Recommended Brands for High-Quality UTP Cat6 Cable for 1 Gbit/s Home Network
Portal 9729 4
  • #1 15907256
    Portal
    Rate: 58
    I want to buy a UTP cable (wire) cat 6 for installation at home. Please advise which company to buy so that it is of good quality... the network at home will be based on a 1 Gbit/s link... I would rather spend a little more money and have peace of mind than later break down walls etc... and replace it with another one
  • #3 15907462
    bossmotion
    Bitner or Madex - you will be satisfied
  • #4 15907679
    jimasek
    Help: 3783
    Rate: 2681
    Madex, Bitner, Draka - I use these every day and I have no complaints.
  • 24 AWG copper cable is sufficient for home gigabit networks
    #5 15908663
    Darom
    Electrician specialist
    Help: 231
    Rate: 588
    In my opinion - in a home network it is not that important. Almost everyone copper and with a minimum wire cross-section of 24AWG/0.5mm will be good.
    It is best to install a cable that is part of the system`s extended warranty. The cables recommended in previous posts are ok.
    Installers use their own distribution channels. An ordinary user may stumble upon a fake of a well-known brand.
    I have never seen Chinese MADEX counterfeits. It`s a good cable.
    best regards
    -DAREK-
