Dishwasher BOSCH SMV53 - Suspended panel / program can not run anything to chang
Przemoad78 23304 3
  • #1 16683998
    Przemoad78
    Hi I have a problem with the dishwasher BOSCH today, after selecting the programs suddenly hang up something - generally you can not do anything further. I did a current reset: a short switch off does not change anything, long only 3 minutes away the same thing goes on, the smart program shows time and nothing else can be done.
    The complete symbol of the SMV53M70EU / 74 dishwasher
    Does anyone have an idea how to do a reset or possibly what has been done and should be replaced? Dishwasher BOSCH SMV53 - Suspended panel / program can not run anything to chang
  • #2 16684114
    h jaworski
    Home appliances specialist
    Help: 466
    Rate: 717
    After closing the dishwasher, you have to see if the display goes out, if it does not go out, I would check the door lock. The key reset was done? but do not ask how to read the instructions to be followed on the internet.
  • #3 16684122
    Przemoad78
    OKAY. Thank you for the info for about 3-4 hours I will check it out and let you know.
  • #4 16686568
    Przemoad78
    The problem was solved. It was a suspension, but after pressing on the various buttons, the dishwasher was run on the suspended panel (although the program was shorter than it should have been). Before that, I turned off the power for 3 hours from the power supply, but maybe it did not help. After the cleaning cycle, everything has returned to normal.
    Thank you for joining the post.
