Best RJ45 Cable for 250Mb/s Network: Cat5e vs Cat6 for Router & 2m Length
buhaj47 5847 7
  • #1 16673382
    buhaj47
    I am going to buy RJ45 cable for router, network speed is 250Mb / s. The first better cable probably falls out, because I'm not sure if cat.5 is limited to 100 Mb / s. Anyway, whether such cable would do the job? The cable length will not exceed 2 m.
  • #2 16673386
    hermes-80
    Help: 1177
    Rate: 743
    UTP Cat 5e easily pulls 1Gb / s - it is important that it is connected to 1Gb / s ports.
  • #3 16673391
    buhaj47
    OK thanks. Any specific companies, if only not to take anything for PLN 2 with Allegro?
  • #4 16673398
    hermes-80
    Help: 1177
    Rate: 743
    Madex, Bitner - do you install at home or only connect 2 hosts?
  • #5 16673416
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    From my experience, I can recommend MAXCABLE cables, both UTP and FTP, although their FTP is rather typically external and extremely stiff, but the parameters are as good as +
  • #6 16673783
    buhaj47
    I connect the device to the router, a short ball.
  • #7 16674522
    Gatki
    Rate: 31
    I bought a cable from Bitner and it works, I think I bought it from 20 meters, cut 2x rj-45 and clamped it!
  • #8 16675054
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    I use MAXCABLE for kilometers :) The longest Gigabit connection I have on this cable is about 25m + PoE power supply to the device and talks without a problem ;)
For a 250Mb/s network, both Cat5e and Cat6 RJ45 cables are suitable, with Cat5e capable of supporting speeds up to 1Gb/s when connected to compatible ports. Users recommend brands such as Madex, Bitner, and MAXCABLE for reliable performance. MAXCABLE is noted for its long-distance capabilities, with successful connections over 25 meters, including Power over Ethernet (PoE) applications. The importance of avoiding low-cost, low-quality cables is emphasized, particularly when purchasing from online marketplaces.
