Installing Incompatible Drivers on Acer es1-531 for Windows 7: Possible Methods?
Kismir 7626 8
  • #1 16683310
    Kismir
    Rate: 9
    I can't find help anywhere rudders drivers for Acer es1-531 for Windows 7. I don't want to install 8 or 10 because I don't like these systems. Do you know any ways how to install incompatible drivers?
  • Windows 7 hardware IDs for Acer es1-531
    #3 16683426
    Kismir
    Rate: 9
    Dla windows 7 64bit
    Intel Pentium:
    ACPI\80860F14
    *80860F14
    Ethernet:
    PCI\VEN_10EC&DEV_8168&SUBSYS_10121025&REV_15
    PCI\VEN_10EC&DEV_8168&CC_020000
    Kontroler sieci:
    PCI\VEN_168C&DEV_0036&SUBSYS_E07F105B&REV_01
    PCI\VEN_168C&DEV_0036&CC_028000
    Kontroler USB:
    PCI\VEN_8086&DEV_22B5&SUBSYS_10121025&REV_21
    PCI\VEN_8086&DEV_22B5&CC_0C0330
    Nieznane urządzenia:
    ACPI\808622C1
    *808622C1
    ACPI\ACPI000C
    *ACPI000C
    ACPI\INT33FF
    *INT33FF
    ACPI\MSFT0101
    *MSFT0101
  • #4 16683437
    RADU23
    Help: 2428
    Rate: 1732
    Install starting with Intel. After installing the drivers, restart and tell what is missing.
    • USB 3.0_Intel_3.0.1.41_W7x64_A.zip (5.18 MB) You must be logged in to download this attachment.
    • Chipset_Intel_9.2.0.1023_W7x64_A.zip (5.34 MB) You must be logged in to download this attachment.
    • Lan_Realtek_7.088.0617.2014_W7x64_A.zip (5.87 MB) You must be logged in to download this attachment.
  • #5 16683472
    Kismir
    Rate: 9
    Installed only from Lan and the rest displays "Windows cannot install the KOntroler Universal Serial Bus (USB) device" Cannot find the driver
  • Driver links for matching PCI and ACPI IDs
    #6 16683490
    DriverMSG
    Help: 3984
    Rate: 4883
  • #7 16684160
    Kismir
    Rate: 9
    The same problem continues. It does not find drivers. For half the night I struggled with controls drivers and decided to install 10tka.
  • #9 16684441
    RADU23
    Help: 2428
    Rate: 1732
    What does not find drivers mean? Does it show any message about an invalid driver?
    You have to manually select them in the wizard.
    Use the guide he posted @DriverMSG .
The discussion revolves around the challenges of installing incompatible drivers for the Acer ES1-531 laptop running Windows 7. Users share various methods to identify and install necessary drivers, including using device identifiers for unrecognized hardware. Specific driver links for Intel components and Ethernet controllers are provided, along with troubleshooting advice for USB controller issues. Despite attempts to install drivers, some users report persistent problems, leading to considerations of upgrading to Windows 10 as a last resort.
