[Solved] Resetting Bosch SGI4900 / 13 Dishwasher: Seeking Guidance on Program Restart
poczta99 18294 10
How do I reset a Bosch SGI4900/13 dishwasher so the program starts from the beginning again?
Turn the dishwasher on, then hold program buttons 1 and 3 (intensive and eco) at the same time until “0” appears on the display; that is the reset procedure [#17267575] If the combination does not work, the button actuator/button pusher may not be physically pressing the microswitch correctly [#17267618] The thread author confirmed that after pressing the correct buttons, the reset worked [#17267785] The manual can also be found on Bosch’s website by entering the E-number [#17267807]
  • #1 17266071
    poczta99
    I have a problem with the dishwasher Bosch SGI4900 / 13 dishwasher at first did not want to turn on, then it worked a bit and turned off, I cleaned it and it is possible that everything will be fine. Only that before it had already been a dozen or so minutes to work and now when I turn it on the program is after a dozen or so minutes I would like to reset it to work from the beginning of the program, take in water, etc. Turning off the electricity does not give anything the program has memorized time. Does anyone know how to reset it, and how would someone have the best service manual or whatever it would be great.
    The most important thing is how to reset it.
  • #2 17266171
    Chupacabra
    Help: 247
    Rate: 868
    Have you tried holding the START button for 5 seconds?
    EDIT:
    The instruction says up to three seconds.
  • #3 17266255
    poczta99
    Pressing for a few seconds does not help
  • #4 17266563
    Chupacabra
    Help: 247
    Rate: 868
    This will be a bigger problem than just resetting the program. Let the program go and see if it comes to an end.
  • #5 17267427
    poczta99
    I did as you wrote. The program reached 6 minutes, when it was supposed to jump 5 minutes it started from the beginning of the program, I waited for the next cycle and the second time it was the same and turned off the dishwasher. How to fix it?
  • #6 17267575
  • #7 17267608
    poczta99
    Nothing gives you the push of two buttons, although these are not intense and eco, but I tried the first and third from the left and right various combinations.
    As any advice, let's set the order of the buttons. Are following
    1. -> ->
    2.55 *
    3.5 *
    4. 65 *
    5. washing only the top
    6. washing the top and bottom
    In the very corner on the other side of the dishwasher
    7.Włącznik
    Any ideas
    The dishwasher does not want to finish the program as it should be 5 minutes until the end the program starts again.
  • #9 17267785
    poczta99
    skryn wrote:
    And there is no option for it not to work. Otherwise, you have a broken button pusher that does not physically push the micro switch.
    Earlier I pressed other buttons. After pressing these buttons it actually worked.
    1. I wonder why the program got stupid or after I tried to run several times when it was contaminated, or just how it clogs, after each cleaning you need to do such a reset?
    2. Can you send me the instructions you have for this dishwasher? Poczt99(_at_)o2.pl Thank you for your help.
  • #11 17267846
    poczta99
    Thank you again.
    Problem solved.
The discussion revolves around troubleshooting the Bosch SGI4900 / 13 dishwasher, specifically addressing issues with program resets and operational failures. The user initially faced problems with the dishwasher not turning on and subsequently shutting off during operation. Attempts to reset the program by holding the START button were unsuccessful. A solution was found by pressing specific program buttons simultaneously, which successfully reset the machine. The user also inquired about the need for resets after cleaning and requested a service manual, which was suggested to be available on the Bosch website.
