Driver Problem: Can't Install Network Card Drivers on Acer Aspire E1-570 (Win 7 Pro)
Nemaider 4725 8
  • #1 16677195
    Nemaider
    Hello, I have a laptop freshly formatted (win 7 prof) and I tried to install drivers for the network card to have the Internet in it, but an error pops up every time. It says that it cannot install this driver because there is no such device. Acer laptop, model aspire e1-570.
    I'm counting on your help :)
  • #2 16677217
    Kasek21
    Help: 4981
    Rate: 3547
    Post screen from Device Manager.
  • #3 16677257
    Nemaider
  • #5 16677270
    Nemaider
    I do not know why there was a change, because it is my sister's laptop and she envelops him. I'll give the ID right away
    Added after 6 [minutes]:
  • #6 16677293
    Kasek21
    Help: 4981
    Rate: 3547
    http://mirror2.helpjet.net/LINK-VALID-FOR-24H...e6f6ef/Network_Driver_0WN8T_WN_17.2.0_A08.EXE
    PS.
    First of all, ie the names can be copied.
    Secondly, is it hard to use Google yourself?
    Nemaider wrote:
    If I hadn't been using google, I wouldn't be writing this post here: /
    You got the link so what's the problem? You have Internet access!
    Please update your browser!
  • #7 16677338
    Killlu
    Help: 64
    Rate: 66
    Nemaider wrote:
    I have a laptop
    So why not bother and use the drivers from the manufacturer of this laptop model?
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    And is a colleague sure that the manufacturer's website has drivers for Windows 7? :)
    More drivers are missing.
    1) chipset - install at the beginning from the website of the chipset manufacturer: https://downloadcenter.intel.com/download/200...tility-Primarily-for-Intel-6-5-4-3-900-Series -Chipsets-Zip-Format? Product = 1145
    2) WiFi - download, unpack, install via device manager (network controller) pointing to the directory with the unpacked driver: https://www.ath-drivers.eu/download-driver-nr-310-for-atheros-AR956x-and- Windows7.html
    3) LAN - download from the attachment, unpack, install via the device manager (Ethernet controller) like the WiFi driver.
    4) USB 3.0 - these should work: https://downloadcenter.intel.com/download/211...0-eXtensible-Host-Controller-Driver-for-Intel -7-Series-C216-Chipset-Family
    If any of them fail to install, let your friend know. There will be no driver for the Simple Communications controller (enter the id here and the appropriate driver will be found), it is also worth expanding the "graphics cards" category - if there is a standard VGA controller, it is worth entering its ID and installing the correct driver. If there is only one Intel graphic (PCI \ VEN_8086 & ...) then you can install this driver: https://downloadcenter.intel.com/download/268...el-Graphics-Driver-for-Windows-15-33-?product = 97499
    If he uses a Touchpad Mate and wants finger scrolling and other advanced functions to work - you also need to enter the ID of the touchpad, it will be in the mice in the device manager (visible as a mouse).
    Finally, keyboard shortcuts (screen brightness and more) are handled by Launch Manager. In the attachment LM for a slightly different Acer model, it should work with Windows 7 (the Win8 version cannot be installed under Win7). It should work, but check it out. In Attachment.
    • LaunchManager_Dritek_7.0.12_W7x64_A.zip (20.99 MB) You must be logged in to download this attachment.
    • Broadcom_Vista_Win7.zip (464.63 KB) You must be logged in to download this attachment.
  • #9 16684851
    Nemaider
    helped, thanks so much for your help
The discussion revolves around a user experiencing difficulties installing network card drivers on an Acer Aspire E1-570 laptop running Windows 7 Professional. The user reports an error indicating that the driver cannot be installed due to the absence of the device. Various responses suggest troubleshooting steps, including providing the device instance ID and checking the Device Manager for details. Recommendations include downloading specific drivers from the manufacturer's website and using the chipset manufacturer's site for the chipset driver. A comprehensive list of necessary drivers for WiFi, LAN, USB 3.0, and chipset is provided, along with links to download them. The user confirms that the suggested solutions were helpful.
