vary; confirm current pricing before sending hardware. [Elektroda, szymon122, post #16673486]
What is Easy4ip/P2P in this context?
It’s Dahua’s cloud/P2P access option that enables remote login without manual port forwarding. After flashing a matching Dahua build, a user gained Easy4ip on a BCS NVR. [Elektroda, bronek1307, post #16915754]
