Samsung UE40MU6102 vs UE40KU6400: Comparing 40-43 Inch 4K TVs up to 2200 PLN for 4x5m Room
ReDric 6438 6
  • Need for 4k versus full hd at 1–1.5 m viewing distance
    #1 16682708
    ReDric
    I chose two models, one from the 2016 UE40KU6400 medium shelf, the other from the cheaper 2017 UE40MU6102, both Samsung. Alternatively UE43MU6172.
    Which is better and is there anything more interesting up to 2,200 PLN? Is it worth buying such a 4k, or better a good full hd? (I want 4k :)
    1. How big is the room where the TV should be?
    with 4x5m
    2. How far are we from the TV screen?
    1-1.5m
    3. How many people sit in front of the TV?
    2
    4. Are we sitting in front of the screen or sideways to the screen?
    straight
    5. Is the TV supposed to stand or hang?
    he will be standing on the dresser
    6. How does the sun shine in the room?
    from the back to the tv screen
    7. What is your TV currently?
    Samsung T24D391 monitor
    8. What do we want the TV to have?
    tv smart, 4k / full hd
    9. What signal will be connected to the TV?
    hdmi / dvi
    10. What devices?
    speakers 2 + subwoofer
    11. How many hours a day does the television work?
    from 4h
    12. Does it happen that you watch only one program for several hours?
    Yes
    13. What kind of programs do you watch the most?
    movies
    14. Are you going to surf the internet?
    watch movies from the net
    15. Do you intend to play games - if so, how much% per day?
    yes, ps4, 2h
    16. Brand preferences?
    no, but it must be recommended and tested
    17. Size preferences?
    40-43 inches, there could be more
    18. What annoys you on TVs?
    thread
    19. Do you watch more in the evenings or during the day?
    differently
    20. Up to what maximum amount do you plan to buy?
    2200zł
    21. How often do you change TV sets at home?
    rarely
    22. Do you use internet applications often?
    Yes
    Ludwik XVI
    Help: 1325
    Rate: 788
    KU6400 will be a better choice.
    Just check if the VA matrix is in the size you are interested in. Samsung mixes matrixes within one TV series non-stop.
  • #3 16683894
    ReDric
    I have one more question - is it worth overpaying for ku6400 approx. PLN 300-400 compared to mu6172 / mu6202? Only for this brightness with HDR? Is it better and will work better? Because he is from 2017, he has a new tizen and the like.
    Thanks a lot, I will buy equipment today or tomorrow so that I await the answer :)
  • #4 16683997
    Ludwik XVI
    Help: 1325
    Rate: 788
    MU61 / 61 is a rather direct successor to the KU6000 series.
    Unfortunately, I have not seen a sensible review with matrix measurements, HDR etc. MU61 / 62 series.
    Smart in the MU series is already Tizen 3.0.
  • #5 16684040
    ReDric
    http://www.rtings.com/tv/reviews/samsung/mu6300 = mu6100 with us
    The mu6100 matrix is 10 bit, in KU6400 8, both VA. But maybe it's mu6100?
  • #6 16684077
    Ludwik XVI
    Help: 1325
    Rate: 788
    The VA die is in the 55-inch model.
    You would have to check if the same sits in smaller inches.
    Unfortunately, with Samsung you really have to be careful and check each time before buying.
    If it turns out that there is a VA then take a newer series or MU.
    E.g. the MU7000 series.
    Model 55 inches = 120 Hz, model 49 inches = 60 Hz.
  • #7 16711654
    ReDric
    I bought ue40mu6102, VA matrix, I am satisfied. It is worth buying him, because in the new generation 10bit matrix and new tizen.
    I looked at ku6400, mu6102 and mu6400, there was no visible difference. There is a test for this TV on rtings, mu6102 = mu6300 on rtings, please check it out.
    So I toss up the info I found (it wasn't here yet):
    UE55MU6102: a-si TFT IPS (PLS) panel (RGB), 60 / 50Hz, in service menu 55,
    UE55MU6102: a-si TFT Samsung MVA panel (RGB), 60 / 50Hz, in service menu 55A6AUOVK,
    UE50MU6102: a-si TFT MVA panel (RGB), 60 / 50Hz, platforms
    UE43MU6100: a-si TFT AMVA panel (RGB), 60 / 50Hz, in service menu 43L6AUOVM,
    UE40MU6102: a-si TFT MVA panel (RG? ;) , 60 / 50Hz.
The discussion centers on comparing two Samsung 4K TV models: the UE40MU6102 and UE40KU6400, with considerations for a viewing distance of 1-1.5m in a 4x5m room. Users express a preference for 4K resolution and inquire about the value of investing in the KU6400, which offers HDR and a newer Tizen OS, compared to the MU6102 and MU6172 models. The MU6102 is noted for its 10-bit VA matrix, while the KU6400 has an 8-bit matrix. Users emphasize the importance of checking the specific panel type before purchase due to Samsung's variability in matrix types across models. The MU6102 is reported to provide satisfactory performance, with no significant differences observed between it and the KU6400 in practical use.
