Dell Inspirion 15 5567 - Windows 7 - Intel card drivers cannot be installed
ziom.z.kuzawy 3411 8
  • #1 16212678
    ziom.z.kuzawy
    Help: 11
    Rate: 13
    I have a problem with the drivers for the Intel integrated card. Installed windows 7 x64 professional on mbr partition, installed drivers for chipset, usb, lan, .net framework 4.5, all visual c ++ redistributable from 2005 to 2013 x64 and x86. When installing Intel graphics drivers, the error "system does not meet the minimum requirements" is always displayed. I was downloading from Intel, Dell, through the intel driver utility updater program, the same. I downloaded the stable and beta versions. I also tried installing the radeon drivers themselves, they installed but didn't work properly.
    The laptop is new, there was no system in it before.
    Platform:
    dell inspirion 15 5567
    i5-7200u
    hd intel 620 + r7 445m
    8gb ram
    500gb disk
    I attach the log from the installation when I try to install the drivers from della in the attachment.
    log.txt (302.45 kB)You must be logged in to download this attachment.
    Edit: I did not notice that the wrong department, please move.
  • #2 16212755
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Unpack the Intel drivers and install manually from the device manager.
  • Windows 10 required for Intel HD Graphics 620 drivers
    #3 16212774
    enhanced
    Help: 963
    Rate: 883
    How do you want to install win7?
    You can see immediately that you need windows 10 for these drivers.
    http://www.dell.com/support/home/pl/pl/pldhs1...-15-5567-laptop&languageCode=po&categoryId=VI
    Supported operating systems
    Windows 10, 64-bit
    After these
    http://www.intel.com/content/www/us/en/suppor...n-intel-processors/intel-hd-graphics-620.html
    also does not detect 620?
  • Questioning the need for driver cleanup after chipset installation with signatur
    #4 16212801
    ziom.z.kuzawy
    Help: 11
    Rate: 13
    The standard VGA driver already supports this card, and when I try to add it manually, I get the message: "windows has determined that the driver is up to date". Should I try for some driver-swepper? If so, what files, from what folder? By the way, I remembered one detail: I installed the chipset drivers with the enforcement of digital signatures turned off.
    To enhanced: these I've already tried.
  • #5 16212810
    enhanced
    Help: 963
    Rate: 883
    give installation logos to those from the link because the log you entered is not of them.
  • #6 16212833
    ziom.z.kuzawy
    Help: 11
    Rate: 13
    I do not know how to get the log from Intel, after extracting the files by the program immediately there is a message "the system does not meet the minimum requirements".
  • #7 16212853
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    During manual installation, choose that you want to choose the driver to install instead of automatic installation.
    Driver supports Windows 7 only on 6th-gen Intel processors
    #8 16212854
    enhanced
    Help: 963
    Rate: 883
    So I thought well that win10 must
    from the readme of these drivers:
    Driver Version: 21.20.16.4542
    Release Version: Production Version
    Release Date: November 3, 2016
    Platforms / Operating System (s):
    7th Gen Intel(R) Core (TM) processor family
    7th Gen Intel(R) Pentium(R) processor family
    7th Gen Intel(R) Celeron(R) processor family
    Microsoft Windows * 10-64
    6th Gen Intel(R) Core (TM) processor family
    Microsoft Windows * 7-64
    Microsoft Windows * 8.1-64
  • #9 16212897
    ziom.z.kuzawy
    Help: 11
    Rate: 13
    Good to know I've tried the impossible for a good few hours. However, there are advantages to reading the manual. You have a thumbs up from me for stopping me from wasting more precious hours.
The user is experiencing issues installing Intel integrated graphics drivers on a Dell Inspiron 15 5567 running Windows 7 x64 Professional. Despite installing necessary chipset and other drivers, the installation fails with a "system does not meet the minimum requirements" error. Suggestions from the community include manually unpacking and installing drivers via Device Manager, confirming compatibility with Windows 10, and using driver-sweeper tools. The user has attempted various driver versions from Intel and Dell, but the standard VGA driver remains the only one recognized. The discussion highlights the challenges of driver compatibility with older operating systems and the need for updated software support.
