Manta 3204 Communicator TV Key Lock Issue: Remote Control & Function Buttons Not Responding
Korza 12879 1
  • #1 17140519
    Korza
    Rate: 17
    The problem is that the tv does not respond to the remote control (either it is broken or stuck on the tv), and the function buttons on the side do not react except the power button, after pressing any other button, the "KEY LOCK" message pops up.
    Maybe someone had a similar problem or knows the solution?
    Thanks for reply, cheers!
  • #2 17140547
    Freddy
    Help: 1394
    Rate: 2821
    Korza wrote:
    "KEY LOCK" pops up.
    Well, you have the answer, someone has "key lock" - on purpose or accidentally.
    Key Lock
    Use the ? / ? buttons to select the Key Lock menu item, then move to the submenu,
    Press ENTER and use ? / ? buttons to turn the lock on (ON) or off (OFF).
