Low Internet Speed: Troubleshooting RJ45 Network Cable Issues (UTP Cat 5e, 1000Mbps)
peePeer 95601 33
Why do my 20 m Cat 5e RJ45 cables cap internet speed at about 85 Mbps while a 1.5 m cable gives over 500 Mbps, and will replacing the cable fix it?
Your 20 m cable was the problem, not the internet line: one cable had a broken pin, another was not even a twisted pair, and the whole set was cheap, poor-quality wiring that could not negotiate proper throughput [#17552058][#17552118] A properly made twisted-pair cable of this length should not be limited to 85 Mbps, so the symptoms pointed to bad cable/termination rather than normal Cat 5e limitations or room layout interference [#17552233][#17552390] The practical fix was to replace it with a proper UTP cable; after buying a Cat 6a 30 m cable and crimping it, the speed rose to almost 520 Mbps [#17571321] After the new cable was installed in the baseboards, it still worked fine with no interference and kept about 520 Mbps, so shielding was not necessary here [#17633553]
  • #1 17545895
    peePeer
    Rate: 27
    I changed the internet speed from 100 Mbps to 500 Mbps, the problem is that on computers connected by UTP cat 5e RJ45 network cables 20 m long, the speed checked with Speedtest is Max 85 Mbps. All computers have 1000 Mbps network cards. On the third computer connected with a 1.5 m cable, the speed is over 520 Mbps - others connected to this short cable also get over 500 Mbps.
    I conclude that it is a cable problem, but I do not know if it is the fault of poor quality (cat 5e) and it is only the inscription on the cover or the problem is caused by laying in the baseboards (coaxial cable from the cable, electrical installation in the wall) causing some big interference. buy a new cable - I'm thinking about a shielded cable, but I don't know if I put it in the same place, the problem will disappear.
  • #2 17545907
    leonov
    Help: 1039
    Rate: 2248
    Pull the current cables out of the strips and you will know if it is the fault of the cables or the interference ;-)
  • #3 17545960
    peePeer
    Rate: 27
    Thanks, but it's not that simple (put the furniture back, etc.) I would have pulled it out and checked it on the floor a long time ago.
    leonov
    Help: 1039
    Rate: 2248
    Do it or buy it as you have it now.
  • #5 17545985
    peePeer
    Rate: 27
    These are two cables from different sellers, bought ready. From one I can cut 5-7 m, I do not have a kneader yet, but the idea is good.
  • #6 17546886
    Zutket
    Level 36  
    Help: 270
    Rate: 1045
    As I know life, you bought the cheapest cable (packet). Unfortunately, good cables cost money. With such lengths (20m) it is reasonable to lay good quality cables and terminate them at the ends with sockets, and then connect the devices to them with packets.
  • #7 17546930
    peePeer
    Rate: 27
    Exactly, the cheapest cables, at speeds up to 100 Mbps, worked well. I just ordered a crimper and plugs, when it comes, I will check the method with cutting off a few meters of the cable and check on the floor, if it is about 500 Mbps, it means that it collects interference.
  • #8 17552058
    peePeer
    Rate: 27
    Hello again
    The kneader came, I checked 1 cable with a tester, and it turned out that 1 pin did not connect, I replaced the tip but the speed did not increase. Cable - it turned out to be an alu line and, what's worse, it is not even a twisted pair. I cut almost 11 m from the second cable - the cable is copper-plated alu wire, I checked the speed of 85-90 Mbps on the floor. The speed on this shortened about 9 m to 90 Mbps. You will have to replace the cables, of course, with copper wire, or buy ordinary UTP or shielded ones - while arranging the previous ones, I had to bend quite strongly in several places - I don't know if the shielded one can be bent that way, I didn't have one in my hands. Another problem is the screen, it must be grounded, is it enough to connect the router and the computer with a metal plug, or do you need to additionally ground it? . What cat 5e or 6a? because I would prefer not to do it a second time, I know that the Cat 6 cable will be thicker and probably harder. On Monday I am going to order a cable - by then someone will help and advise the best solution.
    best regards
  • #9 17552118
    jprzedworski
    Help: 758
    Rate: 828
    peePeer wrote:
    it's not even a twisted pair
    Then you have the answer.
