Home monitoring 6 IP cameras - BCS or Hikvision [set up to 3 thousand]
zenon1967 15798 16
Should I buy one of these ready-made BCS or Hikvision IP camera kits for 6 outdoor cameras on a PLN 3,000 budget, or choose a different setup?
Neither ready-made IP kit is well thought out; the first recorder is especially bad because it can record only two channels at 4 MPx, so buying 4 MPx cameras with it makes little sense [#18169128] The better approach is to select the recorder, cameras, and storage individually for the actual site, because the equipment should match the viewing conditions rather than being chosen as a prepacked set [#18169128] On a tight budget, several replies suggest considering Turbo HD/AHD/CVI instead of the cheapest IP system, since the cameras are usually cheaper and the PoE switch is not needed [#18168881] Also, a budget 4 MPx camera can give worse night images than a 2 MPx one, so higher resolution is not automatically better for this use case [#18169506] The kits were also criticized for hiding important details such as the disk model, which was seen as a way to cut costs on components [#18168868][#18169506]
  • #1 18168520
    zenon1967
    Rate: 50
    Hello colleagues.
    I am to install several cameras next to the house -6 pcs ..- cost up to about PLN 3,000.
    I am interested in the opinion of users and installers.
    https://ivel.pl/p10127,zecja-do-monitoringu-re regator-ip-bcs-bcs-p-nvr0801-4k-e-6x-kamera-4mpx-bcs-p-414r-e-ii.html
    Initial selection is-4Mpx-CAMERA BCS-P-414R-E-II- 6 pcs [about 300 PLN]
    Objects 4mm - angle about 70 degrees - this is the scope that interests me.
    Lighting at night is planned - to be mounted next to the cameras.
    BCS-P-NVR0801-4K-E RECORDER [about 600 PLN]
    2TB disk. [about PLN 300]
    SWITCH LV-SP0208G [about PLN 350]
    or Hikvision
    https://ivel.pl/p10980,monitoring-zewnetrzny-...kvision-hiwatch-reawodator-ip-hwn-4108mh.html
    If I need other data, I will complete it. I have read a lot and I know that 3,000 is not enough for good equipment, so I am looking for a price / quality compromise.
    I am waiting for opinions - about the topic - it can be priv - without unnecessary austerity.
    Regards, Zenon
  • #2 18168868
    suworow
    Help: 650
    Rate: 1276
    This is obvious. The second "set" is out of the question since there are cameras with a focal length of 2.8 mm :)
    As usual, there is no information about the disk in Ivel. So again counting on a not very sophisticated client.
    You can read about the Hiwatch series cameras in this material:
    https://www.elektroda.pl/rtvforum/topic3592781.html
  • #3 18168879
    sosarek
    Help: 9318
    Rate: 15512
    The equipment is completely not thought out, just look at the recorder description. The second is a little better.
    How do you know that 6 cameras are enough for the given angle of view to work, etc.?
    What's the point of packing in IP on a limited budget?
    Z
    Pka, Poznań, 60-850
  • #4 18168881
  • #5 18168893
    zenon1967
    Rate: 50
    Thanks to colleagues for the information.
    A friend of the sauces.
    6 cameras - because ... he can count up to 10.
    4 mm lens - angle about -74 degrees - because the waist I'm interested in as much as it covers the terrain [I had geometry at school]
  • #6 18168918
    suworow
    Help: 650
    Rate: 1276
    A colleague will read it: https://www.elektroda.pl/rtvforum/topic3592781.html and will look at the notes of the indicated registrars.
    A colleague did not refer to what I wrote earlier:
    A colleague is already bored with this topic?
  • #7 18168988
    zenon1967
    Rate: 50
    The world of CCTV is a world of compromises, including the price ones ;)
    I allowed myself to quote from my colleague Suvorov.
    I looked at the article - in the evening time will allow me to read the rest. Notes from the recorders - I did not find ...
    I am inclined to IP- even worse quality- or at the beginning of fewer cameras.
    Some cables already distributed over IP
    4mm cameras, narrower field of view - from 2.8mm - more useful for me - walls of buildings, trees, etc ...
    The proposed drive is- 2TB SKYHAWK
    A budget of about 3,000 - this is just a prerequisite
    Thank you for the information.
  • #8 18168991
    sosarek
    Help: 9318
    Rate: 15512
    zenon1967 wrote:
    Notes from the registrars - I did not find ...
    Are you kidding Just enter your models in Google and you have hundreds of them.
    Well, it's better to buy a sell instead of good quality equipment ...
    Even the analog on the twisted pair is not a problem.
    Z
    Pka, Poznań, 60-850
  • #9 18169001
    zenon1967
    Rate: 50
    Buddy sosarek - thank you very much for the advice - please do not clutter my topic.
    I wrote in 1 post - without unnecessary pinching - my friend can read ??
