Manta Tablet: Application Launcher3 Has Been Stopped - Solutions for Persistent Message
jakubs135 7287 2
  • #1 16680905
    jakubs135
    Rate: 17
    Hello, as in the subject I have a problem with my tablet brand manta namely a few days ago I received the message that "Application launcher3 has been stopped" is so troublesome and the message does not want to disappear and after pressing "ok" the message appears again. Anyone know how to fix it?
  • #2 16680945
    qs300
    Help: 242
    Rate: 362
    Probably only by re-uploading the system, rather there is no other option.
  • #3 16680977
    pitrala1
    Help: 129
    Rate: 111
    The easiest way - Upload valuable data via USB and do the so-called HardReset
    You can combine uploading the software or the application itself through adb, but it's a lot of fun and knowledge, I suggest you do as above :)