    UTP, there are only problems with the screen.
    Well, just like UTP, there is no problem with the screen.
  • #10 17552131
    peePeer
    Rate: 27
    Thanks
    And the categories? 5e or maybe 6a - I just don't know if it's much harder.
    Added after 16 [minutes]:
    One cable has the colors arranged according to the type of assembly 2, and the other (the one is not a twisted pair), it is not known because the colors are a kind of massacre similar to each other. both cables are type - simple, connected correctly - tested with a tester.
  • #11 17552165
  • #12 17552189
    peePeer
    Rate: 27
    Thanks
    I have a router up to 1000 Mbps, but when I connected the internet for the first time - with a killer speed of 4 Mbps and then it seemed a lot ... I will probably put cat 6a because it is not known what speeds will be needed 2-5 years. It is not known, maybe in a few years there will be 8-16-32 K TVs?
  • #13 17552195
  • #14 17552204
    peePeer
    Rate: 27
    According to type B, the second one has completely different colors but the tester shows the same order of insertion.
  • #15 17552207
  • #16 17552227
    peePeer
    Rate: 27
    Yes, the cables are properly clamped, I suspect that the cables are poor quality -20m, they cost about 10-12 with shipping, as I wrote above, one turned out to be a non-twisted pair with non-standard colors.
    Supplier atelpol
    Arris router
    1000 Mbps speed
    Proven speed test
  • #17 17552233
  • #18 17552254
    peePeer
    Rate: 27
    I can make a shorter piece of twisted pair out of this cut piece (1-1.5 m) and check the speed with the Speedtest.
  • #19 17552268
  • #20 17552334
    peePeer
    Rate: 27
    Arris TG2492S
    I made a 1.5 m cable what? -and the same about 85 Mbps. I attach a photo of the contacts. Low Internet Speed: Troubleshooting RJ45 Network Cable Issues (UTP Cat 5e, 1000Mbps)
  • #21 17552390
  • #22 17552420
    peePeer
    Rate: 27
    Nobody used the net during the test.
    I did restart the router. On the original cable from the cat 5e router, the speed is correct, the router supports up to 1000 Mbps but the ordered speed is up to 500 Mbps and the speedtest shows over 520 Mbps. I connected all computers via this cable and they all have speeds above 500 Mbps. Only on this old cable it is 85 Mbps - the same is at 1.5 m and the same at 20 m, it is not normal for me.
  • #23 17552425
  • #24 17552490
    jprzedworski
    Help: 758
    Rate: 828
    Can I see well? After zooming in, I see some strange unevenness, dimples, pitting on these contacts. Is that right or is it just glare? Maybe it is not in contact in the sockets.
  • #25 17552504
    jimasek
    Help: 3783
    Rate: 2681
    @jprzedworski it looks as if it was not a crimper made with just a screwdriver
  • #26 17552529
    peePeer
    Rate: 27
    A crimper, but for PLN 9 it is a bit defective, it presses pin 1 and 8 poorly, you need to press it a few times, I will file a complaint. so I do not need such "for years"
  • #27 17552568
  • #28 17552622
    peePeer
    Rate: 27
    Maybe it will crash, but you have to notice that the factory contacts were not better at all, but exactly the same
  • #29 17552670
  • #30 17552724
    MANTA20E
    Help: 13
    Rate: 63
    Dude # peePeer # - Is there an anti-virus program on your computer ..? It may be the cause of the problems you write about.
    A few months ago I was having exactly the same event with the change of internet provider and its speed.
    It looked like this:
    The previous provider gave Download up to 20 Mb / s and Upload sometimes up to 2 Mb / s. and somehow it was slow but it worked .....
    The new provider on optical fiber gives 300 Mb / s at 150 Mb / s. but computers only see 100 Mbps at 100 Mbps.
    Where is the cause ..?
    Network cards checked, each has a bandwidth of up to 1Gb transmission ... which is much above the provider's parameters.
    It turned out that the cause of the problems was a paid antivirus program, which must be properly configured for this speed. (I will not mention the name of the program for obvious reasons)
    I suggest you take a look at the settings of the antivirus program if you have one on your PC.
