Touran 1.9 TDI 101 HP - errors 1411 and 1409 No heating error 01809 and 01274
witek271 24030 9
Where is the G18 temperature sensor located on a Touran 1.9 TDI auxiliary heater, and what could cause the reported heating failure?
The G18 temperature sensor is located on the auxiliary heater/pump assembly; the linked diagram shows its position and access point [#16686890] The 01411 fault reports an intermittent short to ground, while 01409 records repeated flame-outs. Although the temperature-flap linkages moved and the heater hoses were hot, the air remained cool, especially on the right side, so the flaps were not necessarily the root cause [#16697487] The likely cause was a blocked or internally restricted heater, and replacing the heater restored cabin heating; the unblocked Webasto also began heating after a few kilometres [#16698889] [#16741672]
  • #1 16686493
    witek271
    Help: 19
    Rate: 174
    Tak jak w temacie pacjent Touran 1.9 TDI 101 KM
    Błędy z Vaga poniżej Czy ktoś z Was wie gdzie znajduje się czujnik temperatury G18 i jak się do niego dostać
    Thursday,07,September,2017,16:03:28:62939
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.0.0
    Data version: 20130910
    Address 18: Aux. Heat Labels: 1K0-815-007.CLB
    Control Module Part Number: 1K0 815 007 R
    Component and/or Version: Standheizer 011 1403
    Software Coding: 0000112
    Work Shop Code: WSC 42684 126 88683
    VCID: 3365F94752C0B386591-8066
    2 Faults Found:
    01411 - Temperature Sensor (G18)
    007 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00100111
    Fault Priority: 0
    Fault Frequency: 3
    Reset counter: 200
    Mileage: 248071 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:00:23
    Freeze Frame:
    Ctrl. Pause
    Temperature: 205.0°C
    Temperature: 55.0°C
    01409 - Repeated Flame-Out
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 200
    Mileage: 248071 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:00:23
    Freeze Frame:
    Malfunction
    Temperature: 55.0°C
  • #3 16688478
    witek271
    Help: 19
    Rate: 174
    So it's on the heater's pump
    But I still have no heating
    Summer is almost cold air, but after turning 18 degrees the air conditioning works
    Heater tubes inside hot
    Hot water pump hoses
    So yes scan Vag
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Control Module Part Number: 1K0 907 044 N
    Component and / or Version: ClimatronicPQ35 061 0201
    Software Coding:
    Work Shop Code: WSC 00000 000 00000
    VCID: 326BFC43ADDABA8E527-8067
    2 Faults Found:
    01809 - Actuating Motor for Temperature Flap; Left (V158)
    01274 - Air Flow Flap Positioning Motor (V71)
    000 - -
    So I'm looking for where these engines are
    Drawing helped me
    I checked and the tie rods move in both directions V107 engine and V158 engine
    The additional heat pump works in 100.6% measuring blocks
    but there are also mistakes
    These errors pop up after manually switching on the climatronic panel. In the measuring blocks the temperature is 168 degrees and after clicking the button on the panel 205 degrees pops up.
    Component and / or Version: Standheizer 011 1403
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 3
    Reset counter: 200
    Mileage: 248,071 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:00:23
    Freeze Frame:
    Ctrl. Pause
    Temperature: 205.0 ° C
    Temperature: 55.0 ° C
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 200
    Mileage: 248,071 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:00:23
    Freeze Frame:
    Malfunction
    Errors cleared
    Engines are working error 01809 no longer pops up in blocks everything changes nicely
    There is only error 01274 but it is not likely to affect heating
    If I turn from LO to HI, I can feel the difference because the climate works on LO and on HI a slightly warmer air flies
    As if the air conditioning flap closed and the heating flap did not open at all
    I have no idea how to go about it now
    I will add a picture from myself for posterity maybe someone Touran 1.9 TDI 101 HP - errors 1411 and 1409 No heating error 01809 and 01274 handy
  • #4 16689785
    witek271
    Help: 19
    Rate: 174
    I will add a video confirming the flap pull, I am still wondering if both flaps could be damaged at the same time inside because the tubes from the heater are so hot in the hands
    jerrydzwonkow
    Rate: 18
    So far it has been good? Because if both left and right temperature flaps work as in the video, there is no option that it doesn't heat inside. Maybe the problem is with the heater, clogged ducts, the liquid does not go through the entire exchanger and so it will be. Problem with engine temperature is gone? 90 degrees holding?
  • #6 16697487
    witek271
    Help: 19
    Rate: 174
    The car keeps the temperature
    It is slightly warm on the left and cold on the right
    After getting into the air outlet on your legs, feel the temperature change cold - after inserting your hand - it is not hot as it should be
  • Deformed heat-cold flaps caused HVAC faults
    #7 16698101
    jerrydzwonkow
    Rate: 18
    I stripped the whole heating team and swore in tour a year ago. These heat-cold flaps controlled by v158 and v159 motors were deformed and stuck into the housing. At the end of each there was a spoiler and he hooked, I cut it, I made it and the problems ended. But then they wouldn't work like in the video. If you could remove the cable from the right or left side, then try to manually move the flap and check the temperature of the air supply.
  • #8 16698327
    witek271
    Help: 19
    Rate: 174
    I started manually pulling the cable and there is no difference I just burned my hands from the heater pipes
    jerrydzwonkow
    Rate: 18
    I bet on a stuffed heater. There are no wonders how the flaps go with an efficient heater must heat.
  • #10 16741672
    witek271
    Help: 19
    Rate: 174
    However you hit
    The replaced heater heats up nice
    The unblocked webasto also heats after a few kilometers
The discussion revolves around a Volkswagen Touran 1.9 TDI with heating issues and error codes 01411 (Temperature Sensor G18) and 01809 (Actuating Motor for Temperature Flap). Users seek guidance on locating the G18 temperature sensor and troubleshooting the heating system. Responses indicate that the sensor is located on the heater's pump, and several users report that despite the heater tubes being hot, the cabin does not heat properly. Suggestions include checking for clogged ducts, ensuring the heater is functioning correctly, and manually testing the temperature flaps. One user resolved their issue by replacing the heater, which improved heating performance.
