[Solved] Manta 55LUA57L UHD Smart TV: Netflix Update Issues, Incompatible Versions & Installation Tips
wodz1979 36987 1
  • #1 17562195
    wodz1979
    Rate: 21
    Welcome,
    I have a MANTA 55LUA57L UHD TV, the Netflix app pre-installed works, but informs me of the need to update (does not open some cartoons), but after clicking the update button there is no install option. The same in google play, I can't even find the Netflix app there. Is the latest version not suitable for this tv? Should I wait for the correct update? I tried to install from an external source (I downloaded the google play version on the pendrive) but after installing (overwriting) I get information that the version is not supported by my TV.
    Best regards and thank you for your reply
  • #2 17562278
    wodz1979
    Rate: 21
    Welcome,
    Added after 22 [minutes]:
    https://help.netflix.com/pl/node/12983
    There I found a detailed description on how to update the application, everything ok :-)
