PIONNER AVH-X7800BT Bluetooth Connection Issue: Connected Without Phone, Restore Settings
Weronika Styrcz 13113 11
How can I reset the Pioneer AVH-X7800BT and restore Bluetooth when it shows “connected without a phone” and the Bluetooth settings are unavailable?
Press the reset button located inside the radio’s OPEN button hole using a straightened paperclip or similar tool [#16683332] After resetting, verify on the phone that the car radio appears in the Bluetooth device list and that its permissions are not blocked [#16683435] In this case, restarting the radio and phone did not restore the phone book or enable the Bluetooth icon [#16683424], so the issue may persist after the reset and require checking the phone’s Bluetooth settings.
  • Bluetooth menu disabled after failed phone pairing
    #1 16683069
    Weronika Styrcz
    Hello 
    I bought a PIONNER AVH-X7800BT car radio a few days ago and, since yesterday, I’ve been having trouble connecting via Bluetooth.
    To be honest, at the very beginning I paired my phone with the radio as normal and Bluetooth was working, but when I tried to reconnect my phone to the radio via Bluetooth, it connects but displays ‘Connected without phone’ and still nothing works.
    I’ve tried to remove the paired devices, but I can’t do so because the Bluetooth function isn’t highlighted – it’s as if the radio doesn’t have that function at all. I also wanted to try restoring the factory settings via ‘RESTORE SETTINGS’, but this option isn’t highlighted either and I can’t access it.
    Has anyone else come across a similar situation, or do you know of any other way to reset this radio? HELP
  • #2 16683224
    DriverMSG
    Help: 3984
    Rate: 4888
    Disconnecting from the power supply does not reset the settings?
  • #3 16683300
    Weronika Styrcz
    I tried by disconnecting the cubes and then the same, I was supposed to try to disconnect the battery but I don't know if it would help at all .. I thought there was maybe some other way to restart.
    DriverMSG
    Help: 3984
    Rate: 4888
    See if you have a hole in the OPEN button, there is a reset button inside, you need to press it with a straightened paperclip or similar tool.
  • #5 16683424
    Weronika Styrcz
    Ok radio, I restarted the phone connected to Bluetooth, but still without a phone and I do not have a phone book, in addition, I am sending a picture where the BT icon is still not lit and I cannot enter it
  • #6 16683435
    DriverMSG
    Help: 3984
    Rate: 4888
    Maybe the problem is in the phone settings - check on the phone if there is an available player in the car on the BT list and if the permissions are not blocked there.
  • #7 16683517
    Weronika Styrcz
    I checked but I'm afraid I can't check it
    Added after 11 [minutes]:
    Honestly, I looked through the whole phone but I can't find anything like that ...
  • #8 16683587
    DriverMSG
    Help: 3984
    Rate: 4888
    What kind of phone is it?
  • #9 16684227
    Weronika Styrcz
    Huawei p10 - when I enter BT there are no settings. I downloaded the appradio application, but it is for ISO 7.0 and I have Android 7.0. I thought that somehow I could connect it with a cable and try the program, but nothing too.
  • #10 21951899
    KUSY541
    >>16683069 There’s a green cable at the back of the radio; you need to earth it to something.
  • Grant Bluetooth permissions for the car audio device
    #11 21951911
    płetwa
    Help: 165
    Rate: 555
    In your phone’s Bluetooth settings, next to the name of your radio, there should be a star icon, an ‘i’ or an arrow; you need to tap it and grant permissions. It’s an old phone – I used to have it, but I can’t quite remember the details. On the system I’m using now, you can select various devices: headphones, a speaker, a car audio system, or a hearing aid. There’s also an option for ‘Multimedia and Contacts’ only.
    Weronika, please go through the Bluetooth settings again carefully – you must have missed something in your haste and determination 😉
  • #12 21951950
    damiancz
    Moderator of Car Radios
    Help: 475
    Rate: 1409
    Archived topic – there has been no discussion here for 9 years. Please only reply if you have some advice to offer.
The discussion revolves around a Bluetooth connectivity issue with the Pioneer AVH-X7800BT car radio. The user initially paired their phone successfully, but later encountered a problem where the radio displayed "connected without a phone." Attempts to remove paired devices were unsuccessful as the Bluetooth function was not illuminated. Suggestions included disconnecting the power supply and checking for a reset button inside the OPEN button, which can be accessed with a paperclip. The user also explored phone settings but could not find relevant options. The phone in question is a Huawei P10, and the user mentioned difficulties with the Appradio application compatibility with their Android version.