    In my case, one call to HELPDESK of the company from which the antivirus was purchased was enough.
    best regards
The discussion revolves around troubleshooting low internet speeds experienced on computers connected via UTP Cat 5e RJ45 network cables. The user upgraded their internet speed from 100 Mbps to 500 Mbps but observed speeds only reaching a maximum of 85 Mbps on 20 m cables, while a 1.5 m cable achieved over 520 Mbps. Various responses suggested that the issue likely stemmed from poor cable quality, particularly since the longer cables were found to be copper-clad aluminum and not true twisted pairs. Recommendations included replacing the cables with higher quality options, such as UTP Cat 6a, and ensuring proper crimping of connectors. After testing with a new Cat 6a cable, the user confirmed improved speeds of 520 Mbps, indicating that the original cables were indeed the source of the problem.
TL;DR: Replacing a 20 m cheap CCA “Cat 5e” with real copper Cat 6a raised Speedtest throughput from 85 Mb/s to 520 Mb/s; “Good cables cost money” [Elektroda, Zutket, post #17546886] Use solid-copper UTP, crimp with quality tools, and verify Gigabit link lights.
Why it matters: The wrong cable instantly throttles a 500 Mb/s line to old-school Fast-Ethernet.
• Gigabit Ethernet supports 100 m channel length over Cat 5e or better [TIA-568-C.2]. • Copper-Clad Aluminum adds ≈53 % resistance vs. pure copper, increasing errors [Fluke, 2020]. • Cat 6a handles 10 Gb/s at 100 m; Cat 5e tops out at 1 Gb/s [TIA-568-C.2]. • 37 % of field link failures trace back to bad patch cords [Fluke, 2021]. • Sub-€5 crimpers often mis-seat pins 1 & 8, cutting speed to 85 Mb/s [Elektroda, peePeer, post #17552529]
Why did my Gigabit NIC drop to 100 Mb/s on a 20 m run?
One or more pairs were open or poorly crimped, so the port fell back to Fast-Ethernet, which uses only two pairs [Elektroda, peePeer, post #17552058]
How can I spot a copper-clad aluminum (CCA) patch cord?
Scrape the conductor; a silver core with a thin copper skin reveals CCA. The cable also weighs about 30 % less than solid copper of the same length [Fluke, 2020].
Does cable length alone reduce speed on Gigabit Ethernet?
No. Any solid-copper Cat 5e/6 link up to 100 m maintains 1 Gb/s when correctly terminated [TIA-568-C.2].
Cat 5e vs. Cat 6a—worth the upgrade?
Cat 6a supports 10 Gb/s, so one cable change today covers decade-level bandwidth growth. Price difference is often <€0.25/m [Amazon list, 2023].
Do I need to ground shielded RJ-45 cables?
Yes. Bond the drain wire to an earth point at patch panel and switch. Leaving it floating negates the shield benefit and may introduce ground loops [Siemon, 2019].
Can a cheap crimper really slow my network?
Yes. Mis-seated contacts raise insertion loss and packet retries. “Better throw that pincer into the trash” [Elektroda, Anonymous, post #17552568]
How do I test if electrical cables nearby cause interference?
Pull the network cable out of the strip and retest on the floor; if speed climbs, the route is noisy [Elektroda, leonov, post #17545907]
Quick 3-step check for a healthy Gigabit link
  1. Confirm NIC reports 1000 Mb/s full-duplex.
  2. Copy a 4 GB file between two PCs; expect ≥110 MB/s.
  3. Record errors in switch port stats; counters should remain near zero.
Could antivirus software throttle Speedtest results?
Yes. Some security suites scan traffic and cap throughput until tuned. One user regained full 300 Mb/s after vendor-guided changes [Elektroda, MANTA20E, post #17552724]
Edge case: new cable yet port still negotiates 100 Mb/s—why?
Damaged router jack, auto-MDIX mismatch, or badly bent cable (>4× diameter) can force down-shift. Swap ports and re-test [Elektroda, Anonymous, post #17552207]
What bend radius can Cat 6a tolerate in tight baseboards?
Keep bends ≥25 mm (≈4× 6a diameter). Tighter curves raise crosstalk and may fail certification [Belden, 2022].
