Bosch SRV55T43EU Dishwasher: Power Supply Connected, Non-responsive Start - Programmer or Switch?
ZANDAR 21138 17
How can I find the cause of a Bosch SRV55T43EU dishwasher that has power but does not respond to the Start button, and is the fault more likely in the programmer or the switch?
Start by checking the switch with a multimeter, but the more likely fault is in the control module’s power supply rather than the switch itself [#16190939] In the reported case the gray/burned resistor and the LNK304GN were the damaged parts, and replacing the 100 Ω / 2 W resistor together with the LNK304GN restored operation [#16191607][#16202610] Replacing only the resistor is not enough, because it is mainly a protective part that burns out when the LNK fails [#17614767][#17623243] One reply also suggested replacing the capacitor on the board as a precaution [#16601338] If the dishwasher then powers up but still does not take in water, check the AquaStop valve, wiring, and whether the tap is open [#17504016]
  • #1 16190926
    ZANDAR
    Hello :D
    I have a problem with the Bosch SRV55T43EU dishwasher, which, despite being connected to the power supply and switching on the start, does not respond. The dishwasher is already 6 years old, so eventually something had to break. And here the question is whether the problem lies in the programmer itself or in the switch. I am just starting to disassemble the dishwasher and ask for help where to look for more or less the cause of this phenomenon :?:
  • #2 16190939
    tod.1977
    Help: 65
    Rate: 148
    Hello. If a colleague has a multimeter at home, after removing the module measure the switch and if it turns out to work, post photos of the removed driver on the forum. Best regards.
  • #3 16191218
    ZANDAR
    I dismantled the driver and at first glance it seems ok, only this resistor is strangely gray (may its life be over, unfortunately I don't have a multimeter :cry: ). Bosch SRV55T43EU Dishwasher: Power Supply Connected, Non-responsive Start - Programmer or Switch?
  • #4 16191375
    tod.1977
    Help: 65
    Rate: 148
    Without a millimeter, even a colleague does not know whether the switch itself is in working order. Purchase of such a meter for amateur needs in an electronics store is an expense of about PLN 25, and don't go without it in this case. Secondly, such a device will always be useful at home.
  • #5 16191533
    ZANDAR
    That's the problem :) I need to stock up on such a device. As for the dishwasher, after tracking hundreds of pages, the resistor dropped on 99%, and LNK304GN. Will a friend tell you what resistor will be ok?
  • #6 16191607
    TONI_2003
    Moderator
    Help: 2194
    Rate: 3822
    There is nothing to worry about just going to someone familiar with the subject, and replacing the 100? / 2W resistor and the LNK304GN integrated circuit, I think, will help restore the dishwasher to use :D
  • #7 16202610
    ZANDAR
    I replaced the parts and the dishwasher started :D Only now do not know why it does not draw tap water :cry:
  • #8 16601338
    przemoch
    Looking at the picture - I would also consider replacing the capacitor.
  • #9 17395389
    misiek1369
    How many watts is this resistor?
  • #10 17396366
    wiesiekmisiek
    Help: 259
    Rate: 524
    Read carefully. 2W - Moderator TONI_2003 described it above.
  • #11 17502460
    lukas6873
    Rate: 34
    I have the same problem with this driver. Colleagues, please correct if I'm wrong, but isn't that a 200? resistor?
  • #12 17502599
    zhudomel
    Home appliances specialist
    Help: 1280
    Rate: 3372
    No!
  • #13 17503362
    lukas6873
    Rate: 34
    Thanks! After burning, the third strip is very different from the first, hence my guess.
  • #14 17503652
    TONI_2003
    Moderator
    Help: 2194
    Rate: 3822
    So just start reading and looking instead of littering the topic. There is everything like ... :arrow: # 6 Jan 11, 2017 18:08 :idea:
  • #15 17504016
    Piotr2608
    Help: 851
    Rate: 4487
    What like what but Bosch uses 100W 2.5W resistors in dishwashers :)
    ZANDAR wrote:
    I replaced parts and the dishwasher started Only now do not know why it does not draw water from the tap
    As for not collecting water:
    - cables all plugged in?
    - AquaStop valve OK?
    - faucet unscrewed?
    It happened that the processor liked to experience "shock" after the LNK explosion, since before the repair the dishwasher was working properly ...
    ZimTech Piotr Zimny
  • #16 17614736
    darbi
    SRV45T63EU / 01 cannot be turned on.
    I took out the programmer and, as in the description above, the condensed resistor after replacing with a second old one and turning on the plug immediately turned on.
    What can be the reason for the resistor burning?
    Replace this resistor together with the system?
  • #17 17614767
    wiesiekmisiek
    Help: 259
    Rate: 524
    Yes. Replacing the resistor alone does not do the trick.
  • #18 17623243
    darbi
    Thank you for helping the dishwasher work.
    In the store where I bought components, the seller was familiar with the topic: LNK is damaged while the resistor is only a protection - it is to burn out.
✨ The Bosch SRV55T43EU dishwasher is experiencing a non-responsive start despite being connected to the power supply. Users suggest checking the switch and the programmer for faults. A multimeter is recommended for testing components. The discussion highlights the importance of replacing a faulty resistor (100Ω, 2W) and the LNK304GN integrated circuit, which are common failure points. After replacing these parts, one user reported the dishwasher started but faced issues with water intake. Additional troubleshooting steps include checking the AquaStop valve and ensuring all cables are connected properly.