    So much for the topic.
    BCS and HIKVISION are rubbish companies - since when?
  • #10 18169009
    sosarek
    Help: 9318
    Rate: 15512
    @ zenon1967 I suggest you learn to read with understanding, you can see that you have no idea about the subject and you ignore any advice and consider it spam.
    Did I mention any brand?
    Better to buy CVI, AHD, TVI instead of the cheapest IP.
    Z
    Pka, Poznań, 60-850
  • #11 18169087
    zenon1967
    Rate: 50
    Buddy Sosarek.
    I proposed 2 set of BCS and HIK - in your opinion it is a waste - you write it yourself, read it.
    ;; Well, it's better to buy a junk instead of good quality equipment. ;; - quote ..
    Ends - spam elsewhere
  • #12 18169095
    sosarek
    Help: 9318
    Rate: 15512
    @ zenon1967 Are you kidding yourself or are you seriously struggling to understand what is written to you clearly?
    You have a problem to even look at the specifications of the devices, you know everything better - what's the point for?
    Z
    Pka, Poznań, 60-850
  • #13 18169120
    zenon1967
    Rate: 50
    Here we evaluate 2 proposed IP sets. BCS and HIK.
    We are talking about a compromise of "worse quality" - initially 2 proposed sets.
    The specification on paper is one thing.
    The assessment of the Installers' users - the latter - and these opinions interest me.
    Possibly other sets - what colleagues in the topic will suggest.
  • #14 18169128
    sosarek
    Help: 9318
    Rate: 15512
    Buying a set with 4MPx cameras in a set with an NVR that allows you to record only two channels in this resolution is pointless (you would read the specification, you would know about it) - that's why the installer selects the equipment individually and does not buy ready-made sets.
    The equipment is selected for the specific conditions on the site, there is not a word about them, you insist that the camera with a 4mm lens will meet the expectations.
    HiWatch is again a budget series.
    Z
    Pka, Poznań, 60-850
  • #15 18169204
    zenon1967
    Rate: 50
    Thank you that our discussion is on the right track.
    I read between the lines that the 4MPx camera -that's at home is an exaggeration -OK.
    As I wrote earlier, I lean [and do not insist] - to the 4mm lens - such conditions in the square next to my house, where a narrower angle will work better.
    Narrow entrance to the property, narrow area between the house and trees, etc.
    The 2.8 lens is only a last resort.
    Therefore, according to my modest knowledge - I had previously proposed 2 sets.
    Another BCS set - with 4MM- 2MPx cameras - please give feedback about it.
    https://ivel.pl/p11199,zecja-monitoringu-do-f...u-reawodator-ip-6x-kamera-fullhd-akyszne.html
    HiWatch the budget series.
    Tomorrow I will read carefully about your proposal.
  • #16 18169506
    suworow
    Help: 650
    Rate: 1276
    Why an exaggeration. You just need to know that what we get in terms of quality during the day, we can give back at night, where the image from a 4MPx camera (especially from a budget camera) may turn out to be weaker than the image from a 2MPx camera.
    It all depends on our expectations. Definitely 4MPx to observe how the grass grows ;)
    Please read this more:
    https://www.elektroda.pl/rtvforum/topic3527930.html#17617115
    I did not ask what my friend was going to buy the disk, but I suggested paying attention to what is in the set linked by my colleague, because the only information about it is that it is a 1 TB disk, without a name and model. It is always a way to get a few dozen zlotys on a set, and an untrained person will swallow it. Similarly to this recorder, which was pointed out by @sosarek
    These are such sweet secrets of cheap kits assembled by specialists from this company ;)
  • #17 18169534
    kood
    CCTV and Stationary Alarms specialist
    Help: 259
    Rate: 443
    Buddy, you don't take one thing into account that a smaller horizontal angle is also a proportionally smaller vertical angle, and this can be important, it all depends on what the cameras are to observe, e.g. the length of the driveway and at what height they will be hung.
    It is not surprising to me that this store made such a set :)
✨ The discussion revolves around the installation of six IP cameras for home monitoring within a budget of PLN 3,000. Users express concerns about the quality and specifications of the proposed equipment, particularly comparing BCS and Hikvision brands. The initial selection includes BCS-P-414R-E-II cameras with a 4mm lens and a BCS-P-NVR0801-4K-E recorder. Participants debate the adequacy of 4MPx cameras, suggesting that lower resolution might be more effective in low-light conditions. There are recommendations to consider Turbo HD systems as a potentially better value alternative. The importance of selecting equipment based on specific site conditions and the limitations of budget kits are emphasized, with suggestions for alternative models and configurations.
