Seeking Drivers for Lenovo V110-15IAP Laptop on MS Windows 7 PRO 64-bit system
muadeep 13662 4
  • #1 16188462
    muadeep
    As in the subject, I am looking for drivers for the MS WIndows 7 PRO 64-bit system for the Lenovo V110-15IAP laptop
    http://support.lenovo.com/pl/pl/products/Lapt...bName=Downloads&linkTrack=Mast:SubNav:Support :D rivers 20Software% 20and% | Drivers% 20and% 20Software
    After the whole day of fighting with the majority, I won,
    Ie: I managed to install the entire system in addition to 3 devices:
    Ven_8086 & Dev_5a9a - Intel (R) Trusted Execution Engine Interface
    There were already a few drivers that should work, unfortunately, each installation receives the message "system does not meet minimum requirements" and other such types of errors; /
    ACPI \ INT3452 - Intel (R) IO GPIO Host Controller - INT3452
    It's totally ugly here. I do not want to install anything.
    Ven_8086 & Dev_5AA8 - two results in google. Universal serial bus USD controller
    And here is the biggest problem after USB does not work; / Neither 2.0 nor 3.0 (drivers for USB 3.0 I have OK, but nothing can detect the port).
    Generally, I assume the problem is based on a badly installed chipset or other USB-friendly bitterness.
    I installed the chipset for the version of WIn 10 (nothing was done). I installed it from Lenovo V11-15ISK (nothing was done).
    I have got the software for graphics integrated with driver.sru, which is the part of Intel that throws "no minimum requirements", do not know why.
    Regarding the issues with which I won: it's all the rest. Card reader, audio, camera, if you do not look at graphics, one keye, wifi, ethernet, quick launch, bluetooth and even USB 3.0 drivers. If someone needed it, please contact me, let me know.
    Puki is trying to put together a whole package of drivers for 7 64-bit wines and try to cut the entire package (which will help some of the others who will have the "pleasure" to work with this product :D )
  • #2 16188484
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    I do not know what you expected when the computer is only sold from W10 and from what I see it does not have any drivers under W7.
  • #3 16189021
    muadeep
    Just like 90% of products at the moment, and yet for the majority of them there is no problem getting drivers for wines 7.
    Windows 10 just does not want to.
  • #4 16191957
    master-007
    Moderator on vacation ...
    Help: 330
    Rate: 390
    It's like writing @Kolobos to these devices there are no Windows 7 drivers at the moment. If it was not for the chipset drivers, you could try to replace the IDs in the Windows 8 driver file and use manual installation, but for chipset drivers it is difficult to predict the effects.
  • #5 16264477
    muadeep
    Unfortunately, you can not do anything about this.
    Tmat do zamkniecia; /