TL;DR: Planning six IP cameras under PLN 3,000? Some 8‑ch NVRs record only 2 channels at 4MP; “Buying a set with 4MP cameras ... is pointless” unless specs match. Prefer tailored picks over bundles and consider analog HD if budget-bound. [Elektroda, sosarek, post #18169128]
Why it matters: This FAQ helps homeowners pick BCS/Hikvision (or analog HD) wisely, avoid NVR bottlenecks, and choose lenses, storage, and lighting for real-world results.
Quick facts:
Is 6 IP cameras under PLN 3,000 realistic for a home system?
Yes, but expect compromises or a phased rollout. Consider Turbo HD (CVI/AHD/TVI) to cut cost and skip the PoE switch. At similar prices, analog HD cameras often have better parameters. Choose equipment for the site, not just a bundle. [Elektroda, Anonymous, post #18168881]
Should I choose 4MP or 2MP cameras for a house?
4MP gives more daytime detail. At night, budget 4MP can look worse than 2MP. “What we get in terms of quality during the day, we can give back at night.” Add lighting if you pick higher resolutions. Mix 2MP in darker areas and 4MP where lit. [Elektroda, suworow, post #18169506]
Is a 4 mm lens right for narrow driveways and side paths?
Yes, 4 mm narrows the scene versus 2.8 mm. The narrower horizontal angle also shrinks vertical coverage. Mounting height and target distance then become critical. Test one placement before standardizing all lenses. Use 2.8 mm only where you need wider coverage. [Elektroda, kood, post #18169534]
Why should I avoid pre‑built IP kits?
Some kits bundle 4MP cameras with NVRs that record only two 4MP channels. That wastes cameras’ capability. “Buying a set with 4MPx cameras ... is pointless” if the recorder can’t handle them. Select components individually for your site and required specs. [Elektroda, sosarek, post #18169128]
How do I check if my NVR matches my cameras’ resolution?
  1. Read the NVR spec for per‑channel recording resolution and total throughput.
  2. Confirm how many channels support your target resolution (for example, 4MP).
  3. Match camera count and resolution to those limits before purchase. [Elektroda, sosarek, post #18169128]
Is Hikvision HiWatch OK on a tight budget?
HiWatch is a budget series. It can fit tight budgets, but expect trade‑offs in features and performance. Verify the NVR’s 4MP channel limits before buying. Favor individually selected components over generic ready‑made sets. [Elektroda, sosarek, post #18169128]
I already ran Ethernet. Should I still consider analog HD (CVI/AHD/TVI)?
Yes. Analog HD over twisted pair is not a problem. You also avoid the cost of a PoE switch. This route can preserve image quality when the IP budget forces weak components. Use it when funds are tight. [Elektroda, sosarek, post #18168991]
What hard drive should I pick for the NVR?
Avoid bundles that hide the drive details. Some include only an unnamed 1TB disk. Choose a known surveillance HDD model and capacity that meets your retention needs. Verify the exact drive the kit provides before committing. [Elektroda, suworow, post #18169506]
How many cameras and what coverage do I really need?
Survey the site before buying. Lens choice drives coverage and identification capability. Six cameras may not meet your angle or detail goals. Validate required field of view against actual scenes. Adjust camera count after a pilot test. [Elektroda, sosarek, post #18168879]
Will adding lighting at night improve quality?
Yes. Extra light stabilizes night scenes and boosts detail. Higher resolutions benefit because budget 4MP can degrade in low light. Plan lamps near cameras to reduce noise and reliance on IR. This improves identification after dark. [Elektroda, suworow, post #18169506]
Can I mix 2.8 mm and 4 mm lenses in one system?
Yes. Match each lens to the scene width. Use 4 mm for narrow approaches and 2.8 mm for wider views. Select cameras and the recorder as a tailored set. Avoid generic kits that mismatch optics and NVR capabilities. [Elektroda, sosarek, post #18169128]
What PoE switch budget should I plan?
Plan around PLN 350 for an 8‑port PoE switch in this class. Ensure enough PoE power for all cameras. IP systems need this cost, while analog HD avoids it. Balance switch spend with camera quality and storage. [Elektroda, zenon1967, post #18168520]
Are BCS and Hikvision bad choices?
No. The problem is mismatched components or too‑tight budgets, not the brand itself. Focus on the right technology for the budget. Consider CVI/AHD/TVI instead of the cheapest IP options if quality suffers. [Elektroda, sosarek, post #18169009]
Is 2TB storage enough for six cameras?
2TB is a common starting point when funds are limited. Actual retention depends on resolution, frame rate, and recording mode. Start with a surveillance‑rated drive and expand if retention is short. Size storage to your goals, not just price. [Elektroda, zenon1967, post #18168520]
Does a 4 mm lens really give about 70–74° horizontal view?
In this context, users planned around ~70–74° with 4 mm to suit narrow zones. Verify with the specific camera datasheet. Test one camera on site to confirm coverage before ordering all six units. Adjust focal length as needed. [Elektroda, zenon1967, post #18168520]
